Wheel studs breaking off
Discussion in 'Wheels & Tires' started by Oreo Cat, Nov 26, 2020.
  1. Nov 28, 2020 at 8:51 AM
    Oreo Cat
    Oreo Cat [OP] Worst Member
    Coeur d’Alene, Idaho
    Even if it goes over the hub before the wheel goes on?
  2. Nov 28, 2020 at 10:00 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    It is decorative.
    Only time it could pose a problem is with incorrect install and not seated correctly. This would act to prevent the wheel from seating against the hub.
    This would be obvious when tightening the lug nuts.
    Your pic of the wheel with the broken studs is without the center cap....that is unlikely the cause.
  3. Nov 28, 2020 at 11:59 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Were they just the tuner (conical) type, or extended thread?
  4. Nov 30, 2020 at 1:57 PM
    Oreo Cat
    I replaced all the studs and torqued the wheels down to 83lbs and 2 more Broke off
    :mad:
  5. Nov 30, 2020 at 2:12 PM
    Knute
    Ok....when did the last 2 break? At torque down or after driving?
    I assume you confirmed the studs were fully and squarely seated.
  6. Nov 30, 2020 at 2:18 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    buy some arp studs, save your self the headache of breaking cheap ones
  7. Nov 30, 2020 at 2:43 PM
    Oreo Cat
    Driving
  8. Nov 30, 2020 at 2:46 PM
    Xplosiv
    Xplosiv Well-Known Member
    Jeff
    Lewisville, TX
    2021 OR DCSB Black 99 Corvette FRC
    265/75/16 AT's, Cali Raised Sliders, BAMF RTT Rack
    Sounds like you have a hub issue if you replaced them with correct torque and they are breaking again. Either the wheel seat is warped, or something on the axle end is causing the wheel not to seat correctly.
    Knute likes this.
  9. Nov 30, 2020 at 6:49 PM
    Knute
    Agreed. Something is causing the studs to be overstressed leading to early failure.
    Suggest to replace the 2 broken studs, try running the spare wheel at that location.
    If the studs break again, then the issue is likely in the hub or axle.
    It the studs don't break, then the issue is in the wheel.
    Over torque has been eliminated as a potential cause.
    Or you could take the truck to a mechanic who specializes in suspension to explain the symptom and what was tried to isolate the problem.
  10. Nov 30, 2020 at 6:53 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Is your torque wrench calibrated?
  11. Nov 30, 2020 at 9:03 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Hard to see...are the lug seats chewed up on one side?
  12. Aug 20, 2021 at 2:56 AM
    Lautzofdirt
    Lautzofdirt New Member
    Greg
    '06 Tacoma 4x4 TRD Offroad DCSB
    Wheels and tires so far
    On my 2006 crew cab 4-wheel drive short bed, I have had 5 lug nuts break off on my right front wheel at almost 80 miles an hour, had four of them break off at about 70 miles an hour and had 3 break off today at 65 miles an hour on the front left wheel. When I pulled off the freeway, one of the Lugnuts was loose enough that I could take it off by hand but the stud was not broken off yet. After comparing the lug nut the tire shop provided with my wheels and tires, I've determined that I have only 3/16 to maybe one quarter of an inch penetration through my wheel on to the actual wheel stud. I had previously purchased aftermarket lug nuts just in case I lost some while I was driving and when I attempted to compare a to b the aftermarket auto parts store style would have easily had at least one half inch of penetration on to the stud. After almost crashing and possibly dying multiple times in this vehicle that I've Loved otherwise, I'm considering contacting an attorney for negligence and oversight because the same Tire company has serviced the wheels multiple times over the years and no one has ever said anything or paid any attention to this oversight of their materials sold to me and installed on my vehicle
