Wheel & Tires question.
Discussion in 'Wheels & Tires' started by wing103, Aug 3, 2011.
  1. Aug 3, 2011 at 7:18 AM
    wing103
    wing103 [OP] Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
  2. Aug 3, 2011 at 9:53 AM
    wing103
    Boston
    I find the right one, with 6x5.5", but the offset is -12, is it the wheel will stick out
  3. Aug 3, 2011 at 10:08 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    The -12mm 17x9 with 6x5.5 bolt pattern is the one you want. Depending on the tire you choose. It will stick out 1-2". Your stock factory dunlops might be too skinny for a 9" wide wheel.
  4. Aug 3, 2011 at 10:17 AM
    wing103
    Boston
  5. Aug 3, 2011 at 10:22 AM
    TacoSupreem
    Hayden
    Kentucky
    Those will work. You might have to buy new tires though.
  6. Aug 3, 2011 at 2:16 PM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    i put the dunlops back on my new wheels and it made the sidewalls appear rounder in that makes any sense. they are a 16x8 inch wheel. -6 offset. the tires stick out an inch or two out of the wheel wells....hope that helps you
