Wheelers 1.75" Lift Kit - Installed
Discussion in 'Suspension' started by canyonchaser, Oct 1, 2012.
  1. Oct 1, 2012 at 1:09 PM
    canyonchaser
    canyonchaser [OP] Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    I decided on the Wheelers 3-leaf HD Progressive AAL on the rear with Bilstein 5100. Wheelers recommended, that based on my need and how I drive, that I would be better keeping the OEM springs on the front with the front Bilsteins set at the second-from-the-top setting.
    Here's the before;
    Here's the after;
    I ended up with 1.5" inch raise at the front and a 2.25" inch raise at the rear (although I suspect the rear will settle a bit) - I get an extremely slight vibration as I start rolling - but it's extremely sublte. I'm hoping it goes away as the rear settles.
    Overall, I'm very happy with the end result. It was exactly what I was looking for.
    dp
  2. Oct 1, 2012 at 2:49 PM
    southernboy30
    southernboy30 Member
    Gives the truck a more bold stance.
  3. Oct 8, 2012 at 11:59 AM
    alphanumericone
    alphanumericone Member
    07 PreRunner SR5 Debadged 6-speed
    URD Short Shifter Bilstein 5100 1.75" lift. Redline Hood Struts.
    I really like this look, and have been considering a similar setup.
    I do have a few questions:
    Did you go with Bilstein 5100's on the front with 1.75 lift?
    I understand you went with the stock FJ wheel tire combo. I understand the tire is larger than comes on the TRD Off Road package (what I have), but I'm curious if the backspacing is the same on the FJ wheels as the TRD Off Road wheels.
    Any rubbing issues?
  4. Oct 8, 2012 at 12:02 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Looks good :thumbsup:
  5. Oct 8, 2012 at 12:03 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Looks good!
  6. Oct 8, 2012 at 12:04 PM
    cgs2k2
    cgs2k2 old man
    Looks great!
  7. Oct 9, 2012 at 1:11 PM
    canyonchaser
    Dave
    Utah
    LR TRD PRO MT
    The FJ Cruiser wheels are identical to the TRD Off-Road wheels. Same offset, everything. I am running a fairly conservative 265/75-16.
    I did bilstein 5100's all around - all four corners.
    I used the OEM springs on the front (Sport springs are different than Off Road springs) - I set the front Bilsteins to the second from the top setting.
    Before the Wheelers HD rear leaf and Bilsteins I'd get a little bit of rub while turning, and going through big dips. Now, no rubbing.
    dp
  8. Oct 11, 2012 at 9:35 AM
    alphanumericone
    Thanks for the info... I think I'm just going to do the front at the 1.75" setting (I think that's what you did). Objective it to level the truck, so I don't think I need to do the back, but may just to have the matching shocks all around.
    a
  9. Oct 11, 2012 at 9:51 AM
    canyonchaser
    Dave
    Utah
    LR TRD PRO MT
    If you only do the front, the back will look really saggy. As mine has settled its much closer to level now.
    I feel the best performance upgrade was adding the HD Add-a-leaf on the rear (with the bilsteins on the rear too). Makes the truck a lot more usable for loads and towing.
    dp
  10. Oct 12, 2012 at 4:15 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I like the look - did you leave in the overload leaf or did you remove it?
  11. Oct 13, 2012 at 8:18 AM
    canyonchaser
    Dave
    Utah
    LR TRD PRO MT
    I really waffled on that one - but decided to leave it in. Now that the truck has settled it looks about perfect methinks.
    dp
  12. Oct 13, 2012 at 10:27 AM
    Polymerhead
    Missouri
    I agree - looks great.
  13. Oct 15, 2012 at 3:25 PM
    alphanumericone
    Just purchased. Decided on all four corners. Will consider AAL later if it's nose high and/or I end up needing more rear spring in the future (not much towing/hauling so far).
    Appreciate your input!
  14. Oct 15, 2012 at 3:40 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    Truck looks good with the lift, :thumbsup:
  15. Oct 17, 2012 at 9:05 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    looks awesome Dave :) It will serve you well.
  16. Oct 27, 2012 at 5:57 AM
    donwsmith56
    donwsmith56 Member
    Don
    jackson, NJ
    2012 TRD OF access cab
    Love the look of the fj rims on your truck, your pics have made me decide to go the same way. Since I am having 5100's @ .85 (front of course) installed on all four corners I'll have them change the rims at the same time. Truck looks great with The lift and rims.
    Hope there's a market for the old rims and bilsteins, truck has 400 miles on it.
  17. Oct 27, 2012 at 8:00 AM
    canyonchaser
    Dave
    Utah
    LR TRD PRO MT
    Thank you!
    I actually plasti-dipped my old wheels black and left the old tires on them and was able to sell them locally for $400.
    dp
  18. Oct 29, 2012 at 6:34 AM
    BOONDOCKSAINT
    BOONDOCKSAINT Well-Known Member
    Central Louisiana
    WHITE 2016 DC OFF ROAD 4X4
    Pioneer 400w amp Infinity Reference Ref 6x9 (front doors) Infinity Reference Ref 6 1/2(rear doors) Kicker HS 8" hideaway
    Sub'd for info, This is the look I want for my truck. How is the everyday ride for you? I have flip flopped on getting Eibach's, 884's, or 885's so that the ride would remain close to the same.
  19. Oct 29, 2012 at 7:16 AM
    canyonchaser
    Dave
    Utah
    LR TRD PRO MT
    Well, since I used the OEM springs on the front and the rear 3-leaf HD AAL is progressive, the ride is actually better. It's not harsh or anything like that. The better shocks provide excellent damping, so the truck deals with seams and tracks corners better better than it did new.
    The only downside I've noticed is an extremely slight sudder during take-off, but even this has improved to virtually un-noticable as the rear leafs settled a bit.
    dp
  20. Oct 30, 2012 at 5:45 AM
    BOONDOCKSAINT
    Central Louisiana
    Thanks for the feed back, This is exactly what I was looking for. I was having a hard time pulling the trigger, I wanted to keep the cost down, but didnt want a rough ride. I have an 07 DC SPORT so I feel confident that my OEM springs will be fine. I think I will follow your lead :D
