Wheelers 3 leaf AAL issue with install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tectonic, Jul 31, 2016.
  1. Aug 3, 2016 at 6:12 AM
    Tectonic
    Tectonic [OP] Well-Known Member
    James
    Tucson, AZ
    12 TRD Sport DCSB 4wd
    Bilstein 5100 all around OME 884 Wheelers 1.5" 3 leaf progressive aal 255/75r17 Hankook Dynapro ATM ARE camper shell Hella Sharptones (4)
    Thanks. Work in progress. Got my OME coils and SPC UCA's to put on soon.
    I've done aal a few times now and I've had really good luck with DuPont Teflon spray to get rid of squeaks:
    https://www.amazon.com/gp/product/B00D3G6IFE/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
    The bike tube fix seems to work for people too
  2. Aug 3, 2016 at 6:19 AM
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    FWIW, I have the new recall springs with a Wheeler's 3-leaf AAL installed and I did not have any problems. I would call Wheeler's before you write them off.
  3. Aug 3, 2016 at 7:15 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Wasn't planning to write them off, just meant it was good to know. I know they say 1.5" of lift but is that what you got out of them? I actually don't want that much but this option seems like the best.
    rstuart likes this.
  4. Aug 3, 2016 at 7:20 AM
    Tectonic
    James
    Tucson, AZ
    I'll get back to you on the lift amount, I think I made a mark on a board somewhere in my garage. It's also a little hard to say exactly how much lift the leafs are responsible for because I removed the overload (I guess just subtract the thickness of overload...). Sounds like you'll want to do the same and remove the overload, which is what Wheeler's recommends anyways
    TACO TX[QUOTED] likes this.
  5. Aug 3, 2016 at 7:23 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I have after lift measurements in my thread here, but not befores. But we both have 2015s which have the same 3+1 leaf pack. You can compare my after to your current.
    https://www.tacomaworld.com/threads/baja-tx-pro-kit-icon-aal.385619/
  6. Aug 3, 2016 at 7:44 AM
    Arailt
    Dallas, TX
    2019 GX460
    You'll get ~1.5" without the factory overload leaf and ~2" with it.
    I had the 1.5 Progressive AAL on both my old 2+1 springs and now my new 3+1 recall leafs and got the same amount of lift from both setups.
    Here is my current to show clearance. Passenger side rear (behind axel).
    AA9F640C-51A3-4D77-AB6E-2768CCB57104_zps_f85fd691ba820ebc168886ed052e9090848ac2a4.jpg
    TACO TX[QUOTED] and Tectonic[OP] like this.
  7. Aug 3, 2016 at 10:39 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Installed the same wheelers AAL on my truck yesterday and ran into the same issue. I had to grid the brackets off in order for it to clear. Mine is a 2012 DCSB as well with the factory 3+1 leaf pack.
    Tectonic[OP] likes this.
  8. Aug 3, 2016 at 10:43 AM
    MilesToEmpty
    MilesToEmpty Well-Known Member
    Charles
    Frederick Co, MD
    '13 Baja TX
    Wheelers Progressive AAL, Firestone RideRite airbags.
    I also had to grind off my clips. Which sucked because I had to go out and buy a new grinder lol.
  9. Aug 3, 2016 at 4:42 PM
    Tectonic
    James
    Tucson, AZ
    There are tens of us, maybe even dozens! Definitely a good idea to make sure you have to right tools if you're reading this prior to install and think you might have this issue. 1/4" steel with ~1/2" rivet is no joke if you're ill prepared
  10. Aug 3, 2016 at 6:46 PM
    icegrill
    icegrill Well-Known Member
    Oregon
    2015 Tacoma TRD (sold) bmw F80 M3 current
    What is the verdict for 2015 oem leaf springs needing to have a band cut?
  11. Aug 3, 2016 at 6:48 PM
    TACO TX
    Kelly
    Denison ,Texas
    So far some seem to fit and some need a clip cut off is what I have come up with.
  12. Aug 3, 2016 at 6:50 PM
    icegrill
    Oregon
    Wow thanks for the quick response, I have the icons waiting in my install que
  13. Aug 3, 2016 at 6:53 PM
    TACO TX
    Kelly
    Denison ,Texas
    The icons seem to fit without any problems but the Wheelers seem to be good for some and not for others. I think there must be different springs with clips in different places for some to fit and some to interfere.
    YotaDan likes this.
  14. Aug 3, 2016 at 7:48 PM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    It's probably a manufacturing issue or quality control issue. I think they are just not putting the clamps in the same spot on every batch so on some they rub and some not. Could also be the oem leafs also have this issue where sometimes the clips are in different spots. All you can do is try to install what you have if doesn't fit then it's time to cut some metal. If you have a grinder and some patience then it's not that bad. Another member did a write up and had a good approach, first cut the side off the bracket so the leaf will come away from the others, then drill out the top of the rivet and punch it down and out. This way seems to be easier and you don't need a grinder, could use a sawzall to cut the bracket and some drill bits.
  15. Aug 4, 2016 at 12:38 PM
    #35
    Tectonic
    James
    Tucson, AZ
    You can probably remove the wheel, line up your Icon leaf set to your stock leafs, and see if there will be overlap with the clips. 10 minute exercise that might help you gauge how long your install is going to take
  16. Aug 4, 2016 at 1:01 PM
    #36
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    You have an off road which I believe even the 2015's still have the 2+1 leaf pack in the rear, so you shouldn't have an issue with hitting the clips. This seems to be an issue with the TSB leafs.
  17. Aug 4, 2016 at 7:17 PM
    #37
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    All 2015s have the 3+1 leafs.
  18. Aug 5, 2016 at 2:43 PM
    #38
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    I installed the wheelers hd 3 leaf and it cleared the brackets fine. 2011 o/r. sounds like the moved that bracket 2012 and up?
  19. Aug 5, 2016 at 4:17 PM
    #39
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    No looks like it's only on the TSB leafs which older OffRoads do not have.
  20. Sep 15, 2016 at 10:31 AM
    #40
    mrSM1TTY
    mrSM1TTY Well-Known Member
    Charlotte, NC
    2015 TRD Off-Road
    I have a 2015 off road DCSB and just purchased a set of the Wheelers 3 leaf AAL's. What's the consensus regarding potentially having to deal with this issue? I guess I could do what @Tectonic recommended before diving into the install. Just want to be sure I'm prepared before getting started.
