Wheel & Tires Size Issue: I need your advice!
Discussion in 'Wheels & Tires' started by Flynn Diesel, Feb 4, 2010.
  1. Feb 4, 2010 at 11:24 AM
    Flynn Diesel
    Flynn Diesel [OP] Well-Known Member
    Phoenix, AZ
    2010 PreRunner SR5 Double Cab
    •BFG AT KO 285/70/17, XD Addict 17x9, Light Racing UCA’s, Billstein 5100’s, OME 885’s, Toytec AAL, Seat Belt warning disable, Grill Craft Black MX Upper & Lower Grill, VisionX 55/65 watt xenon Low/High Beam lights. FOG Light only Mod. Tailgate theft prevention mod. Wet Okole armrest mod. Redline Hood Struts, Weathertech floor liners. AMP Bed Extender. Wet Okole Seat Covers. Pioneer P4200DVD
    I am looking at this set-up for my 2010 DC PreRunner 4x2. I just received my 5100's which I plan on setting at 2.5 on all 4 corners. Does anyone see any issues with the wheel & tire spec listed below. I plan on removing the mud flaps but other than that I do not want to do any cutting or trimming. Any feedback would be greatly appreciated.
    Xtreme Alloys Series 7189 Black Finish
    Part Number: PXA7189-6883
    · 16x8, 6 on 5.5 Bolt Pattern
    · Backspace = 4.5 in.
    · Max Load = 2200lbs
    · Finish = Flat Black
    · Hub Centric = No
    · Offset = 0mm
    LT285/75R16, BFGoodrich All-Terrain T/A KO
    o Load Range D
    o Max Load 3305
    o Tread Depth 17/32
    o Overall diameter 33.0 inches
    o Raised White Letters
  2. Feb 4, 2010 at 11:32 AM
    CAMZTRD
    CAMZTRD Well-Known Member
    steve
    hampton, va
    2006 DC TRD Off-Road 4x4
    billy 5100's @ 2.5 w/ 1/4 spacers, toytec aal, LR UCA's, revotec headlights,revotec taillights, lamin-x fogs, color matched grille and rear bumper, undercover, bed-extender, black nerf bars, scan gaugeII , afe drop in, 50 series flowmaster, 6000k bi-xenon hids, more to come.......
    wheel specs look fine..and only the front struts are adjustable..you will need an aal or block for the rear to level it out...the 285's will not fit unless you trim your inner fender wells, and you will still rub your cab mounts at full lock...
  3. Feb 4, 2010 at 11:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    And possibly a body mount chop/box.
  4. Feb 4, 2010 at 11:38 AM
    Flynn Diesel
    Phoenix, AZ
  5. Feb 4, 2010 at 11:48 AM
    CAMZTRD
    steve
    hampton, va
    yes, you would have no issues with that size.
  6. Feb 4, 2010 at 3:03 PM
    Flynn Diesel
    Phoenix, AZ
    Any other suggestions before I make the move?
  7. Feb 4, 2010 at 8:32 PM
    Quakee
    Quakee Well-Known Member
    Eddie
    (LA) Tujunga, CA
    2010 TRD Off-Road 4x4
    Toytec ultimate lift kit, Total Chaos UCAs, spidertrax spacers, mudflaps removed, 4wd badge where "prerunner" usually goes, wicked flow 13" muffler, sound ordnance b-8pt sub-woofer.
    instead of a 275/70 why not go with a taller 265/75?
  8. Feb 5, 2010 at 6:20 AM
    Flynn Diesel
    Phoenix, AZ
    then the tire would look skinnier, right?
