Wheel Vibration at 20 mph
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jamma, Nov 26, 2017.
  1. Nov 26, 2017 at 9:26 AM
    Jamma
    Jamma [OP] Well-Known Member
    2017 MGM TRD Off Road
    I recently had a lift, wheels and tires installed and everything came out good. I do get a slight vibration in the steering wheel when the truck hits about 20 mph and then all vibrations stop at around 27-30. Any other speed it is perfectly smooth. Would this be tire or wheel related?
  2. Nov 26, 2017 at 9:30 AM
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    Might be wheel balance issue or front end alignment. First check the lug nuts to see if they were torqued properly.
    Jamma[OP] and CaptainAwesome like this.
  3. Nov 26, 2017 at 9:31 AM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    drivers side front diff bearing, look for ecgs bushing
    stealthmode, kgilly and InfernoTonka like this.
  4. Nov 26, 2017 at 9:32 AM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    Balance tires an if it still there. Start on only thing you changed. Suspension an lift.
  5. Nov 26, 2017 at 9:37 AM
    Jamma
    I thought about the bushing. But since the vibrations only come at a very select speed, I didn't think that was it. If it is the bearing could it cause vibrations at only a certain speed?
  6. Nov 26, 2017 at 9:39 AM
    Jamma
    I did have the new wheels/tires balanced and had an alignment done, and the numbers look very good. I'll double check the lug nuts.
    InfernoTonka[QUOTED] likes this.
  7. Nov 26, 2017 at 9:42 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    Put it in four wheel drive and if it goes away then it is more than likely the ecgs bushing
  8. Nov 26, 2017 at 9:50 AM
    Jamma
    I'll test the 4wd here in a little bit, thanks!
  9. Nov 26, 2017 at 10:26 AM
    Jamma
    Alright so being in 4wd or not does not change the vibration. I guess I'll take it in for another balance and alignment. What are the chances of the tire being out of round? Would that cause this?
  10. Nov 26, 2017 at 10:57 AM
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    That can also do it or possibly a wheel weight fell off or improper balancing...process of elimination..good luck
    InfernoTonka likes this.
  11. Nov 26, 2017 at 11:11 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Did you get a road force balance?
    Happen to know the road force number?
    Wheel and tire specs? Hubcentric?
    Alignment numbers?
    Does it change rotating front to back?
  12. Nov 26, 2017 at 11:14 AM
    Scotty Dosent Know
    Scotty Dosent Know Well-Known Member
    2017 Tacoma DCSB
    Why dont you put your stock wheels and tires on and see if it goes away?
  13. Nov 26, 2017 at 11:32 AM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    short answer, yes. I get oscillation type vibration around 35-40mph but nothing above or below. so my ecgs bushing is sitting on my desk awaiting install. However got bigger fish to fry this weekend like bending back a pinch weld and flattening out some plastic fender liners.
  14. Nov 26, 2017 at 11:34 AM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    oops forgot to mention thats how you check it, sorry. mine goes away when in 4wd, so I know its the diff bearing.
  15. Jun 23, 2020 at 8:44 AM
    PitterPatter
    PitterPatter New Member
    2019 Voodoo Blue Tacoma TRD PRO
    Experiencing the same issue after Revtek 1.5" FRONT SPACER AND REAR ADD-A-LEAF FOR TRD PRO TRUCKS. I had Discount tire balance and install 285/75/16 KM3's and my local shop do an alignment. There's a slight vibration in my steering wheel at speeds of 20-25mph, vibration will go away above and below these speeds. I experienced the vibration right off the bat after Revtek install with stock tires. Issue did not go away after new tires were installed and alignment completed.
  16. Sep 24, 2020 at 3:25 PM
    rd12vman
    rd12vman Member
  17. Sep 24, 2020 at 3:27 PM
    rd12vman
    rd12vman Member
    Did you find out what was causing your vibration? I am having similar vibration in the steering wheel around 20 mph. All started after OME lift was installed earlier this week.
    Sky.Fox likes this.
  18. Sep 24, 2020 at 4:48 PM
    PitterPatter
    @rd12vman I have not, unfortunately. I did however order a set of 3 degree axle shims and plan on installing in the upcoming weeks... will keep you posted.
  19. Sep 25, 2020 at 7:02 AM
    rd12vman
    rd12vman Member
    Sounds good. Keep me posted. I did see another thread where the shin did the trick for someone else.
  20. Jun 23, 2021 at 4:55 PM
    Davidwallace93
    Davidwallace93 Member
    David
    2021 Tacoma TRD Off Road
    Has anyone had any luck with this?
