wheel width and back spacing help needed.
Discussion in '5 Lug' started by newbie taco, Aug 27, 2018.
  1. Aug 27, 2018 at 4:19 PM
    newbie taco
    newbie taco [OP] Well-Known Member
    Was hoping somebody can give me some insight as to whether this wheel set-up would fit good on my base 2wd 2014 5-lug taco. I would like to use these Method wheels brand I found. They are a 15" x 8" with 5 x 4.5" bolt pattern with a 3.5" back spacing/ -24mm offset. I have no idea what my stock steel wheels are other than 15"x 6". If figure they will stick out a bit more but unsure. Any input on this would greatly be appreciated. Here's the link below to the wheels/specs if anyone cares to see them. -Thanks,
    https://www.summitracing.com/parts/mth-s0268/overview/
  2. Aug 27, 2018 at 7:05 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    They will fit but will push out some more then stock rims.
    Also arnt hub centric so you will need the rings if you make the hub centric
  3. Aug 27, 2018 at 7:37 PM
    newbie taco
    What is the difference between hub centric and lug centric? Is one better than the other?
  4. Aug 27, 2018 at 8:48 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Non hub centric rims just use the lug nuts to center it. Which isn’t really a problem
