Wheel turning clunk/Pop sound?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fore, Dec 11, 2010.
  1. Dec 11, 2010 at 9:53 AM
    Fore
    Fore [OP] Well-Known Member
    07 PreRunner
    Tried searching for this can't find anything. The weather here in VA has been getting colder, I'm starting to notice a loud clunk/pop sound when making extreme slow right and left turns out of a parking space or when rein-acting the sound at a stand still while turning the steering wheel left to right. Seems to be coming from the front wheel area just below or near the top of the front shock area. Seems to be a part of the wheel steering mechanism. Does anyone know what this could be and possibly how to fix this? I have an automatic 2007 Prerunner 2WD, V6
    Thanks~:confused:
  2. Dec 11, 2010 at 9:57 AM
    elblako91
    elblako91 Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
    Hmm it could be your steering stops. Look under you truck and check your steering stops. Does it do it when you max out your turning on your steering? Does it do it when steering is maxed out and you go over a bump?
  3. Dec 11, 2010 at 10:16 AM
    Fore
    07 PreRunner
    Not sure what you mean by steering stops? Can you post a picture or illustration? It doesn't happen when I go over any bumps just happens when I backing out of a parking spot and making a extreme steering wheel turn then straighting the wheel to drive away. It also happens when I ask my wife to turn the steering wheel slowly left to right at a stand still. This truck does not go off roading of any kind.
  4. Dec 11, 2010 at 10:21 AM
    elblako91
    Blake
    1992 Toyo Pickup
    Here's a picture of a steering stop. This person put grease on the steering stop and on the lower control arm.
    Uploaded with ImageShack.us
    Are you turning the wheels while the vehicle is not moving?
  5. Dec 11, 2010 at 10:43 AM
    Fore
    07 PreRunner
    Thanks for the pic. Yes, that is what is puzzling me. The "steering stops" make sense on extreme wheel turns like maybe a U-turn or something, but this is also happening at a stand still too while rein-acting a turn. I could even make the clunk sound when I roll down the drivers side window and stand out of the truck and turn the wheel myself with one hand to the left while watching the front tire turn on the pavement. I would also add that with one hand I doubt whether I'm turning the wheel all the way left before it makes the loud clunk/pop sound.
  6. Dec 11, 2010 at 10:51 AM
    elblako91
    Blake
    1992 Toyo Pickup
    yeah it's not the steering stops if your turning the wheels while the trucks at a stand still. Maybe you could get under the truck and get someone to turn the wheel while you look under to see if you can see or hear from where it's coming from?
  7. Dec 11, 2010 at 10:53 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Does it happen when going straight and applying the breaks?
  8. Dec 11, 2010 at 11:06 AM
    Fore
    07 PreRunner
    No only when turning out of a parking lot stall or turning the wheel left then right at a stand still. I did look underneath while my wife turn the wheel, seems to be coming like I said before while looking up towards the top of the shock area (general direction only I know it's not the shock or spring) but some part of the wheel turning mechanism just right of the shock while looking up from the ground.
  9. Dec 11, 2010 at 11:17 AM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    Check your ball joints, upper and lower, and tie rod ends. See if they are leaking grease or are torn open. Try to isolate it more by getting under there and having someone turn it. You should be able to feel the pop in the component making it and parts around it. Just dont get your hand crushed in the process...
  10. Dec 11, 2010 at 11:18 AM
    Taco11
    Seattle WA
    Fixed.. :eek:
  11. Dec 13, 2010 at 1:23 PM
    zx6rman96
    zx6rman96 Well-Known Member
    Indianapolis
    07 PreRunner SR5 TRD off road
    JVC HD-60 tinted windows Black paitned TRD wheels 6000k Bi Xexon HID's Laminx yellow (fogs's) Rear TSB
    curious to find out if you found the problem, i too experienced the same thing yesterday morning and today....16deg out, pulled stragiht out of the driveway and when i transfered to the street I heard one clunk, wheel was barely turned though, sounds like we might have the same issue. I remeber i had this same problem on a VW Jetta i owned, and it turned out it was the strut top bearings were worn out. dont know if our Taco's have that or not, but im sure they do.....lemme know what you find out, as i am leaving mine alone until it warms up, if it still does it when its warm i'll look into the issue
  12. Dec 13, 2010 at 1:30 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Mine has been doing this also. Sounds like mine is coming from the driver side wheel well area? Only seems to do it when it's really cold or wet? Mine doesn't do it when im sitting still and turning the wheel though? Only when i'm making a slight turn.
  13. Dec 13, 2010 at 4:46 PM
    Fore
    07 PreRunner
    Thanks for the replies, I still haven't figured it out yet. I did grease some different areas of the wheel rod connections/mechanisms, but there's no zerk fittings really to do that. I didn't notice the problem today so maybe it help some. Possibly the grease soaked down into the washer joint connections I guess who knows. I'll keep you posted if it seems to do the trick.
  14. Dec 13, 2010 at 5:04 PM
    zx6rman96
    Indianapolis
    Same exact location for me too
  15. Dec 13, 2010 at 7:41 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    I think I have the same clunk when turning the wheel to the left side and straightening it out while standing parked or moving slowly. I don't hear it when wheel turned to the right though. I went down and had someone turned the wheel, I noticed the clunk coming from the inner tie rod/steering gear housing location. I hold on to the tie rod and I could feel some kind of snapping.
    So I went to the dealership this morning and have it looked at. I was hoping that it's only the inner tie rod but they told me it's the rack and pinion and it will cost me $1600. :eek: I looked at the boots, they didn't even open it to see if it's only ball joint with a play. I'll have it looked at by another shop.
  16. Dec 13, 2010 at 7:46 PM
    oneshot808
    oneshot808 Well-Known Member
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    Wet Okoles/Weather tech all around, LED's +HIDS, 6"Fabtech w/ Fox front & rear
    Whew I thought I was the only one that heard the clunks! I still haven't figured it out.
  17. Dec 15, 2010 at 5:07 PM
    Fore
    07 PreRunner
    Please keep us posted I think were starting to get somewhere. Anybody else have any solutions to this problems?
  18. Dec 15, 2013 at 1:57 PM
    Remfic
    Remfic Member
    Ben
    Wisconsin
    2011 TRD Off-Road
    K&N CAI
    Ever figure it out? Mine did it once today and it's about 5 degrees out
  19. Apr 19, 2015 at 10:39 PM
    DJFRENZY
    DJFRENZY Well-Known Member
    Bay Area, CA
    Hydrating this old thread. I hear the clunk sound once in awhile, but not too often under the driver side wheel well. Wondering if anyone found the problem.
  20. Dec 10, 2015 at 8:07 PM
    Quakes15
    Quakes15 Well-Known Member
    Peninsula (BAY AREA)
    TRD Sport Toyota Tacoma X DCSB 4WD
    ICON Stage 3/ Stealth 6's/ Nitto Trail Grapplers
    I am starting to hear a bit of the clunk noise on the drivers side when turning only or pulling out of the parking lot. I have noticed that I only hear it when it rains and it has been raining today. Not sure if anyone knows what it could be?
