Wheeler aal help
Discussion in 'Suspension' started by FixedTRD, May 1, 2010.
  1. May 1, 2010 at 12:31 AM
    FixedTRD
    FixedTRD [OP] Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    I got some wheeler aal 1.5. It state to remove the overload but I would like to know if this is necessary or can I keep the overload on?
  2. May 8, 2010 at 9:50 PM
    FixedTRD
    Will
    Alhambra, CA
    anyone?
  3. May 8, 2010 at 9:53 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I don't think its necessary, I didn't remove any leafs when I added my AAL
  4. May 8, 2010 at 10:08 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    I just added a Toyotec AAL. I placed my AAL between the overload and the leaf pack. IMHO I wouldn't remove the overload.
  5. May 8, 2010 at 10:52 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Of course you can leave the overload spring on BUT the centering pin that Wheelers provides is not long enough to go through both the AAL and the overload (or so I recently read); you'll need to buy your own centering pins that are the correct length.
    Plus your overload spring will add height to your overall lift, if that matters...
  6. May 9, 2010 at 3:36 PM
    FixedTRD
    Will
    Alhambra, CA
    Thanks everyone I guess I will put the overload back on once i order new center pin and new u bolts.
  7. May 10, 2010 at 5:24 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Did you get the single aal kit, or the 3 leaf aal kit?
  8. May 10, 2010 at 5:33 PM
    FixedTRD
    Will
    Alhambra, CA
    I got the 3 leaf aal.
  9. May 10, 2010 at 5:41 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    That one is meant to replace the overload leaf. Is designed for smooth ride and off-road performance.
  10. May 10, 2010 at 5:52 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    You will probably lose the ability to load up the box right full of stuff though eh? or does it not effect payload that much by removing the overload leaf ?
  11. May 10, 2010 at 5:54 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    You do lose payload capacity. However, alot of people are getting the 3 leaf aal and then also getting a set of Timbrens for the rear. That way they get the best of both worlds.
  12. May 10, 2010 at 6:02 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    oh ok right on, or superbumps eh lol?
  13. May 10, 2010 at 11:54 PM
    FixedTRD
    Will
    Alhambra, CA
    What would be the pro and con if I were to install the overload.
  14. May 11, 2010 at 12:04 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Well, I think keeping the overload spring in there could damage the leaf pack with the 3leaf AAL in place.... As I see it, the smallest leaves on the AAL wont extend past the end of the overload so the springs can be forced into a negative arch, effectively damaging them.
  15. May 12, 2010 at 8:09 AM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2016 4Runner
    How much load capacity are you loosing? I am on the fence about which to get for my truck.
