"Wheeler's Anonymous"
Discussion in 'Southern California' started by SlipperyTaco, Apr 5, 2016.
  1. Feb 9, 2018 at 8:43 PM
    Kens04Taco
    Kens04Taco Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Lol I’m just messn around boss, haven’t been on the thread in a while.
    itaro likes this.
  2. Feb 9, 2018 at 8:45 PM
    oni06
    oni06 Well-Known Member
    I know.
    itaro likes this.
  3. Feb 9, 2018 at 8:48 PM
    eon_blue
    Azusa, CA
    itaro, dtaco06 and MadTaco461 like this.
  4. Feb 9, 2018 at 10:27 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Lol
    itaro and dtaco06 like this.
  5. Feb 10, 2018 at 5:51 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    I can help you with that kieth. You should just need help with the visual inspection
    dtaco06 and oni06[QUOTED] like this.
  6. Feb 10, 2018 at 8:57 PM
    oni06
  7. Feb 10, 2018 at 9:19 PM
    oni06
  8. Feb 12, 2018 at 9:06 AM
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    Yeah it's close. When Kyle checked mine at 70mph I was really going 78.
    eccracer104 and dtaco06[QUOTED] like this.
  9. Feb 12, 2018 at 9:17 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    How are you liking your new Kangs?
  10. Feb 12, 2018 at 9:31 AM
    Tacoma1192
    Tacoma1192 GD MOTORSPORTS
    Kyle
    Boise, ID
    2015 DCSB Sport
    39's, LT, 4 Link, Spidertrax 9"
    Yep. youll still want to check it against GPS when you can. Your 4.88 gears comes into play as well. That calculator assumes no changes in gearing.
    dtaco06[QUOTED] likes this.
  11. Feb 12, 2018 at 9:34 AM
    Tacoma1192
    Kyle
    Boise, ID
    2015 DCSB Sport
    It could be where 4runners have the speed sensor placed. if it is used off the ABS Tone ring then gear ratios will not affect it. but if it a speed sensor on the out put shaft of the transmission, then yes, it will come into play.
  12. Feb 12, 2018 at 10:09 AM
    Tacoma1192
    Kyle
    Boise, ID
    2015 DCSB Sport
    you are correct. Toyota uses the ABS Tone ring at the wheel. gears do not matter. just wheel hub speed. So yes, 70 MPH is 78-79 actual. My whole comments in this section are total irreverent. I don't know shit.
  13. Feb 12, 2018 at 11:33 AM
    oni06
    They worked great off road. On road they are a bit stiff with the 700lbs coils (I was on 650 lbs before) but not worth the time to swap the coils out. Eventually will add a winch up front and if that still isn't enough Ill change the aluminum front bumper to a steel one.
    sdsurfer[QUOTED] likes this.
  14. Feb 12, 2018 at 11:36 AM
    eon_blue
    Azusa, CA
    They'll break in and start to feel better over time, I noticed that with mine. Really stiff at first but after a few wheeling trips they softened up. The winch will help too.
    oni06[QUOTED] likes this.
  15. Feb 12, 2018 at 11:45 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    That’s about what mine reads. Scan gauge correction was 12% on my truck.
  16. Feb 12, 2018 at 2:20 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Yeah it sounds good, you could go a little further and get the manufacturer specs for your stock size and current size and get the *true* speed differential, it will be more accurate than what the generic calculator says. I'm not much of a fan of generic calculators, some models of tires of the same size can actually vary by a lot like 1/2"+
  17. Feb 12, 2018 at 6:03 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    They sure look nice! I’ve heard nothing but good things about the Kings. Haha... any excuse to add new stuff to the taco!
    MadTaco461, oni06[QUOTED] and itaro like this.
  18. Feb 12, 2018 at 6:35 PM
    BandanaBerg
    BandanaBerg Yotas Yotas Yotas Pocast
    Phoenix,AZ
    2010 DCLB SR5 4x4
    Up Front; Icon 2.5 Extended w/ Fox 600s, Icon Delta Joint UCAs, Poly Performance Taco Tabs, BAMF Hybrid Bumper, Pelfreybilt Legacy IFS Steel Skid, RCI Transfer Case Skid Out Back: Archive Garage Hammer Hangers w/ High Clearance Cross Bar, OME Dakar Expedition Pack, Icon 2.0 RR, All Pro U-Bolt Flip w/ Super Bumps, All Pro Extended Brake Lines, Trail Gear Rock Assault Bumper w Custom Swing Tire Carrier Wheels & Tires: Pro Comp 5001 Wheels 16" on some 285/75/16 BFG AT KO2, ARB Single Compressor Up Top & Around: RCI 5° Rock Sliders, CaliRaised LED Premium Roof Rack w/ CaliRaised LED Dual Function Light Bar, CaliRaised LED Amber Fogs in CaliRaised LED LED Fog Light Pod Replacement Brackets, Anytime Fog Mod, CaliRaised LED Ditchlight Fogs on CaliRaised LED Low Profile Ditch Light Brackets, Voswitch UV100 Switch Controler, Chineseum Chase Ambers & reverse/camping LEDs Misc Thangs: Tech Deck w Ram Ball Mounts, Expedition Essentials 2nd Gen Rail w/ Ram mounts...
    Yessir!
    We’re Locked in the Rear!
    I’ve got a winch!
    Done!
    :quickdraw:
    “We Overland Bro!” :rofl::rofl::rofl:
  19. Feb 12, 2018 at 6:46 PM
    BandanaBerg
    Phoenix,AZ
    2010 DCLB SR5 4x4
    I’m running about 75-6mph @ 70mph on the dial according to my GPS... :notsure:
  20. Feb 12, 2018 at 8:23 PM
    BLKTRUCK
    BLKTRUCK Where’s @ODNAREM?
    The Privilege
    Find Ron
    ICON 2.5, ARB bumper, ICON 2.0 RR, Dakar leaf pack, Maxtrac spindles, Moto Metal wheels,
    I get 9 in the white privilege.
    itaro, MadTaco461 and dtaco06[QUOTED] like this.
