Wheel/Tire question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 24-7, Aug 3, 2018.
  1. Aug 3, 2018 at 10:53 AM
    24-7 [OP] Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    Hello everyone. My Tacoma is my first vehicle with the sensors in the tires. Soon i'll be putting ko2s on my stock wheels. What happens with the valve stems and sensors? Can they be reused or do I need new ones?
    Thank you
    Phil
  2. Aug 3, 2018 at 10:55 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    The sensors are attached to the wheels so there should be no problem.
  3. Aug 3, 2018 at 10:56 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Sensors will just stay in the wheel and be reused when you get new tires.
  4. Aug 3, 2018 at 10:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    There is a 'refresh kit' that many places will require you to use. Like Costco is about $3/per. It provides a new mounting gasket and such. Not bad to have if there are a lot of miles/age. But on a new vehicle your installer should let you take a pass.
  5. Aug 3, 2018 at 11:02 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    What size are you going to get?
  6. Aug 3, 2018 at 11:05 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Sensors should last at least 6 years if not longer. The ones on our '06 4Runner were still working when I got new tires a couple months ago, but I had new sensors put on anyway (the battery lasted 9 years as well, must be doing something right). As Billy said, not a bad idea to refresh the gaskets, though.
  7. Aug 3, 2018 at 11:47 AM
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Stock
  8. Aug 3, 2018 at 11:48 AM
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Are the valve stems attached to the sensors?
  9. Aug 3, 2018 at 11:49 AM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    Yes. I believe they are. Regardless, you can use the existing sensors with the new tires. The tire shop should be able to take care of everything.
  10. Aug 3, 2018 at 11:50 AM
    jmauvais
    NorCal
    ...stuff
    You can get one inch bigger without lift or anything.
  11. Aug 3, 2018 at 11:54 AM
    shakerhood
    Southern Ohio
    Yes, the valve stem is part of the sensor
  12. Aug 3, 2018 at 11:58 AM
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Okay thanks everyone for you help.
    boynoyce and shakerhood like this.
