wheel weights rubbing caliper
Discussion in 'Wheels & Tires' started by yoeddy, Apr 22, 2012.
  1. Apr 22, 2012 at 4:53 PM
    yoeddy
    yoeddy [OP] Member
    Rob
    Issaquah
    I just had my 5000 mile service and they rotated the tires. Now the front left wheel weights slightly rub the caliper. My first inclination is to just leave it. Lead is soft, the caliper has to be harder, so it will clear eventually. Dumb move or should I take it back and see if I can get the weights repositioned?
  2. Apr 22, 2012 at 4:59 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    i would have them rebalanced and ask for adhesive weights that will be placed on the inside of the rim..
    i have the adhesive style for off roading in mind solely because the weights are on the inside of the rim, and can't be removed from scraping rocks while on the trail..
    T Fades likes this.
  3. Apr 22, 2012 at 5:20 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
  4. Apr 22, 2012 at 5:21 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    if they rub the caliper then they are already tap on weights so why would you recommend tape on weights? the caliper is located inside the wheel diameter, not on the inside lip anywhere
  5. Apr 22, 2012 at 5:32 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    I rotate and balance taco rims all the time at work and this is a real common problem. The stick on weights (that you are using) are nice because it keeps the wheel looking clean, but the clearance is tight on the front. I will usually put the hammer on weights on the outside only if the wheel is already scratched from this, I will use the stick on weights on the rim just inside the caliper in your situation. Now that your caliper has made contact with the weight it has rubbed off the protective coating on the caliper, it will more likely rust in that spot now. Take it back and explain that the Tech should have heard the noise when he did your first service.
  6. Apr 26, 2012 at 7:38 PM
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    exactly
  7. Apr 26, 2012 at 7:51 PM
    MonkeyProof
    SoCal- SGV
    if they use the 1/4 gram adhesive weights which are slim, they will not rub. i balance my own wheels and use the 1/4 gram weights with no issues..but what the hell do i know, i'm only a diesel/heavy line tech at a ford dealership:rolleyes:
  8. Apr 26, 2012 at 8:15 PM
    08pretaco
    az
    What if they doubled up on the inside row instead of making two side by side
  9. Apr 26, 2012 at 8:18 PM
    sudafed
    sudafed Well-Known Member
    Oh your a technician or Ford?
    You must know everything when it comes to everything.
  10. Apr 26, 2012 at 8:19 PM
    MonkeyProof
    SoCal- SGV
    when it comes to actual experience in balancing my own wheels, at the ford dealership that i work at..pretty much :D
  11. Apr 26, 2012 at 8:34 PM
    08pretaco
    az
    I work at a shop as well, not a fancy diesel tech or anything of that nature. First Tacoma that came in I made the silly mistake myself. I double stacked the 1/4 oz and it rubbed on the caliper. After I discovered this backing it up to pull it around, I redid the front with 2 roles and no stacking. It also matters where you place the weights in the middle. Some wheels have a little slope and are not flat all the way to the face. If you place weights on the sloped area your most likely going to rub regardless of using 1 stack of 1/4 oz weights.
  12. Apr 26, 2012 at 9:09 PM
    Bobber Bill
    Los Angeles, CA
    I don't always LOL
    but when I do, it's because it's fucking funny
    Toki likes this.
  13. Apr 27, 2012 at 5:59 AM
    yoeddy
    yoeddy [OP] Member
    Rob
    Issaquah
    No stacking, they originally did have two rows and they still rubbed. These were the fake bead lock wheels.
    Turns out they have wider thinner weights that Toyota typically uses for these wheels. The shop that did my lift didn't use them. I guess the other wheel in that spot had rubbed as well, but I never heard over the radio and with the windows closed. The dealer rebalanced with the thin weights. Bingo, no rubbing.
    Thanks for all the help and responses
  14. Apr 27, 2012 at 7:02 AM
    08pretaco
    az
    Perfect! Glad it was figured out!
  15. Apr 27, 2012 at 7:12 AM
    Bobber Bill
    Los Angeles, CA
    Glad you got it figured out. I had a shop stack weights once. Those things hit my calipers, got ripped off the wheels and bounced off the highway before they shot up at the bottom of my cab. Sounded like random gun shots and I felt each impact.
  16. Oct 3, 2018 at 3:17 PM
    AJC84
    AJC84 Well-Known Member
    Andy
    2011 DC LB V6 4X4 MAG GREY
    I know this is an old thread but I am having same issue. Tire shop put too thick of stick on weights and it's rubbing caliper. They said it's barely contacting it and should go away quickly. Is that true or did they just bs me because they were too lazy to rebalance with smaller weights?
  17. Apr 10, 2024 at 11:54 AM
    microsnook
    microsnook Well-Known Member
    '20 TRD OR MGM MT
    I just got mine done as well. TRD Beadlock style wheel 16” and it’s rubbing the weights. Should I have them redo it? I think I already lost front passenger weights. Not even 1/4 mile. Thanks
  18. Apr 11, 2024 at 8:53 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    YES. 100%. If you've lost weights already then that means your wheels are no longer balanced. The tire shop should have checked for clearance and moved the weights accordingly. Take it back and have them finish the job correctly.
  19. Apr 11, 2024 at 8:55 AM
    microsnook
    '20 TRD OR MGM MT
    I did, they shifted them 1/8" and everything is good now. Cheers.
    Discount Tire likes this.
