"Wheeler's Anonymous"
Discussion in 'Southern California' started by SlipperyTaco, Apr 5, 2016.
  1. Jun 17, 2016 at 10:09 AM
    #2341
    SlipperyTaco
    SlipperyTaco [OP] Slippery when Wet
    Chandler, AZ
    04 Tacoma 4x4 & 2014 4Runner Trail Premium
    FOX 2.5 C/O, CAMBURG UCA, FOX 2.0 REAR, SMP CUSTOM FRONT BUMPER, BAMF LCA SKIDS, SCS RAY 10 MATTE GREY WHEELS, 305/70/16 BFG KO2, ALL PRO STANDARD LEAF PACK, ALL PRO SLIDERS, U-BOLT FLIP KIT, MARLIN CRAWLER REAR BUMPER, TIMBREN REAR BUMPSTOPS, WHEELERS SS BRAKE LINE F/R, D-BADGED, GIBSON CAT BACK, K&N CAI, LINE-X , GREY WIRE MOD, APOLLO 3.0 SHROUDS, D2S XB 5500K HID BULBS, LED HALOS, LED DEMON EYES, TRS LED BULBS, BHLM, IGGY PODS, CALI RAISED PODS, 30" CALI RAISED 4D LIGHT BAR, BESTOP SUPERTOP, TRASHAROO , WET OKOLE SEAT COVERS. 4 RUNNER- 2014 TRAIL PREMIUM W/KDSS KINGS FRONT AND REAR DIRT KING BALL JOINT UCA METAL TECH LONG TRAVEL SPRINGS METAL TECH UPPER/LOWER LINKS SONORAN STEEL KDSS TRACK BAR URD EXHAUST URD Y PIPE URD MAF CALIBRATOR PEDAL COMMANDER PRINSU ROOF RACK RIGID ADAPT LIGHT BAR SCS SR8 17" GUNMETAL 285/70/17 FALKEN WILDPEAKS TRS FOG LIGHTS TRS HID KIT SS OFFROAD SLIMLINE WITH SIDE PROTECTION COASTAL REAR SWINGOUT HEFTY FAB SKIDS
    Ya they cost a shit ton of money.. CVJ is fine never done it myself but heard good stuff about them
  2. Jun 17, 2016 at 10:13 AM
    #2342
    SlipperyTaco
    Chandler, AZ
    Are they better then toyota oem or is cvj just more cost efficient?
  3. Jun 17, 2016 at 10:15 AM
    #2343
    SlipperyTaco
    Chandler, AZ
    ahhh nice nice. I am a boot blowin machine :(
  4. Jun 17, 2016 at 10:18 AM
    #2344
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    I'm doing both sides, so x2 axles from them, plus inner and outer boot upgrades.
    x2 axles $198
    x2 red boots $85
    x2 blue boots $70
    shipping $50
    $402 total if I get my old ones back to them to re-coupe the core charge- I guess the shipping would add to the total cost.
    Figured this is the best route for price to quality ratio if not doing a DIY rebuild. I hope the boots are worth it. IMO my OEMs at 200K miles had more life in them, the ~2" lift killed the boot.
    snowboard704[QUOTED] likes this.
  5. Jun 17, 2016 at 10:22 AM
    #2345
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea my oem boots lasted 170k until I got a little lift, then the passenger side went out... Then a few months later the driver side went out
  6. Jun 17, 2016 at 10:26 AM
    #2346
    alex.busta
    alex.busta Mall Crawler
    Alex
    North OC, Cali
    2016 DCSB TRD Sport 4X4
    Trail Paint Job!
    So I have a question.
    I've really been torn on getting tires. Primarily because I've spent so much on this truck in the last 8 weeks.
    The bigger I go, the more $ for tires and the more $ for modifications needed so I don't rub.
    Is a tire that is more or less, 1" taller and 1" wider worth it?
  7. Jun 17, 2016 at 10:28 AM
    #2347
    SlipperyTaco
    Chandler, AZ
    Ive gone through 4 boots @ 85k miles 3 inner and 1 outer
    Yes :) >.>
    alex.busta[QUOTED] likes this.
