"Wheeler's Anonymous"
Discussion in 'Southern California' started by SlipperyTaco, Apr 5, 2016.
  1. Aug 4, 2016 at 10:18 AM
    #6421
    Maggot61
    Maggot61 Well-Known Member
    Jose
    Sky Valley, CA
    2005 Tacoma Prerunner 4.0L
    "If I'm gonna die, I'm gonna die historic on the fury road!"
    Ya the frame kit is what i'm looking at.
    Mike likes Tacos likes this.
  2. Aug 4, 2016 at 10:19 AM
    #6422
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    You can use a straight Allen T handle with the Allen close in size to the holes on the King shock collar, or King sells a T handle one, or they have me a straight one. Pretty much looks like a straight rose tapered at one end that fits into the shock.
    Most of the time you can adjust on the truck itself (front should be jacked off the ground) unless there's too much crap in the way for the tool to turn it.
  3. Aug 4, 2016 at 10:19 AM
    #6423
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    I bought the one with the little angle at the end to hive more leverage. I got to adjust mine too cause Im off level by 1/2" right now. Probably working on the truck next weekend. I'll let yall know
  4. Aug 4, 2016 at 10:21 AM
    #6424
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    220 is Definatly the way to go, much smoother and all around better if you have the wiring for it
    alex.busta and Mike likes Tacos like this.
  5. Aug 4, 2016 at 10:21 AM
    #6425
    Mike likes Tacos
    Northridge,CA
    2014 4x4 DCSB
    I dont think you can adjust with the straight tool once installed. Cause the resivoir hose gets in the way. The t handle with the angle tip makes it way easier. Anyways thats what I read a while back.
  6. Aug 4, 2016 at 10:23 AM
    #6426
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    I've only adjusted them last night to where I thought they needed to be, after driving today we'll see where they settle tonight if I need to crank them a tad more, waiting on alignment until I get them where I want them. Or unless I can find a place with some kind of a warrenty
  7. Aug 4, 2016 at 10:26 AM
    #6427
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    That may be the case, I remember checking it out last night an at full droop there looked like a little room if the resi was unscrewed from the bracket, we'll see:ballchain:
  8. Aug 4, 2016 at 10:27 AM
    #6428
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Going to have to confirm with @SlipperyTaco since we were talking about doing it at his place, I think he's still on vacation though. We were looking at next Sunday the 14th
    Looking like a high of 85* for MJT on Saturday :bananadance:
    alex.busta likes this.
  9. Aug 4, 2016 at 10:28 AM
    #6429
    socalktk
    socalktk Well-Known Member
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Kings, Pelfreybilt skids, mobtown sliders, dakars, SCS
    http://www.kingshocks.com/products/parts/tools/
    Don't I actually need the spanner wrench or just their T=handle?
    i want to move the top coil nut lower, to show more thread, to raise the front end a little. I was told the most you want is about 8 threads showing..
    snowboard704 likes this.
  10. Aug 4, 2016 at 10:29 AM
    #6430
    socalktk
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    ya'll arent thinking of going up to big bear that weekend with @JDEMELLO and the TTORA.com group?
  11. Aug 4, 2016 at 10:30 AM
    #6431
    eon_blue
    Azusa, CA
    Myself and I think @MADSTEEZE were going to do just a day run on the 13th (Saturday)
    Camping at Pismo the following weekend so I need to get a mod day in to get a few things prepped and ready :cool:
  12. Aug 4, 2016 at 10:32 AM
    #6432
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Spanner wrench is nice to use when the coil is off the truck, there won't be enough room for adjustments with that specific wrench in your case. The extended T handle is the way to go
  13. Aug 4, 2016 at 10:45 AM
    #6433
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Sweet. I've always considered ADS
  14. Aug 4, 2016 at 10:48 AM
    #6434
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Anybody want to be a pal and give me a rundown of how exactly the clickers on shocks work? I've messed with mine a bit and don't notice much difference. I think if I understood what was happening when I turn the dial it would help.
    I know. I'm an idiot.
    Thanks!
  15. Aug 4, 2016 at 11:01 AM
    #6435
    Mike likes Tacos
    Northridge,CA
    2014 4x4 DCSB
    I hear ADS is really good. You really cant go wrong with King, Fox, Icon, or ADS. All very well known and have great reviews.
    I dont know exactly. Im sure youll find a good thread if you google it.
  16. Aug 4, 2016 at 11:07 AM
    #6436
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    From research I've done it seems like the adjusters are really only for fine tuning. If your looking for more of a durastic change on the shock, then different shim setup is necessary.
    Filthy motorsports has a great YouTube video explaining how it all works.
    Basically the resi has its own shim stack and by adjusting the knob "stiffer" it's harder for the shock oil to work its way through the piston in the resi making the shock itself stiffer.
    If you were to adjust the knob on the resi softer, the oil can more easily go through the piston in the resi making the shock compress faster an therefore be "smoother"
    Hope that little explanation helped allitle:notsure:
    https://m.youtube.com/watch?v=29T9-xGy380
  17. Aug 4, 2016 at 11:12 AM
    #6437
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Only thing about icons is I know some people were having issues with cracking, I'm pretty sure icon worked it out though image.jpg saw it on a older tacomaworld thread
  18. Aug 4, 2016 at 11:42 AM
    #6438
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Thanks! That helped a ton!
    snowboard704[QUOTED] likes this.
  19. Aug 4, 2016 at 12:29 PM
    #6439
    Mike likes Tacos
    Northridge,CA
    2014 4x4 DCSB
    You need to bring that truck out with us man. You gotta a lot of nice stuff we can help ya put to work.
  20. Aug 4, 2016 at 12:33 PM
    #6440
    Mike likes Tacos
    Northridge,CA
    2014 4x4 DCSB
    @MADSTEEZE ,@eon_blue ,@digitaLbraVo . Think I'm in on this MJT Saturday. Probably be able to get my foreman to cover for me. :fingerscrossed:
    Gotta finish getting my lights set up by then.
    digitaLbraVo, alex.busta and eon_blue like this.
