Wheel/Tire Sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cl251, Mar 27, 2022.
  1. Mar 27, 2022 at 8:01 AM
    cl251
    cl251 [OP] Well-Known Member
    New jersey
    2010 Silver Tacoma TRD Sport
    3in Bilstein lift w ucas 17x9 Falcon Wheels and 35s Viper cut Stereo upgrade Lighting
    Hello, I recently have been driving and started hearing a roaring sound coming from my front driver side wheel area almost sounds like i put new mud terrain tires on. I immediately thought it was a bad wheel bearing but I checked everything, jacked it up the wheel had no play at all, it doesn’t vibrate when i drive, it doesn’t pull in either direction, and also doesn’t change tone when turning. It just gets louder the faster i go. I also checked the cv which had very minimal/normal play from the inner side of the axle. Can anyone think of anything that it could be before I take it somewhere? Any help would be great. Thanks!
  2. Mar 27, 2022 at 8:05 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Lift the front of the truck and spin each wheel by hand while holding the knuckle. Any roughness felt through the knuckle is a bad bearing. It should be smooth and quiet. Compare side to side. The louder side is the bad bearing
    TnShooter, XSplicer62 and photogr4x4 like this.
  3. Mar 27, 2022 at 9:31 AM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    Agreed. My driver's side started making a similar noise and I assumed it was the needle bearing so I bought an ECGS bushing. While that *might* have been part of the problem, the wheel bearing was failing and a new CV axle fixed it.
    TRDSport10 likes this.
  4. Mar 27, 2022 at 9:36 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    How many miles do you have? My 04 4runner was doing this last year and turned out to be a worn wheel bearing. It had about 150k on it then.
  5. Mar 27, 2022 at 9:39 AM
    cl251
    New jersey
    I have 41k. I live in jersey with a lot of salt but it still seems early for a wheel bearing to go
  6. Mar 27, 2022 at 9:41 AM
    boostedka
    James
    NM
    Yeah I would agree with that.
  7. Mar 29, 2022 at 11:33 AM
    cl251
    New jersey
    Thanks for the response. I just did this and I don’t feel anything or hear anything on either side. I have absolutely no idea what it could be
  8. Mar 29, 2022 at 11:39 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I also confirm that these trucks are notoriously hard to diagnose bearing doing the “grab and rock” method.
    @b_r_o method is about the best.
    What most don’t realize is the wheel/bearing isn’t under load. So it doesn’t respond the same when jacked up with no load on it. The fact the the CV is turning at the same time doesn’t help either.
  9. Mar 29, 2022 at 12:26 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yea it can be very subtle too, not always going to feel the roughness
    Might be something else causing the noise
    TnShooter likes this.
  10. Mar 29, 2022 at 2:39 PM
    Goldwrench
    Goldwrench Well-Known Member
    2010 silver 4wd access taco
    Bought used and mild lift
    Drive at speed you hear noise. Tune in on it. Quickly swerve left and then back straight. Swerve quickly right. Ok. If noise abated on left swerve, almost guaranteed bad wheel bearing on left.
  11. Mar 29, 2022 at 2:48 PM
    cl251
    New jersey
    I tested that out too. Swerved both ways at neighborhood and highway speeds. Both times there wasn’t any change when turning any direction.
    Goldwrench[QUOTED] likes this.
