Wheeler's 05+ HD Replacement Pack
Discussion in 'Wheeler's Off-Road' started by YotaDan, Mar 6, 2013.
  1. Mar 6, 2013 at 10:20 AM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    This is a heavy duty rear leaf spring set for owners wanting a stouter rear spring set for their Tacoma. Great for trucks hauling extra weight, utility and expedition applications. They have 4 leafs plus an overload leaf and feature diamond cut leaf ends with anti-friction pads, bolt style pack clamps and a provision for the factory e-brake cable clamp. They are supplied with a performance polyurethane bushing set and zinc coated u-bolts. They fit Standard, Xtra and Double Cab chassis, 4cyl and V6. Depending on chassis and load, your truck will sit higher than stock. The 3rd leaf down can be removed for reduced ride height and a softer spring rate if desired. These springs are left and right specific and are made from 60mm width material. These leaf packs work well with a performance gas charged shock such as Bilstein 5100's (listed below). You will notice an improvement in the stability and ride height of your Tacoma under load as well as enhanced control of axle wrap.
    Couple pics for those of you who are curious:
    REDdawn6 likes this.
  2. Mar 14, 2013 at 12:27 PM
    Jeffsdeere
    Jeffsdeere Well-Known Member
    Jeff
    07 Tacoma DC4wd
    BAMF Sliders All Pro Rear Bumper 5100's @.85
    Are you guys running any special deals on these? What does shipping generally run?
  3. Mar 14, 2013 at 12:29 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    x2
    How about to Canada?
    Would this be considered a direct (heavier duty) replacement for 2nd gen Tacoma TSB (4 leaf) springs?
  4. Apr 30, 2013 at 10:13 PM
    splitbolt
    splitbolt Well-Known Member
    Ozarks
    2016 TRD OFFROAD DCSB MGM
    Are these made by Alcan?
  5. Apr 30, 2013 at 10:19 PM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Will this give me more or less lift in the rear rather then a stock leaf pack with TSB with over 100K and an 1 and a quarter inch AAL? if so how much?
  6. Apr 30, 2013 at 10:43 PM
    splitbolt
    Ozarks
  7. Mar 2, 2014 at 6:37 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    So are these just about neutral to stock height or do they give any lift over the 3 leaf (2/1) springs?
  8. Aug 24, 2014 at 8:42 PM
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    anyone have any feedback on these? trying to decide between these or 3 leaf HD add-a-leaf
  9. Nov 1, 2015 at 2:30 PM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Any insight on how much lift these give? Able to retain stock height shocks? I'm debating on adding the 3 leaf AAL to my TSB leaf pack or just replacing the leaf pack with these. About a years time and 15k miles the TSB pack is now sitting on the overloads, they were great when new but with the extra weight of my cap have gone soft again.
  10. Nov 2, 2015 at 10:18 AM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    These are a Heavy Duty Replacement pack meant for vehicles with a constant load. When unloaded they will provide 2.25-2.5" of lift.
  11. Nov 2, 2015 at 2:55 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    So with a load would I be looking at stock TSB leaf spring height you think? I have a leer 100xq topper on the truck at all times, which the stock off-road 3 leaf pack gave out carrying and now my TSB 4 leaf pack is resting on overloads as well. Thanks for the help.
  12. Nov 2, 2015 at 4:04 PM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    Just depends on how much weight. They are still beefier than the TSB pack. 4 supporting leafs and the Overload.
  13. Nov 4, 2015 at 7:51 AM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    I have run these leafs on a 2.7 L AC with an ARE topper for two years. I got just under 2" of lift with them. Great product, as I have used them very hard and they have no squeakes or creaks.
    YotaDan likes this.
  14. Nov 11, 2015 at 11:47 AM
    tacollie
    tacollie New Member
    Colorado Springs
    09 TRD Off-road, auto
    Flippac, wheelers HD springs with OME d29xl, Bilstien 5100 all around.
    I run these with about 400lbs regularly. It sets about stock height but handles and rides way better. I think I am about 21.5" center of hub to flare.
    YotaDan likes this.
