WHEEL SPEED SENSOR RELOCATION
Discussion in '3rd Gen. Tacomas (2016-2023)' started by youngster77, Jan 11, 2022.
  1. Jan 11, 2022 at 4:11 PM
    youngster77
    youngster77 [OP] Well-Known Member
    2017 TRD OFF-ROAD
    Swapping out the stock rear end for a Currie full floater in my pre-runner.
    Looking for a wheel speed sensor relocation kit (reluctor ring with pick up or something of that nature) to run either off the tail shaft of the T case or pick up from actual T case. The 3rd Gens do not have a pick up in the T case like how the gen2s have a boss you can drill and tap to locate a pick up sensor. There is a kit available that has a reluctor ring and pick up that bolts to the yoke of the diff, but we are trying not to go that route since this is a desert truck and will most likely get ripped off in that location.
    Or... will a gen2 and gen3 T-case swap with each other? If they do, we can drill and tap the 2nd gen T-case for pick up and swap them. TIA!!!
  2. Jan 11, 2022 at 4:21 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    sheeesh
    Anton338 likes this.
  3. Jan 11, 2022 at 4:28 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    The issue is, the system is looking for wheel speed. It's programed for it. If the system sees the speed before the gears, that is gonna mess things up. Your best bet it to have something made to compensate for the gear ratio. This might have to be a custom part for you to build.
  4. Jan 11, 2022 at 4:34 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    The stock speed sensor is before the gears anyway?
  5. Jan 11, 2022 at 4:50 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    What if you tie it to the front wheels just to give it the same signal? You'd loose or potentially really screw up if ABS tries to kick in but that may be one way to give the signal. I have never tried this or seen it done but one way to test wheel speed sensors/wiring is to jumper the sides.
    That's quite the terminator-like setup you got there...
  6. Jan 11, 2022 at 5:03 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    The 3rd gen takes the speed signal off the ABS.
    I also believe the 2nd gen for a good number of it's production years does as well.
  7. Jan 11, 2022 at 5:15 PM
    Anton338
    Anton338 Ill-Known Member
    Anton
    New Jersey
    2018 TRD Off-Road DCSB
    Mostly electrical shit that nobody cares about.
    Oh come on, you can fit a third caliper in there, man. I believe in you.
  8. Jan 11, 2022 at 5:18 PM
    youngster77
    2017 TRD OFF-ROAD
    For reference, my ABS has been gone ever since I installed a long travel race Kit up front. No issues aside from Christmas tree lights on the dash but the concern now is not being able to engage into four-wheel drive when swapping out the stock rear end.
    My build on IG @thatblackyota
