Wheel to wheel Running boards for Access cab! ARGH!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Janster, Sep 18, 2008.
  1. Sep 25, 2008 at 7:17 AM
    Janster
    Janster [OP] Old & Forgetful
    Jandy
    Lancaster, PA
    Awesome gang!!
    I'll give it a try!!
    (just time permitting of course)
    Thankyou for the help!!!
  2. Oct 5, 2008 at 10:05 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
  3. Sep 2, 2009 at 4:15 AM
    Janster
    Jandy
    Lancaster, PA
    I forgot this thread existed...been a while.
    I just picked up a set of Toyota double cab running boards from another member (Brad -pataco). Thanks Brad! Great meeting you!
    The total length looks awesome (when holding them up). At first glance, I'm really positive about being able to make these work. But - I haven't started working on things yet and I'm crossing my fingers.
    Anyone know the bolt size for the mounting holes in the body? I'm sure I can do a few test fits, I've got plenty of bolts lying around the garage. Just thought if anyone knew off the top of their head. THANKS!
  4. Sep 2, 2009 at 4:45 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Looks like you're well on your way to building what you want but if things go south, check out Avid Offroad who is building the Arctic bull bar. I just ordered a set of nerfs for my truck from Brandon and awaiting delivery. We'll see what they look like soon enough but I know he would build anything you want. He does great work and has great prices! Good luck!
  5. Oct 26, 2009 at 2:46 PM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    I too am interested in doing this. I found your write-up link at Toyota Nation, great job by the way.
    Just to clarify, Did you have to shorten the double cab running boards?
    I see where you relocated the brackets, but I assumed the double cab boards would be too long and have to be cut. (unless now that you are going to the rear wheel they fit).
    I plan on probably buying a new set, so just want to be sure before I order them.
    Thanks
    Shawn
  6. Oct 26, 2009 at 10:33 PM
    Janster
    Jandy
    Lancaster, PA
    No cutting....what you see in the pictures, is what the double cab running boards are sized at. It's a perfect fit from wheel to wheel. You only need to relocate the bracket and drill 2 holes.
    Just be careful stepping on that backside where there's no support.
    Good luck!
  7. May 7, 2010 at 9:12 AM
    dj_jazzy
    dj_jazzy Member
    2024 Limited
    I hear your pain... I've searched high and low and you can find the wheel to wheel for Tundra... but not Tacoma. What's up with that !
    You are not alone. It's very annoying.
