Wheel vibrating after new suspension, wheels, and tires installed. Help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LOTR_is_awesome, Nov 10, 2023.
  1. Nov 10, 2023 at 6:57 AM
    LOTR_is_awesome
    LOTR_is_awesome [OP] Member
    Hi there. I feel a vibration coming primarily from my front right tire when I’m driving. There’s a pause between vibrations. I feel the vibration every 1.5-2 seconds and it only lasts 1 second at a time. I can only feel it when I’m going 25 mph or faster. It’s not strong enough to make the truck wobble or anything. It’s mild, but it’s annoying because I can feel it and hear it even though it’s very subtle. Here is the work I just had done on the truck:
    - new front suspension with Bilstein 5100s with 3 inch lift
    - new leaf springs in the rear
    - new Black Rhino wheels
    - new tires, upgraded from 31 inch to 33 inch
    Does anyone know what might be causing this? Thanks.
  2. Nov 10, 2023 at 7:06 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I would assume it’s a wheel problem does it seem to be front or rear?
    There’s a lot of information out there about the hubcentric size required for rear wheels. I assume these are too small, and the wheel is just not sitting squarely
  3. Nov 10, 2023 at 7:07 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Needle bearing in the front diff has gone bad from the lift. See if it goes away if you put the truck in 4wd.
    It's on the left side but vibes can be felt all over.
