Wheeler's 3 leaf progressive AAL - Cutting alignment brackets
Discussion in 'Suspension' started by Ronn, Jan 21, 2013.
  1. Jan 21, 2013 at 12:53 AM
    Ronn
    Ronn [OP] Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    Called Wheeler's the other day about their progressive AAL. They gave me the measurements:
    Short side 15 inches from centering pin
    Long side 18 inches from centering pin
    Apparently there are different styles of TSB springs that were installed on our trucks. Mine is an 07 DCLB SR5 4x4 and has factory TSB leafs. The bracket to the front measures 17 inches and the rear bracket measures 16 3/4 inches, so I would have to cut one.
    Just wanted to post this as an FYI so you can measure first and know if you need to cut or not. I'm sure there are others like me who would want to know this kind of info before buying. Hope this helps someone.
