Wheel Specs
Discussion in 'Wheels & Tires' started by replica9000, Mar 18, 2009.
  1. Aug 22, 2010 at 5:56 PM
    #61
    6spdtaco
    6spdtaco Well-Known Member
    VT
    Taco
  2. Sep 26, 2010 at 7:04 PM
    #62
    trdproven
    trdproven Well-Known Member
    What would be the perfect wheel fitment specs for 16", what would be the offset and bs in order to clear the suspension and stay flush with the fender? thanks
    if anyone got the flat rota grids or te37 specs, i'd really appreciate it.
  3. Oct 11, 2010 at 1:50 PM
    #63
    JJK
    JJK Active Member
    08 SR5 DC
    TrueTrac Limited Slip
    Tacoma 2005+ stock 16” Alloy wheels 26lb per box ship weight (per UPS).
    Part # 42611AD031
  4. Oct 14, 2010 at 7:16 PM
    #64
    wholesaler57
    wholesaler57 Member
    Florida
    prerunner SR5
    Does anybody know if the 16x8 stock wheel off of a 2010 Tacoma 4x4 will fit my 2002 Tacoma Prerunner 2 wheel drive? If so, please let me know.
  5. Oct 15, 2010 at 11:39 AM
    #65
    scriber007
    scriber007 Well-Known Member
    They are 16x7, and they should fit. The only thing it will tuck in more. The backspacing is around 5 inches. The first generations have 4.5 backspacing.
  6. Nov 11, 2010 at 9:25 PM
    #66
    HBtaco
    HBtaco Active Member
    Austin
    2022 Grey DCSB TRD Sport 2WD
    Bilstein 6112 Bilstein 5110 w/ICON 1.5" AAL 285/75/r17
    any info on a 2011 dc with the trd sport package? the only info i have as of now is the tire and rim size
    thanks
  7. Dec 10, 2010 at 12:05 PM
    #67
    Griffindoug
    Griffindoug Member
    Doug
    Rhode Island
    06 Tacoma SR5 Trd
    Bone Stock, for now
    Just ordered some Wrangler Duratracs 265/70/17 and I am running stock suspension. I have a TRD sport, with 17" rims. I am a little overwhelmed by which wheels will fit well. Most of the aftermarket rims have a very small offset. How important is the offset? I see at the beginning of this thread, it shows the specs of the stock sport rims, should the aftermarket rims meet these measurements exactly? if not which measurements can I ignore, and by how much?
    Thanks
  8. Dec 16, 2010 at 10:08 AM
    #68
    Taco canuck
    Taco canuck Member
    Nova Scotia, Canada
    2011 TRD Sport
    I just checked the hub bore size on my 2011 TRD Sport and it measures 106mm instead of the 108mm stated in the first post.
  9. Feb 26, 2011 at 11:04 PM
    #69
    usualxsuspect
    usualxsuspect Well-Known Member
    Brian
    Tracy, CA
    '02 2.4L 2WD Xtracab SR5
    Pioneer deck + amp w/ Polk Audio 10' sub. AFE Pro Dry S air filter. Bug and window deflectors. Tinted all around.
    Anyone know the specs for a 1st gen steel wheels, specifically a....
    2002 2.4L xtracab SR5?
  10. Feb 27, 2011 at 6:28 PM
    #70
    scriber007
    2wd steel wheels are 15x6
    Bolt pattern / bolt circle / PCD: 5 X 114.3 (mm) = 5 X 4.5"
    Lug Nut Thread Format: M12 (12 mm) X 1.5
    Borehole 67.1 mm
  11. Jun 30, 2011 at 7:52 AM
    #71
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    if the trd off road wheels are 5.25" backspacing, what is the most/least backspacing I should do to not start hitting suspension parts. I am looking at getting some winter rims and tires, but the tires will be the same as the factory 265/70/16. But I want to get as close to the 5.25" backspacing as possible.
    If I do 4.75" backspacing, will I get rubbing?
  12. Jul 7, 2011 at 4:39 PM
    #72
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Anyone know the backspacing of the tx pro wheels
  13. Oct 18, 2011 at 7:36 AM
    #73
    TacomaPrime
    Gregory
    Illinois
    I would like to know this as well.
