Wheelers "5-Leafspring" group buy???
Discussion in 'Group Buys' started by DTRD, Feb 23, 2011.
Thread Status:
Not open for further replies.
  1. May 17, 2011 at 7:38 PM
    #381
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Thanks! Definitely agree with you on the settling, which should be expedited when I re-install my camper shell in a couple of weeks. (The new suspension has been installed less than 24 hours, and has only about 100 miles on it.)
  2. May 18, 2011 at 10:29 AM
    #382
    billk
    billk Active Member
    Huntersville,north carolina
    1996 Tacoma 4x4 X-cab
    Broke my seat so it is all the way back, now the wife can't drive it
    Here is my 96 after the new rear leafs. Job didnt take to long, went in real easy. Truck rides much better, even seems smoother. Wonder if I can do this to the wife's rear end??
    ROlla-Xrs likes this.
  3. May 18, 2011 at 8:11 PM
    #383
    Norton
    Looks good! Definitely agree with the better/smoother ride - more controlled.
    :rofl: Wrong forum for that, I'm afraid...
  4. May 19, 2011 at 3:01 AM
    #384
    billk
    billk Active Member
    When I removed the leafs, both were marked as Right. Did anyone else have this problem??
  5. May 19, 2011 at 9:35 AM
    #385
    scocar
    scocar hypotenoper
    Whoa. I didn't. Are the leafs OEM? Do they say MEXICO on them?
    Did you have lean? Because one leaf is longer than the other, or at least they are for 2001-04. Not sure if that is true for 96.
  6. May 20, 2011 at 8:03 AM
    #386
    billk
    billk Active Member
    Ohhh yeah it leaned, both were same size, and they were OEM. Must have been a Friday made truck.
    The ride now is so nice, it is like a new truck. I just thought that was the way it was when I bought it in 98 at 2 years old.
  7. Jun 10, 2011 at 10:07 PM
    #387
    Norton
    After a LOT more visits to the shop and time on the alignment rack than I care to remember, I finally ended up replacing the steering rack bushings. While not happy with the unexpected cost, I couldn't be happier with the result. Highly recommended, if you have trouble getting a good alignment or your steering feels sloppy after installing your lift.
  8. Jun 11, 2011 at 9:10 AM
    #388
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Yup, mine had a few degress of positive camber in the front after installing the matching coils. Was fine out on the highway, but it got a little darty out on the freeway and at those speeds.
  9. Jun 14, 2011 at 5:23 AM
    #389
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Did you guys get new brake lines after you got your 5 leaf packs installed?
  10. Jun 15, 2011 at 9:47 PM
    #390
    Norton
    I didn't.
  11. Jun 16, 2011 at 7:59 AM
    #391
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    no
  12. Jun 16, 2011 at 9:24 AM
    #392
    scocar
    scocar hypotenoper
    No. But need to. I have scared myself a couple times just cycling the axle to full droop to change shocks, etc.; it is very easy to max out the stock line. This has convinced me it is necessary and it is high on my list.
  13. Jun 16, 2011 at 9:57 AM
    #393
    YellowDog01
    04 4x4
    I think Wheeler's included a brake line with my kit. Is a new brake line easy to put on or should I let the shop do it for me?
  14. Jun 16, 2011 at 10:16 AM
    #394
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If your OK with bleeding the brakes, it is a fairly simple process. Replacing the line will likely introduce air into the system. The brakes will have to be bled after that.
  15. Jun 16, 2011 at 1:16 PM
    #395
    YellowDog01
    04 4x4
    Hmm...Never bled brakes before. I'll have the shop look at it
  16. Jun 26, 2011 at 7:27 PM
    #396
    YellowDog01
    04 4x4
    The leaves are side specific right? The end of the letters has a "L" and a "R", so I'm guessing those are telling me which side goes where
  17. Jun 26, 2011 at 9:05 PM
    #397
    Norton
    Yes they are. You're guessing correctly.
  18. Feb 29, 2012 at 1:32 PM
    #398
    TACOMIKE09
    TACOMIKE09 Well-Known Member
    Escondido,CA
    Panda'd 03 Dbl Cab TRD 4x4
    Bilstein 1500's all around, Alcan 5-leaf pack w/add-a-leaf, custom tube bumper up front w/two 7" old-school Cibie Driving Beams
    Is this group buy discount still available?
  19. Feb 29, 2012 at 2:19 PM
    #399
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    nope, but there is a new one forming! check the GB section!
Thread Status:
