Wheel stuck on left rear
Discussion in 'Wheels & Tires' started by kneisska, Nov 6, 2011.
  1. Nov 6, 2011 at 3:31 PM
    kneisska
    kneisska [OP] Member
    Karl
    St. Paul, MN
    09 TRD Off Road
    Seat belt beep turned off
    Hi all. Brand new here. I'm trying to do a bit more DIY to save some $ and rotating my tires fit my DIY capabilities. Mind you I'm no mechanic, I ran into a problem that could be dire in an emergency situation. Had truck on jack stands, front left whell popped off no prob. Rear wheel stuck. I've tried loosening lugs, dropped truck and rolled back: no go. Tried mule kicking the shit out of it...to no avail. How do I get the bastard off?
    JKU3000 likes this.
  2. Nov 6, 2011 at 5:08 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Get a fat man to mule kick the fucker
  3. Nov 6, 2011 at 5:11 PM
    98tacoma27
    Ben
    Not Beech Creek
    Large rubber mallet or bigger mule
    Sometimes you just have to beat the piss out of them
  4. Nov 6, 2011 at 5:13 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    try humping it
    or a pry bar helps, alot
    cosmic65charlie likes this.
  5. Nov 6, 2011 at 5:18 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    im assuming the lugs dont spin at all. i couldnt get my lug nuts to spin off ALL the way. they were stripped. doesnt sound like that is the problem though. just thought id mention it.
  6. Nov 6, 2011 at 5:19 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    oh lugs are stuck, try soaking with a penetrating oil and getting back to em tomorrow
  7. Nov 6, 2011 at 5:19 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    My first gen pulled this once upon a time. Beat the hell outta it. Assuming that the lugs are all off and the wheel is just stuck to the rear drum, thats what happened to mine.
  8. Nov 6, 2011 at 6:25 PM
    kneisska
    Karl
    St. Paul, MN
    09 TRD Off Road
    Nope, the lugs are all off. I have this feeling like I'm forgetting something simple. There are no locking lug nuts...like I said they are all off. Is there some kind of security hub? Maybe not a hub, but some kind of cap or washer thing? It looked a bit different than the front wheel...I'll take some pics if you'd need clarification. Thanks for the responses everyone.
  9. Nov 6, 2011 at 6:29 PM
    especk
    Erik
    Redding, CA
    o all the lug nuts are off huh. usually a little rocking of the tire back and forth will get it loose. im not sure whats keeping it bound so tight.
  10. Nov 6, 2011 at 6:34 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    In my case the wheel was put on by the dealership the day before I received the flat that inspired me to remove my wheel. Once the lugs were off I couldn't pull the wheel off. I was on a construction site, I used a Backhoe to hold the truck up, got underneath and hit it with a hammer, pryed on it with a bar, even hit it with some skids. None of that worked I called the dealership and raised 7 kinds of hell. Ended up using the tractor to pull it off using a strap while it was attached to the back hoe. Went home and had them pull the other wheels off and of course the others came off with ease. However the pass rear drum had the marks where the wheel had been stuck previously. No explanation was ever reached just a freak occurrence. You can try jacking the truck up and droping it quickly with a floor jack. Be very careful, put some lugs on half way or better before trying this.
  11. Nov 6, 2011 at 9:34 PM
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    Drift and hit a curb, itl pop right off.
    Soak the front of the drum in wd40, then assuming the truck is on solid jack stands, go under the truck and boot the tire.
    If that doesn't work park on a sidewalk with a full curb, jack up your truck a couple inches. Put a scissor jack in between the curb and the inside of the tire and pop it off.
    Just a couple options
  12. Nov 7, 2011 at 8:10 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I like this curb idea! I don't have many here but if I'm in the cities i'll remember this.
  13. Nov 8, 2011 at 10:26 AM
    wesrunner
    wesrunner Gang Gang
    Wes
    Louisiana
    It's paid for.
    a buncha fuckin toyotas
    I read on here that the rear wheels tend to get corroded to the drums. Beat the hell out of it and put never seize on the back of the rim when you put it back.
  14. Nov 8, 2011 at 10:29 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    interesting.... never had this problem, interested in the outcome
  15. Nov 9, 2011 at 2:04 PM
    kneisska
    Karl
    St. Paul, MN
    09 TRD Off Road
    Ok, well this is how it worked. I lucked out and got a free tire rotate coupon in the mail from my favorite local garage. What timing!
    Anyhow, just so I could post some kind of conclusion, I asked the tech how the heck they get these stuck wheels off. He said once it's on their lift, they use a pry bar from behind the tire to pop it off.
    He said by no means should you ever kick a wheel from behind when it's on a jack (as you will have three outcomes, one will be deadly). He didn't recommend using a sledge hammer to the side wall because you can damage your wheel (if you miss) or your tire (create a bulge). So those of us without lifts have to take chances I guess.
    I dunno what I would have done if I had a flat and my wheel was stuck. I suppose carry a pry bar...anyone have any good ideas where to mount a pry bar in a taco so it's not in the way or rolling around the bed?
    Hope this post helps anyone in the future..
    :drunk:
  16. Nov 9, 2011 at 2:05 PM
    97yota4wd
    Eric
    Mesa, AZ
    i would have used a rubber mallet on the inside of the wheel. and beat the flying fuck out of it.
    glad you got it figured out though
  17. Mar 23, 2020 at 5:05 PM
    CaeTzar
    CaeTzar New Member
    06 double cab 4l standard
    In case anyone is still having an issue still....
    I hadn't rotated in a couple of years, kept outside. Don't drive many kms so no need to. Rust from drum and corrosion from aluminum wheel made quite the glue.
    I tried the above, here's what got it off without getting under it.
    Wd40 soak, then pound on wheel (with 10lb sledge using a towel and wood to protect finish) in a rotational direction to break the fused rust a bit. Then a 5 foot digging bar to pry between tire and leaf spring (watch you don't pinch brake lines). Front side then back switching a dozen times. Finally popped off and I fell on my ass. Ass pad recommended.
  18. Mar 24, 2020 at 7:16 AM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    When I changed out my winter wheels with my summers about 2 weeks ago all mine where stuck and just used a pry bar to get them off.
  19. Mar 24, 2020 at 7:18 AM
    81shark
    81shark Well-Known Member
    i kick and use a rubber mallet. thankfully, it only happened on the woman's old car
  20. Mar 24, 2020 at 7:19 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Next time use a dead blow hammer on the inner lip of the wheel. Beat it outwards as you rotate the wheel.
