Wheelers 1.5 Progressive AAL and Overload?
Discussion in 'Suspension' started by chowwwww, Jan 7, 2015.
  1. Jan 7, 2015 at 12:25 PM
    chowwwww
    chowwwww [OP] Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    I will be installing the wheelers 1.5 prorgressive AAL either this weekend or next weekend. The description says that I can use it with or without the overload. I have a 2003 double cab with camper and stock spare on the truck. Dont really carry that much heavy gear just during the summer when I go fishing and Ill be towing a boat maybe 2 times a month during that time.
    Would you guys recommend keeping the overload or just getting rid of it? Interested in opinions on ride quality with and without it and height.
  2. Jan 7, 2015 at 7:17 PM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    I left mine in but it did give me almost 2" of lift in back. are you lifting the front? if you are not you will be ass high. I will post a pic of mine with no lift in the front.
  3. Jan 7, 2015 at 7:19 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Get rid of it. My truck handles 500-600 lbs no problem without it.
  4. Jan 7, 2015 at 7:21 PM
    williams63
    chili
    nh
    2011 dblcb
  5. Jan 7, 2015 at 7:21 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Is that it ?
  6. Jan 7, 2015 at 7:29 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I have a progressive aal and I left my overload in. I doubt the overload has an effect on ride quality because it only comes into play when the leaf flexes enough, not during normal driving.
  7. Jan 7, 2015 at 8:03 PM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Yes, I'm lifting the front 2.5. I prefer for it to sit leveled, but I don't mind a little rake. Just don't want the front to sit higher than the rear.
  8. Jan 7, 2015 at 8:04 PM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Thanks for the replies guys.
  9. Jan 7, 2015 at 8:09 PM
    williams63
    chili
    nh
    2011 dblcb
    with 2.5" coils up front.
  10. Jan 7, 2015 at 8:18 PM
    deeezy
    Dana
    Hawaii
    I don't know how the aal will be on a first gen but on a second gen 1.5" in back was about 1/2" higher than the front lifted 2.5"
    You need to break out a tape measure and see where your rear is now compared to your front. Add 2.5 to the front and see how high you want the rear lifted.
  11. Jan 7, 2015 at 9:06 PM
    chowwwww
    Orange County
    03 Doublecab 4x4
    That looks good to me!
  12. Jan 7, 2015 at 9:07 PM
    chowwwww
    Orange County
    03 Doublecab 4x4
    That's a great idea. I'll do that tomorrow before I start taking my suspension off.
  13. Jan 7, 2015 at 9:23 PM
    TacoBrah
    Sean
    Havent tried any higher yet because I havent had a need. Im sure it would be able to handle more.
    I have also towed a small fiberglass boat with no problem.
  14. Jan 8, 2015 at 3:47 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    For normal driving conditions (i.e., not a lot of axle flexing), the overload leaf essentially acts as a 1/2" lift block, so it comes down to whether or not you want that added 1/2" of lift in back. The ride quality isn't much different with or without the overload, although I've noticed the added 1/2" of lift can create a slight axle wrap feel during braking.
  15. Jan 8, 2015 at 4:00 PM
    Lipson
    Lipson Well-Known Member
    Adam
    San Diego
    '97 T4R Limited
    Take the overload out! I have the same setup and and after running the progressive AAL w/ the overload i ended up removing it. The overload is designed to mate with a larger leaf so when your springs go into negative arc, it supports them. If you have the AAL pack in there and bottom out, the overload actually contacts the second or third leaf from the bottom, creating a sharp impact that can cause a failure. Just my $.02
    61ragtop likes this.
  16. Apr 22, 2016 at 8:27 PM
    JHsieh_3
    JHsieh_3 Well-Known Member
    Jeff
    City of Angels
    2018 Tacoma TRD Sport
    Don't mean to revive the thread, but you seem knowledgeable in this area. I have bilsteins 5100 all around, OME 885 coils up front with bilsteins set at .0. I added the Wheeler's 1.5 Progressive AAL's in the rear and removed the overload. I'm noticing that my back sags a little lower than the front, probably about half inch (assuming due to the overload being removed). How can I level out my truck? I don't really want to put my overload back in due to the reasons you stated above.
    I drive a 15' Double Cab Short Bed tacoma.
    Thanks!
    J-VET likes this.
  17. Apr 23, 2016 at 6:54 AM
    williams63
    chili
    nh
    2011 dblcb
    if your set at 0 up front already you would either need to put a smaller coil or put the over load back in. you could also add blocks.
  18. Apr 23, 2016 at 6:56 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I left mine in as well
    Walston9 likes this.
  19. Apr 23, 2016 at 7:13 AM
    williams63
    chili
    nh
    2011 dblcb
    Unchained wish those step bars your selling were for a short bed
  20. Apr 23, 2016 at 7:27 AM
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    Put the overload in. I've been running the Wheeler's progressive AAL in my 2+1 stock pack for over two years with the overload and I've had zero issues. I regularly haul ~1000lbs of landscaping materials in the summers and it handles very well.
    Just under 1000lb last weekend.
