Wheel Spin Sensor w/ Ovesize Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ritewayco, Sep 29, 2009.
  1. Sep 29, 2009 at 3:41 PM
    ritewayco
    ritewayco [OP] Member
    09 Tacoma Double Cab 4x4 TRD Off-Road
    3 inch Procomp Coil Over. 2 inch add-a-leaf and block in the rear
    I have a 2009 Tacoma DC with a 3 inch lift and 285/75/16, and when I take a corner at moderate speeds the outside wheel brake pulses to slow down the rotation. Has anybody experienced issues with the wheel speed sensors and oversize tires?
  2. Sep 29, 2009 at 4:04 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    maybe you should take your traction control off and give it a try if you haven't tried that
  3. Sep 29, 2009 at 4:14 PM
    TACOFEAVER
    TACOFEAVER Well-Known Member
    Newfoundland, Canada
    09 SR5
    3" lift, and 265 75 R16 Trxus M/T's enroute. (to be installed in about 2 weeks)
    only when raining, and too much skinny pedal!:D:D
  4. Sep 29, 2009 at 5:32 PM
    Allens_Piece
    Allens_Piece Well-Known Member
    Anchorage Alaska
    09 4XTRD Dbl Cab
    Wheels/tires 3" Toytek coilover w/ OME rear springs (no blocks) Billstien shocks, K&N CAI, TRD Exhaust.
    Cant turn the Traction off in the f-ing 09's. as soon as you go over 25 it kicks in even after you pushed the button to turn it off. Also if the vehicle is turning, or otherwise not going straight, the vehicle will apply braking or prevent acceleration until the vehicle thinks its back on track. I've been to the dealer to find out how the hell im supposed to do donuts in the parkinglots with out the truck flipping out on me... They said it cant be turned off untill your in 4-hi, or 4 low. i forget now... Maybe they lied cause they didnt know, but i have been unsuccessful in trying to turn the f-er off.
  5. Sep 29, 2009 at 5:52 PM
    DaGMEN
    DaGMEN Member
    I've had my lift 3 months now and the vsc has engaged in a corner only two times. Both times going about 45mph around a 35mph curve. I've heard that the vsc needs to be re-calibrated after lift and tires(i have 3" with 285/70/17) but I have not heard if anyone has had any success with getting the dealership to do it. I haven't talked to the dealership about it yet.
  6. Sep 29, 2009 at 6:41 PM
    krimson
    krimson Nothin
    TRD Off Road
    yeah you should bring it to the dealer, thats what i would do.
  7. Sep 29, 2009 at 8:17 PM
    ritewayco
    I am discussing with the dealer to see if they will adjust the VSC system and re-calibrate the speedometer. It is not looking very likely that the dealer will touch the system.
  8. Sep 29, 2009 at 9:57 PM
    fishshooter
    fishshooter Well-Known Member
    Northwest Florida
    09 Super White TRD Off Road 4X4
    Stock
    The dealer doesn't know what he is talking about. With the vehicle stopped, press and hold the VSC off button for about 5 seconds. TRAC, VSC, and ALSD will all turn off and not come back on until you either hit the button again or turn the truck off. If you just press the button, you get ALSD on, TRAC off, until you get up to around 30 MPH, then TRAC comes back on. That is in the owner's manual. Also, TRAC/VSC is "on" in 4hi and you have to go through the same process to turn it off. That is not so clear in the manual, but that is how it works. Turning TRAC completely off in 2wd or 4hi will result in NO traction control,brake modulation, or throttle interference, so you can cut donuts like a mad man.
  9. Sep 30, 2009 at 6:13 PM
    Cryer
    Cryer O shizzle!
    Bryan, Tx
    '11 Tacoma TRD Sport
    3" lift
    yeah while at a complete stop, hold the button for 3-5 seconds. turns off..
    on another note, is there a way you can hardwire in a switch that you dont have to hold? just flip it and poof
  10. Oct 1, 2009 at 9:48 PM
    Allens_Piece
    Anchorage Alaska
    09 4XTRD Dbl Cab
    Holy Shit... This is exactly why I love this forum. Thank you!!! You just made my 06 for 09 swap worth it!!! Really. I dont know how to rep you, but someone needs to.
    :cheers:
  11. Oct 2, 2009 at 9:52 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    not sure if this is the issue, but some have said that VSC needed to be recalibrated after lifts...mainly 6", but who knows. could b something to look into at the dealer. on that note i have a 3" and 285/75/16 and i dont have that issue