  8. Jun 17, 2016 at 10:36 AM
    #2348
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    What size are you at now? 32?
    I've wheeled with a buddy that has about 1 inch smaller an running a 10.5 width an he struggled climbing a little rock pass which got me nervous, my truck walked right up it with no traction issues. Same psi, same tire
  9. Jun 17, 2016 at 10:36 AM
    #2349
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    Taller is definitely better. Wider is more for the good look. You get true ground clearance with a taller tire.
  10. Jun 17, 2016 at 10:37 AM
    #2350
    alex.busta
    Alex
    North OC, Cali
    Trail Paint Job!
    I'm a 265/70/17 so 31.62" x 10.43"
  11. Jun 17, 2016 at 10:38 AM
    #2351
    planesane
    planesane Well-Known Member
    2015 white Tacoma limited 4x4
    6 inch rough country lift kit, Kings shocks front and rear, Deaver leaf pack, 4xinnovations shackle flip, 6 inch shackle, front, rear bumpers , rock sliders, warn winch, 35 inch tires
    Tire size is very important. The size of your tire will give you more ground clearance and when you air down more contact patch. When you go larger rubbing is almost always an issue but don't be discouraged by that. You want to trim around and allow that wheel to move. Do it right or do it twice
    alex.busta likes this.
  12. Jun 17, 2016 at 10:41 AM
    #2352
    alex.busta
    Alex
    North OC, Cali
    Trail Paint Job!
    Okay, so I need to just suck it up and get 285's. Got it!
    Nicklovin and eon_blue like this.
  13. Jun 17, 2016 at 10:42 AM
    #2353
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    I went from a 265/70r16 to a 285/75r16 an couldn't be happier. Bigger/aggressive look, notice alittle bit compared to stock acceleration wise with 410 gears. But then again, I didn't buy a truck to race??
    Helps a lot with height clearance and track width, front rubbed a bit so pulled the trigger on some 5100s (temporary). Minor frame rub so I threw a small spacer on:facepalm:. Trimmed some plastic an pinch weld mod an now only rub flexed out turning.
    Nicklovin and alex.busta[QUOTED] like this.
  14. Jun 17, 2016 at 10:43 AM
    #2354
    SlipperyTaco
    Chandler, AZ
    YES!
  15. Jun 17, 2016 at 10:43 AM
    #2355
    planesane
    If you are searching around on the forums you will probably find somebody with a similar build to yours and the tire size you are Desiring. That will give you an idea what kind of trimming and hammering you need
  16. Jun 17, 2016 at 10:45 AM
    #2356
    planesane
    Wheel spacer can push your wheel out a little more too. That gives it a more aggressive stance as well as improving the width. The farther your tire is out the more articulation you have
  17. Jun 17, 2016 at 10:46 AM
    #2357
    SlipperyTaco
    Chandler, AZ
    Just keep cutting until the rub is gone :D
    Nicklovin, alex.busta and dtaco06 like this.
  18. Jun 17, 2016 at 10:57 AM
    #2358
    alex.busta
    Alex
    North OC, Cali
    Trail Paint Job!
    Yeah @Sandtaco has the same truck and with said tire size. He showed me what needs to be done. CMC and pinch weld mod.
    I have the CMC being done tomorrow if @Yotamac is able to work it in with my compressor install.
    I'll talk to him about the pinch weld. I think I should be able to do that myself though.
  19. Jun 17, 2016 at 10:58 AM
    #2359
    eon_blue
    Azusa, CA
    So this is what I'm going with, going to stick with the billies...I know a lot of folks don't like the ride quality but I'm not bothered by a stiff ride, and this will give me the funds left over for the new tires that I'm surely going to have to get like @MADSTEEZE is going through right now lol.
    Going with the OME 881 coils and the HS progressive 3 leaf AAL, and add a diff drop kit. Should end up with a 2" lift, maybe slightly higher in the rear.
    Should I add the UCA's? :goingcrazy:
  20. Jun 17, 2016 at 10:58 AM
    #2360
    alex.busta
    Alex
    North OC, Cali
    Trail Paint Job!
    I have Konig Countersteer Typ X with -10mm offset, so I don't think I need wheel spacers? :notsure:
