Wheel/Tire Combo
Discussion in 'Wheels & Tires' started by usmcmax, Feb 23, 2013.
  1. Feb 23, 2013 at 11:50 AM
    usmcmax
    usmcmax [OP] Well-Known Member
    Andrew
    Okinawa/Virginia
    None yet.
    Before I pull the trigger I want to run these numbers past the pro's. I am going to do 5100's with 1.75" front and no lift to the rear. I want to put the kmc enduro's with nitto terra grappler on.
    For the wheel: 16 X 9, 6x139.7 OS: -12mm BS: 4.53"
    Tires:LT265/75R16
    Will someone please look this over and make sure I'm not completely screwed up. Thanks, your help is much appreciated.
    Andrew
  2. Feb 23, 2013 at 8:44 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    The wheels specs look fine to me. You'll probably need to trim some plastic, remove your mud flaps, and I recommend you do the CMC mod if you off-road at all. Also, check the specs on your tires to make sure that particular size is approved for a 9" wheel.
