Wheel & tire setup on 17 SR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bperson01, Oct 20, 2024.
  1. Oct 20, 2024 at 8:14 AM
    bperson01
    bperson01 [OP] New Member
    Hello All- I have a very stock 2017 SR double cab that I'd like to switch-up the wheels and tires. Currently have stock 16" steel rims, and from what I've read and researched, I'd should be able to move up to 17" PTR20-35110-G4 Gloss Gunmetal gray wheels. Can anyone confirm my thinking I could run 265/70/17 tires without any issue or lifting? Also, is it accurate that I'd need mag style lugs and new TPMS? Thanks for the help for a noob!
    Tocamo likes this.
  2. Oct 20, 2024 at 2:16 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Can confirm will fit, no issue. Can't confirm about needing mag style lugs & TPMS
  3. Oct 21, 2024 at 4:03 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    If you have the steel wheels you will need new lugs and TPMS sensors.
  4. Oct 21, 2024 at 6:40 AM
    bperson01
    Thanks for the replies so far! Any recommendations on lug nuts, or just any aftermarket M12x1.5 mag seat?
  5. Oct 22, 2024 at 2:23 AM
    VaToy
    Parts Unknown
    Whatever you loke as long as they fit
  6. Oct 22, 2024 at 3:26 AM
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    TPMS sensors are up to you. I took the ones in my steel wheels and installed them in my new wheels which are on the Tacoma most of the year. When I swap out wheels for winter driving I am able to ignore the TPMS light on the dash. I've read where some guys cover it up with a piece of tape. I just ignore it seeing what replacements cost.
    Tire clearance can sometimes be an issue. When my larger wheels get turned hard while in reverse they do rub slightly once in awhile in the wheel well and I did remove my front air dam completely, No difference in MPGs. Been running the same set up on my 17 SR extended cab since new. No lift installed.
    bperson01[OP] likes this.
  7. Oct 22, 2024 at 7:08 PM
    Muddy Duck
    Muddy Duck Well-Known Member
    Is the 265/70R17 a common replacement for the OEM 16” wheels? I am currently running on 265/70R17. I have a concern that they may wear out the brake faster and they are burning up about 10% more gas. They sure look good though.
    Are my concerns valid?
  8. Oct 23, 2024 at 5:08 PM
    bperson01
    I really appreciate all this discussion and advice. I think I'll give the OEM steel TPMS a shot (with the 180 degree rotation that I've read about)...to start with, anyhow. Going from 16" steel wheels to the 17" TRDs, I know mag style lugs are needed (not acorn), but do they need to be a longer/taller style, or the standard 1.47" tall?
