Wheel weights – Steel vs. factory alloy – 16”
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JJK, Oct 7, 2010.
  1. Oct 7, 2010 at 4:04 PM
    JJK
    JJK [OP] Active Member
    08 SR5 DC
    TrueTrac Limited Slip
    Hello All,
    Does anyone know the weight difference between the factory steel and factory alloy wheels for 2nd gen Tacoma trucks?
    I just went with a heavier tire and at the same time finally installed some allow wheels I got used last year. I am wondering if the lighter wheel will off-set the heavier tire (old tire =38lb, new tire = 46lb).
    Thanks!
    JJK
  2. Oct 7, 2010 at 4:31 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Alloys are typically lighter than steel, and aftermarket alloys are typically even lighter...but I don't know the actual numbers.
  3. Oct 7, 2010 at 5:56 PM
    06redtacoma
    06redtacoma Well-Known Member
    Alabama
    06 Trd Offroad
    Lifted, Slider, stock rack, rear mounted winch in stock bumper, brush guard, Sound system, ipod to car, tint, wheel spacers, 285 bfg AT,
    if you get actual number i think you are going to be disapointed the alloy metal is much lighter but if you look at the amount of alloy in comparison to the amount of steel that was there the alloy takes up a lot more space. good luck with it plus does it really matter? you feel any difference in the breaks?
