Wheel width and offset
Discussion in 'Wheels & Tires' started by IvanCard, Apr 22, 2013.
  1. Apr 22, 2013 at 6:31 PM
    IvanCard
    IvanCard [OP] Well-Known Member
    Houston, Tx
    06 DCSB, 13 DCLB SPORT, 17 DCSB OR
    So I'm going to put a Fabtech 6" lift on my 2013 taco. Also getting the Fuel Hostage wheels. The guy at the lift shop told me that a 20x10 with a -24 offset will rub too much so i went with the 20x10 with -12 offset. Later he calls me and tells me that the guys at Fabtech told him that I should go with a 20x9 wheel with -12 offset. Because of wear&tear and alignment reasons. I'd really like to go with the 20x10 with the -24, I love the look of the tires/wheels sticking out the truck. If not then the 20x10 with -12
    BTW the tires will be 295/60r20 Which is approximately like a 34" tire or so
    Any help on this is greatly appreaciated :D
  2. Apr 22, 2013 at 6:33 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    What wheel width range is recommended by the manufacturer of those tires? Go with that.
  3. Apr 22, 2013 at 6:42 PM
    IvanCard
    Houston, Tx
    I'm not sure I'd have to look. But I've seen both 20x10s and 20x9s on that tire so they'll both work fine. I mean the tire is about 11.5 inches wide or so.
    I just want to know if anyone has them on, and exactly what width with what offset they are using. And if and how bad things be rubbing lol
