Wheeler's 3 Leaf vs All Pro 3 Leaf
Discussion in 'Suspension' started by qckslvr2234, Feb 28, 2012.
  1. Feb 28, 2012 at 6:37 PM
    qckslvr2234
    qckslvr2234 [OP] Well-Known Member
    Maryland
    06 Double Cab
    5100's at 2.5, taco lean spacer, Wheelers 3 leaf aal, sway bar relocate, Nitto terra grapplers 285/70/17, spidertrax, custom fishing rod holder, afe drop in filter, 15% tint on front 35% on back, access original roll up cover, BHLM, LED's in cupholder, Plasti-dip badges
    Which is better in your opinion?
    Can you use them with or without you overload in place?
    I occassionally tow a boat so which one will handle better as mainly daily driver conditions with occassional towing involved?
  2. Feb 28, 2012 at 7:33 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I'm sure they're pretty much the same. Wheelers are made by alcan, icons are made by deaver but not sure who makes the AP's. I'd say they're pretty equal. To keep some towing capability you can leave the OL in. Flex and offroad ride will be affected but heavy loads without the OL will sag them and you'll start bottoming out! Youll have 2"+ lift with the OL.
  3. Feb 28, 2012 at 7:39 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    Not that it's conclusive or anything but in my searching and asking around Wheelers got a lot more recommendations and praise. I'm sure either will suffice and in all probability not be all that different in performance but Wheelers had the rep from what I found.
    hope that's at least slightly helpful
