Wheel upgrade 07 Tacoma Reg Cab 2WD
Discussion in 'Wheels & Tires' started by hammerdog, Aug 15, 2007.
  1. Aug 15, 2007 at 1:07 PM
    hammerdog
    hammerdog [OP] Well-Known Member
  2. Aug 18, 2007 at 12:55 AM
    reid
    reid Well-Known Member
    Vancouver BC Canada
    2007 V6 Access Cab
    Magna Flow stainless cat-back, 3" Toytec Lift, 32" Mickey Thompsons
    I think that this is only for one wheel.
    Anyway my truck is an 07 V6 ext cab and it uses a 6 x 5.5. Ie. 6 lugs, this wheel has 5. Dont know about your truck though.
  3. Aug 18, 2007 at 5:36 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    I am going to agree with reid and say that this auction is for one wheel. Therefor to buy all four that the seller has listed is going to run you $620 plus what looks to be about $46.00 shipping. And there is not way in hell that oem camry wheels are worth $660 to your door.
    Second they MAY fit if you have a base 4x2 tacoma with the 5 lug hubs (I don't know the bolt spacing on the 5 lug trucks or on the camry so I can't be sure) But the 4x4 trucks and pre-runners all use a 6 lug hub, so they are not an option if that's what you have.
    just my $0.02
  4. Aug 18, 2007 at 8:37 AM
    hammerdog
    Thank you for your responses.
    I have 5 lugs, but I read a post on CustomTacos.com that Camry wheels have a center bore of 60.1 and the center bore on a 2WD Tacoma is 67.1 so the wheels would have to be bored out in order for them to fit, so not worth the extra work to me.....
  5. Aug 18, 2007 at 10:37 AM
    reid
    Vancouver BC Canada
    2007 V6 Access Cab
    definately not worth boring them out. The time it would take for a machine shop to put them on a lathe and bore ou the inside Diameter would cost you pretty much the price of the rims.
  6. Aug 18, 2007 at 12:55 PM
    spp
    spp OC, Kalifornia
    OC California
    You read wrong. The bore on '04 and earlier is 67.1.
    '05 and up is 60.1. Let me know how the camry wheels fit.
    I've been thinking about trying to find some from Camry or Sienna.
    I want some 16" with TPMS sensors still installed.
  7. Aug 18, 2007 at 5:50 PM
    hammerdog
    spp- I got that information from customtacos 2WD Tacoma forum, but you are you saying the 07 2WD Tacoma wheel bore is 60.1 ?
  8. Aug 19, 2007 at 7:24 AM
    spp
    spp OC, Kalifornia
    OC California
    I also got My info from Custom Tacos. You misread the post there.:)
  9. Aug 19, 2007 at 7:31 AM
    spp
    spp OC, Kalifornia
    OC California
    2WD / 5-LUG INFO: Basic Tacoma Wheel Info
    2WD 5-lug Tacoma wheels have the following basic parameters:
    Bolt pattern / bolt circle / PCD: 5 X 114.3 (mm) = 5 X 4.5"
    Lug Nut Thread Format: M12 (12 mm) X 1.5
    Centerbore:
    1995.5 - 2004: 67.1 mm
    2005 - ???? : 60.1 mm
    Tacoma OEM / factory 2WD wheels have been sized as follows:
    1996 - 1997:
    Wheel Size: 14 in. (2WD)
    Type & Material: Steel
    1998 - 2000:
    Wheel Size: 14x5,14x6 (2WD)
    Type & Material: Steel, Alloy
    2001 - 2004:
    Wheel Size: 15x6 (2WD non-SR), 16X6.5(S-Runner)
    Type & Material: Chrome, Steel, Alloy
    2005:
    Wheel Size: 15" (2WD non-XR), 18" (X-Runner)
  10. Aug 19, 2007 at 8:57 AM
    hammerdog
    spp- thanks for the updated info, makes it a lot easier now
  11. Aug 19, 2007 at 5:27 PM
    spp
    spp OC, Kalifornia
    OC California
    Post pictures of whatever you get so I can decide too please.:)
  12. Aug 19, 2007 at 6:26 PM
    hammerdog
    Will do, apparently the offset on the camry wheels is 50, but that should still work....will post photos when i finish....
  13. May 4, 2008 at 4:40 AM
    tacoma man
    tacoma man Well-Known Member
    Rochester NY
    2018 Limited 4wd Magnetic Gray
    SPP
    I have new 31x10.5x15 tires from 99 v6trd that is to be crushed. Would like to use the tires on new 08 2wd 2.7 basic access tacoma. Would tires fit with stock rims? THanks.
  14. May 4, 2008 at 2:29 PM
    spp
    spp OC, Kalifornia
    OC California
    I think the rims would be too narrow for that size tire and they would rub without a lift.
