Wheel Specs
Discussion in 'Wheels & Tires' started by replica9000, Mar 18, 2009.
  1. Apr 30, 2013 at 9:10 PM
    #161
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
  2. May 3, 2013 at 12:30 PM
    #162
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    There is a new 17x8" Six Shooter coming out later this month.
    17x8"
    6x139.7
    0mm offset
    4.5" back spacing
    265/70R17 will be a good size if you aren't lifted. Very little to no trimming required. Front mud flaps will need to be removed on a stock Tacoma.
    275/70R17 will also work with a bit more trimming (again, on a non-lifted Tacoma). You'll need to trim the bottom of the fender liner, a small portion of the inside of the over-fender trim, and remove the front mud flaps.
    Neither tire size will rub on your frame / cab-mount. :)
    Suspension clearance will be great too.
    If you do want the 17x9" Six Shooters 285/70R17 is usually a better size to use.
  3. May 3, 2013 at 12:49 PM
    #163
    JdMeF9SiR2
    Corona, CA
    Most wheels today are made in China. I've been in the wheel business for 15 years now, and I came into the business at a time when wheel manufacturing was transitioning into China.
    I can tell you from hands on experience that most (not all) of the wheels that are made in China are of lower quality than wheels made just about anywhere else. That does not mean that the wheels from China are low quality, or that all wheels from other countries are better than all wheels from China, but generally speaking I have found the majority of wheels from China to be heavier, require more weight to balance, lower quality finishes, and apparent less attention paid to details.
    Overall the benefit of manufacturing wheels in China is inexpensive, quick mass production. I consider most wheels from China to be "commodities" rather than specialty or high-end items. It is concerning (and a little bit sad) to me to see Toyota outsourcing wheel production to China, and my feelings are based on the facts I've gathered from taking the time I to do hands on tests with the Chinese-made Toyota OE wheels that have come out (and are continuing to come out) over the last few years. The wheels Toyota is using from China are not unsafe, and they don't have particularly poor finishes, but they are extremely heavy, which is usually a tell-tale sign of lower-tech manufacturing which requires more material to achieve the proper load rating.
    There are some high-tech facilities being built in China now, but the costs and turn around times are not as quick from these factories, so it will be interesting to see how much these new factories are put to use.
    I personally do not stock any wheels from China. When a factory in China can make a wheel that is wholly superior to a wheel from a factory that I am using elsewhere, then I will consider using that factory. I have an obligation to offer my customers the best possible wheel that we can find that meets our standards within our price point. Selling wheels made in a certain country just because they're cheaper and quicker to produce is not one of my standards.
    These statements are solely related to the quality of wheels from China. I do have personal views on the treatment and welfare of Chinese factory workers as well that keeps me from ordering from China, but those are unrelated to "wheel specs," and I don't want to bring this thread further off-topic.
    -Dustin
    FN Wheels
  4. May 5, 2013 at 9:13 PM
    #164
    jsantoslincoln
    jsantoslincoln Member
    James
    Lincoln, CA
    Thanks for the feedback. Per our email conversation, lookin forward to these comin in!
  5. May 6, 2013 at 4:45 PM
    #165
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    Dustin good shit man! Thank you...My new SCS wheels are made in "Thailand" lol NOT China :D
  6. May 6, 2013 at 6:22 PM
    #166
    JdMeF9SiR2
    Corona, CA
    Thanks guys. :) I'm just glad to be able to contribute.
  7. Jun 21, 2013 at 12:05 PM
    #167
    AFZ
    AFZ Well-Known Member
    IN
    4x4 AC 4.0 TRD OR
    So Base and TRD O/F have different size calipers?
  8. Jul 31, 2013 at 2:28 AM
    #168
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Went from the first page to the last. No update for the first page for weights on the steelies and TRD OR wheels?
    I'm thinking about going to steelies but not if they are more heavy. I will assume they are heavier.
  9. Aug 11, 2013 at 10:05 AM
    #169
    gretch6364
    gretch6364 Active Member
    Any word yet on the Tacoma Baja backspacing?
  10. Aug 13, 2013 at 3:10 PM
    #170
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    I pieced this together from the TRDparts4U and discussions with my Discount Tire guy for the TRD Baja wheels:
    TRD Baja Alloy Wheels: 16x7.5, 6 to 10 mm offset, ? backspacing, 6x5.5" bolt pattern, 106mm hub bore, 5.5 inch bolt circle, ? lbs
    Didn't find weight or backspacing.
  11. Sep 12, 2013 at 9:25 AM
    #171
    SRT Nate
    SRT Nate Well-Known Member
    Nathan
    Titusville, FL
    10 PreRunner DCSB TRD Sport
    6K Hid Headlights, 3K Hid Foglights, Black Housing Headlights and Smoked Fog Lights, Access Rollup Tonneau Cover, Debadged, K&N Intake, OEM Roof Rack
    9 pages and no info on the 20" Enkei WT4s? Any one care to chime in with some info?
    Nate
  12. Oct 22, 2013 at 6:27 PM
    #172
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  13. Oct 23, 2013 at 3:56 PM
    #173
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if the TRD off road rims have a 32mm offset and 5.25 back spacing can i assume that the TRD FJ rims with a 15mm offset have 17mm (.67in) less back spacing?
  14. Oct 23, 2013 at 4:29 PM
    #174
    KenLyns
    Belly of the Beast
    Not quite. The FJ TRD wheel is 7.5" wide. So 5.25 - 0.67 + 0.25 = 4.83" backspacing.
  15. Oct 23, 2013 at 4:36 PM
    #175
    nd4spdbh
    SoCal
    Ahh yes forgot they are .5in wider.
    Whats the offset on stock 2004 TRD 6 lug rims
    these guys.
  16. Nov 6, 2013 at 9:34 PM
    #176
    rhuffman12
    rhuffman12 New Member
    ryan
    florida
    tacoma 4x4 2 in level
    leveling kit
    so I have a 99 1st gen with about 2 in level and want new tires and rims. could I clear 285/65/18 on -24 or even -12 (rather run -12 cheaper) offsets? or could I get even crazier and run 295/70/18s? I want big tires and rims but little lift and rub.
    currently running 265/75/16 with practically no rub. plan on putting bigger leveling just want to know If I need a different tire size and if itll run on the upper control arm
    thank you!
  17. Nov 6, 2013 at 9:43 PM
    #177
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Anyone know what the base model SR5 steel wheels weight is?....just curious.
  18. Nov 7, 2013 at 10:35 AM
    #178
    MRJ
    MRJ Well-Known Member
    Bucky
    Kent, WA
    '12 pyrite mica 4x4
    Snugtop SuperSport
    29 lbs. it's posted on the page before this.
  19. Nov 7, 2013 at 10:40 AM
    #179
    AR15xAR10
    Thank you. I just assumed since the first post wasn't updated with the information....that i'd just ask. Lol thanks again!
  20. Nov 23, 2013 at 5:43 AM
    #180
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    Thought this might be useful to the thread.
    guidoStow, SmileyGuy and gipsyfetus like this.