  14. Oct 19, 2011 at 5:08 AM
    #74
    dustbowl
    dustbowl Member
    slidell,louisiana
    02 limited tacoma
    I have an 02 limited prerunner TRD and I've been searching eBay for a while and everything I like is saying not compatible with my truck. All specs say I have 6x139.7 (6x5.5) but nothing seems to work. Any help would be appreciated
    #74
  15. Oct 28, 2011 at 5:59 AM
    #75
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Aluminum TRD Sport 17" wheel = Multiple finds, sorry can't confirm any of these.
    22.5lbs
    25.5lbs
    28.9lbs
    Aluminum TRD Offroad 16" wheel= 22.2 to 22.4lbs
    My SR5 base model 4x4 truck has a center bore of 106mm, I would assume that this is the same for all 05+ model Tacomas with 6 lugs.
  16. Nov 19, 2011 at 4:12 PM
    #76
    gus54
    gus54 Well-Known Member
    Gus
    Cleveland, Ohio
    2016 Quicksand Tacoma TRD Off Road
    Undercover Lid, BFG KO2 AT
    Looking to replace these 16" alloys in the spring. Anyone have the specs for this wheel? Or whatever the specs would be for an aftermarket wheel to replace them.
    Also...my Taco is not the TRD, but are these the same as the TRD 16" wheels?
  17. Nov 22, 2011 at 4:12 PM
    #77
    gus54
    Gus
    Cleveland, Ohio
    :eek: uh...that's what I get for listening to my wife without looking at what she was talking about first. Turns out what she thought was the finish peeling was some sticker that was somehow stuck on the wheel and was turned up on one side. I told her "Come here honey, and watch this..." as I peeled it off the otherwise perfect wheel. She just shrugged and walked away. :facepalm:
  18. Nov 22, 2011 at 5:02 PM
    #78
    Sabre01
    Sabre01 Active Member
    N.H.
    V-6 Prerunner
    Thats why I'm here!...Never done, all it takes is $$$
    Just an FYI on the backspace/aftermarket thing. If you want the wheel to stick out more, For more clearance, you need a numerically lower number than you currently have (For Larger Tires than 265/75x16). To measure backspacing; take the wheel off, lay it face down, place a straightedge on the edges of the rim, NOT the tire!. Now, this is not easy with the tire mounted, but it can be done. As long as you have a straight edge to measure from, this can be a good,straight piece of lumber, a framing square, even a good,straight cardboard edge.. Place the straight edge on the rim, rim, rim!! Then measure down to the 'flats' or, the hub as it's known, that distance will be the backspace of your wheel. So, if youve got a 5.5" backspace and your huge tire is rubbin', you will need more backspace, such as 4.5" for example, which ironically, is a Lower number, I know. what your'e trying to do is move the CENTER of the wheel in, towards the vehicle, which in turn will move the RIM (&Tire) OUT. Now , keep in mind, this will cause excess load on your spindles/front end parts IF you go excessive. An inch should not cause much stress, but if you go more, the stress increases the farther you go... I'm sure you have all seen the car or truck out there that looks absolutely stooopid with rims sticking way out beyond the sides of the car !! So, here I've given you MY best explanation of backspacing, I have done this on my cars with custom rims, Tubbed out Hot Rods,Mustangs etc... It's not that hard, and if you need a Visual of the above process, I've seen it on many of the Tire mfg's sites, SUMMIT has a good one, there are many, but I give you my .02 cents in an effort to help. May your Flaps be Muddy:D
    Charlie Bravo likes this.
  19. Dec 14, 2011 at 8:23 AM
    #79
    Chimp75
    Chimp75 Member
    Sun Valley, ID
    08 TRD Sport 6-Spd
    Fox Shocks, TRD Intake/exhaust, TRD Short shift kit, Camburg upper A-arms
    I've been looking around on this thread for a while an haven't found an answer so here is the most likely place to get one and the most relevant.
    I have a 2008 TRD Sport with 17's (obviously) and I decided to buy some 16's because winter tires are cheaper and more widely available used in that size.
    I bought a set of TRD Off Road wheels assuming they would just slide right on, but now reading through this the backspacing is slightly different.
    Can I just put these wheels on my truck without issues? I am assuming all the front suspension parts and brake rotors are all the same between models.
    Thanks in advance for the input, I'm anxious to know if I blew it.
    Chimp
  20. Dec 16, 2011 at 8:19 PM
    #80
    massboy11
    massboy11 Member
    Don
    New Jersey,USA
    09 Tacoma 2x4
    Thanks for the info! As ashamed as I am to say this...I didn't even know the specs on my own wheels, now i can start shopping for new wheels with a little knowlege of what I can put on there.
