Wheel stud failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 5layerTaco546, Mar 22, 2020.
  1. Mar 24, 2020 at 8:09 AM
    #141
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    After seeing the new pic, I'm the opposite.
    I'm seeing it starting at the ratcheting marks at the top, propagating to beach marks in the middle and final rapid fracture at the dark spot.
    Fatigue failure...
  2. Mar 24, 2020 at 8:11 AM
    #142
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Really effective technique. (Only issue is that it is dependent on bolt length, short bolt few flats, long bolt more flats, and the modulus of the clamped parts)
  3. Mar 24, 2020 at 8:59 AM
    #143
    splitbolt
    NW Arkansas
    Turn-of-nut and fastener elongation are two different methods.
    Turn-of-nut is +/- 15% accurate.
    Fastener elongation is +/- 5% accurate
  4. Mar 24, 2020 at 10:10 AM
    #144
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I thought I read a lot of posts here that started doing their own rotation after the dealer provided services and experienced broken studs. I think you may need to adjust to include dealer too (I mean we know they dont torque shit right). I can only imagine after so many on/off with the impact that it’s a matter of time I guess.
    I know I check after them and find loose and over torque lugs and I use a torque wrench anytime the wheels come off
  5. Mar 24, 2020 at 11:40 AM
    #145
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I would expect the dark spot to be where corrosion started. Usually, the "brighter" spots are the newest failures.
    I'm not an expert in this, but the few failures I've had examined, that's the general rule of thumb that I get out of the results.
  6. Mar 24, 2020 at 11:46 AM
    #146
    Woodrow F Call
    Colorful Colorado
    Sure because you are breaking 360 degrees into 6 equal segments. I've actually seen nuts with more markings than the number of flats.... I think 4 per flat. Even then, you could just break the nut down into 360 degrees or even finer for more precision. It's still a number of threads per inch (or pitch if going metric). You can still back out what you need.
    But yes, elongation is the best measurement and in reality, all the methods used are to determine some type of elongation even if approximate. Bolt stretch is the whole point of a fastened joint. Have enough bolt stretch so that it doesn't loosen, but not too much that the bolt yields.
  7. Mar 24, 2020 at 11:53 AM
    #147
    splitbolt
    NW Arkansas
    Strain gauges are +/- 1% accurate.
  8. Mar 24, 2020 at 11:57 AM
    #148
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Breaker bar operator error .
  9. Mar 24, 2020 at 12:16 PM
    #149
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    OK, you guys made me go out and make sure all my lug nuts were there. They are so now I have peace of mind. :thumbsup:
  10. Mar 24, 2020 at 12:43 PM
    #150
    Woodrow F Call
    Colorful Colorado
    How do you put one on a bolt/stud? maybe one with a hollow center?
  11. Mar 24, 2020 at 12:48 PM
    #151
    splitbolt
    NW Arkansas
    Yeah, you have to modify.
    They seemed to be used more for testing and calibration, than actual application.
  12. Mar 24, 2020 at 1:42 PM
    #152
    Woodrow F Call
    Colorful Colorado
    On those GE turbines I mentioned earlier. The big studs were actually hollowed out so you could use a heating element to "lengthen" the bolts. Then you could just turn the nuts the appropriate number of flats and once it cooled down you had the stretch. You might could stick a strain gauge in something like that, but you'd have to tighten without the heat.... hydraulic wrenches or hammer wrenches only then.
    Anyways, I guess we're way off topic.
    Rottencotton likes this.
  13. Mar 24, 2020 at 2:09 PM
    #153
    Rottencotton
    Stinkin Rincon
    Interesting.
  14. Mar 26, 2020 at 7:36 PM
    #154
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    aint like a few have collapsed
    fallen over the last year
  15. Mar 26, 2020 at 7:37 PM
    #155
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Those were pins and sleeves. And the goofballs pulled all the pins ~300' up, u NEVER do that. Wind came through and did the rest
  16. Mar 26, 2020 at 7:41 PM
    #156
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Update, I finally replaced my broken lug stud after 6 months.....
  17. Mar 26, 2020 at 7:51 PM
    #157
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Same with cranes, kinda. U have a hydraulic head that threads onto the top of the stud, then stretches to ~200 bar then u run the nut down my "hand". Scary when u don't count the number of threads and she pops off the top.
  18. Mar 26, 2020 at 9:06 PM
    #158
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    Wooo!!
    Skydvrr likes this.
  19. Mar 27, 2020 at 2:12 AM
    #159
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    Was it overtightened?
  20. Mar 27, 2020 at 9:28 AM
    #160
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Using a breaker bar on lug nuts is a no no,use a torque wrench.
    abodyjoe likes this.
