Wheel turning clunk/Pop sound?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fore, Dec 11, 2010.
  1. Dec 23, 2020 at 2:11 PM
    #41
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Strut mounts or broken coil spring/coil spring isolators?
    Edit: I had a Saab 9-3 years ago that started doing that, and it was a bad strut mount with too much play. When the wheel was turned (slow or no speed), the force would cause the strut to knock within the mount at the top of the tower.
    Chris1121555 likes this.
  2. Mar 4, 2021 at 2:58 PM
    #42
    Chris1121555
    Chris1121555 Well-Known Member
    East Coast
    2017 Infeno TRD OR Manual
    -Toytech BOSS 2.0 Aluma Series lift w/ AAL (2") -265/75R16 BFG AT KO2's -Plastidipped TRD OR Wheels w/ Red TRD Center cap -LED Head/Fogs -Interior LED lighting -Rigid Industry Ditch Lights -Black OEM Grill (Painted) -Westin Grill Guard -Copy Polymer Shfit Knob (M/T) -Tonneau Cover, Tri-Fold. (*Looking to sell or trade for Rollup*) -Kicker CS speaker upgrade -Kicker Hideaway 8" subwoofer
    @Fore
    Any update?
  3. Jul 31, 2022 at 6:59 PM
    #43
    Taco4XStock
    Taco4XStock Clutch Cargo
    South West Desert
    2003 Tacoma 3.4L 4X4 5 Speed Manual Trans TRD.
    My Horse's Tires are 1 in. bigger.
    My 03 Tacoma 4X4 Stock gets a metallic knock at turns below 15 mph. Had ball joints done. Sway bar done. recently Rack and pinion done. Ujoints done last week and STILL get the knock on turns. I had the mechanic check all bushings joints and tighten all bolts. Still does it. I am going to GoPro certain areas and see if that gives me a clue. Will double check the strut and shock bushings. I'll be back!
  4. Jul 31, 2022 at 8:33 PM
    #44
    dogbite
    dogbite Well-Known Member
    Utah
    '10 double cab TRD OR
    OME lift, Leer shell, Beefed sliders, Extra 12V outlets for rear bench
    Steering stops but more likely lower control arm ball joint/bushing thing. If you're OEM, you replace the whole thing. I'm about due for my third set. I always replace them in pairs.
  5. Aug 1, 2022 at 4:35 AM
    #45
    tak1313
    2013 Base 2WD
    Control arm bushing?
  6. Aug 1, 2022 at 4:58 AM
    #46
    DrFunker
    DrFunker Well-Known Member
    alignment cam bolts?
  7. Aug 1, 2022 at 6:58 AM
    #47
    tak1313
    2013 Base 2WD
    Forgot to mention - the fact that it is happening on low speed turns could also indicate bad strut mounts.
  8. Aug 1, 2022 at 8:43 AM
    #48
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    also, check the outer tie rods
  9. Aug 3, 2022 at 9:39 PM
    #49
    TacomawithArima
    TacomawithArima Active Member
    East Bay California
    2014 Tacoma TRD OR Baja Black
    Wow I just developed this problem after some very light off roading on some USFS roads. I've driven and beat up a bunch of ford rangers and never developed this clunk sound. Kinda disappointed in my trd off road right now. Gonna take it to a mechanic on Tuesday to see if they can diagnose the problem without replacing every single component of my suspension.
  10. Aug 9, 2022 at 1:01 PM
    #50
    MikeMcfly
    MikeMcfly Active Member
    Alpharetta, Ga
    2019 Taco
    EXACTLY why I am sitting in the shop right now.
    I do much stop and go driving they just confirmed my rack and pinion needed to be replaced.
  11. Aug 26, 2022 at 4:27 PM
    #51
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    What year and mileage?
  12. Aug 26, 2022 at 5:10 PM
    #52
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    On Cars and SUV's with MacPherson struts, Yes. but the tacoma and most other trucks do not have the typical SUV/car strut mount that turns with the wheel. Ours are static and do not turn since they are mounted to the LCA and not to the knuckle. So since they don't turn you won't get the low speed clunks on turns from the strut mount. Not to say they cannot go bad though and cause a clunk in general like going over bumps.
  13. Aug 28, 2022 at 2:28 PM
    #53
    MikeMcfly
    Alpharetta, Ga
    2019 Taco
    It is a 2006 double with just under 148k. I am going back into the shop to hopefully get a cheap answer....HOPE.
  14. Sep 1, 2022 at 9:40 PM
    #54
    MikeMcfly
    Alpharetta, Ga
    2019 Taco
    Found in my case 1 wheel bearing needs to be replaced.
  15. Sep 1, 2022 at 10:23 PM
    #55
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Does it sound like this? I have removed my sway bar after this and the noise persists. I’ll check the steering shaft torque and see if that fixes it.
    https://youtu.be/McTc014Yuyg
  16. Sep 1, 2022 at 11:17 PM
    #56
    MikeMcfly
    Alpharetta, Ga
    2019 Taco
    Yeah I found it happen on a turn mainly.
  17. Sep 2, 2022 at 12:01 PM
    #57
    woods_24
    woods_24 Well-Known Member
    2009 Black TRD Sport DCLB
    I have the pop/clunk too. My intermediate steering shaft is brand new, and sway-bar deleted. Tie rods and alignment are recent. New steering rack. Next job is rad support bushings. I'll check cam bolts too and report back.
  18. Sep 2, 2022 at 12:34 PM
    #58
    JasonLee
    15 TRD OffRoad
    I am hoping that is my issue.
  19. Nov 29, 2022 at 9:13 PM
    #59
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    Any update?
    In the same boat
  20. Jan 12, 2023 at 12:35 PM
    #60
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
    Still have that pop?
    I did the rad bushing & cam torque
    I still have it.
