Wheeler Multi-Leaf Add-A-Leaf Set-1.5"Lift 3 Leaf Progressive 1995+Tacoma,Tundra 1999-2006
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by chueflee, Apr 17, 2022.
  1. Apr 17, 2022 at 1:50 PM
    chueflee
    chueflee [OP] Well-Known Member
    Chue
    2013 toyota tacoma TRD offroad extended cab 4x4 v6
    afe intake, urd spec u headers, urd y pipe, 76mm throttle body, kelford camshaft, trd supercharger, urd cam gear, urd thermostat, ucon ems, NST pullies, ipt valve body, stoptech disc brake 323mm front, sos rear disc conversion
    Never used. Brandnew $160 shipping included
    • SOLD
    A 3-leaf progressive racing style add-a-leaf set. Designed to replace your factory overload leaf. Kit includes longer U-bolts and center pins. These add a leaf kits feature 60mm width, diamond cut ends and anti-friction pads for smooth, squeak-free performance. They are tuned to enhance load performance while providing a good ride. Includes two add-a-leaf packs (3 leafs each), center pins and u-bolts. NOTE: Lift amounts are approximate and may vary depending on chassis and load. On some years and/or models, you may need to remove the front clamp from the Add-A-Leaf to avoid interference with the overload spring and gas tank strap.
  2. Apr 20, 2022 at 5:40 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod
    Free bump, I have this on my truck and it preforms great!
