"Wheeler's Anonymous"
Discussion in 'Southern California' started by SlipperyTaco, Apr 5, 2016.
  1. Aug 11, 2016 at 11:26 PM
    #7301
    goblue82
    goblue82 Well-Known Member
    The Dude Abides
    Southern California
    Click muh sig
    POR-15 for those drilled holes and you'll be protected from rust.
    :thumbsup:
    ODNAREM and eon_blue[QUOTED] like this.
  2. Aug 11, 2016 at 11:26 PM
    #7302
    eon_blue
    Azusa, CA
    Drilling straight into the metal according to the mounting instructions. Though the write-ups I've read suggest laying down a rubber seal and using sealant that I'll be picking up from the hardware store before I do the install.
  3. Aug 11, 2016 at 11:31 PM
    #7303
    DesertDunes
    DesertDunes Well-Known Member
    Cole
    Coachella Valley. CA
    2012 Super White Tacoma TRD OR DCSB
    Overland Stuff
    I bet that rack will hold A LOT of weight once installed. I installed my rack onto the OEM rack which is only supposed to hold about 100lbs. I currently have a Plano case that holds a shovel, axe, tow strap and misc tools. I have traction boards up there, lights and an ARB awning. I'm probably over the weight limit but its seems to be holding up just fine. I want to add a high-lift but I dont believe I can. I'll have to save for a year and get a Prinsu
    ODNAREM, alex.busta and eon_blue like this.
  4. Aug 11, 2016 at 11:34 PM
    #7304
    eon_blue
    Azusa, CA
    According to the note that was included by Smittybilt with the rack, they don't recommend going over 150lbs. As long as it'll hold my hi-lift, a shovel, maybe a jerry can and a few miscellaneous tools then I'll be set
    ODNAREM, alex.busta and snowboard704 like this.
  5. Aug 11, 2016 at 11:35 PM
    #7305
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Should work good for what you have in mind! Too much weight up there will be too top heavy anyways:notsure:
  6. Aug 11, 2016 at 11:36 PM
    #7306
    eon_blue
    Azusa, CA
    True...I might need to counter the weight with a few hundred lbs worth of sandbags in the bed, lol
    goblue82, ODNAREM and DesertDunes like this.
  7. Aug 11, 2016 at 11:37 PM
    #7307
    DesertDunes
    Cole
    Overland Stuff
    I can't notice the weight on my roof. Only thing I notice is the LOUD howling that it makes.
    SixthSnail likes this.
  8. Aug 11, 2016 at 11:38 PM
    #7308
    DesertDunes
    Cole
    Overland Stuff
    I also have load e KO2's so maybe that helps??
  9. Aug 11, 2016 at 11:38 PM
    #7309
    eon_blue
    Azusa, CA
    yeah the write ups I read mentioned that as well :( oh well, it'll be my truck's signature "howl"
  10. Aug 11, 2016 at 11:39 PM
    #7310
    eon_blue
    Azusa, CA
    I have E load KO2's as well :amen:
  11. Aug 11, 2016 at 11:40 PM
    #7311
    DesertDunes
    Cole
    Overland Stuff
    It only bothered me for the first month or so. Now I'm used to it. I does get annoying on the freeway if you're driving for hours. Like the trip to pismo will suck lol
  12. Aug 11, 2016 at 11:40 PM
    #7312
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Just turn up the music:rofl:
    I've got a vibe about 65-70 so that's what I do.. have chased the problem for some time now with only dead ends:annoyed:
  13. Aug 11, 2016 at 11:42 PM
    #7313
    DesertDunes
    Cole
    Overland Stuff
    I had a nasty vibe around 60. Balancing the tires and an alignment fixed it
  14. Aug 11, 2016 at 11:43 PM
    #7314
    DesertDunes
    Cole
    Overland Stuff
    Now I have a clicking sound that only happens when I brake hard. IDK what it is but its pissing me off
    snowboard704 likes this.
  15. Aug 11, 2016 at 11:44 PM
    #7315
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Wish it was that simple.. have got an alignment last week, retorqued all bolts, drive shaft rebalanced and checked out, checked u joints, checked carrier bearing, checked wheel bearings.. Kinda over it at this point:bananadead::ballchain:
  16. Aug 11, 2016 at 11:50 PM
    #7316
    DesertDunes
    Cole
    Overland Stuff
    My reason is I have a bestop
    eon_blue and snowboard704 like this.
  17. Aug 11, 2016 at 11:52 PM
    #7317
    eon_blue
    Azusa, CA
    I'm getting a Softtopper in the future, plus I want to mount my lights on the roof and have a little extra storage up there.
    I'm sort of on an expo-build I guess, lol.
  18. Aug 11, 2016 at 11:54 PM
    #7318
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    I'm also looking into soft tops, like the fact that I can sleep in there an also be able to take my dirtbike around when it's down without having to deal with storing a hard top
  19. Aug 11, 2016 at 11:57 PM
    #7319
    eon_blue
    Azusa, CA
    Yup, plus I think the utilitarian look of them suits the first gen Tacoma look really well. I also like the idea of being able to remove/install it with ease, kind of reminds me of the removable tops on the first gen 4runners back in the day (kind of a stretch, but still).
  20. Aug 11, 2016 at 11:58 PM
    #7320
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Sliders welded on are removable with some grinding. Holes in roof are permanent. Make sure you seal it with a generous amount of silicone.
    They advertise way less than it can actually hold just to be safe.
    Get a Prinsu, I really liked mine on my Tacoma. Held my tent just fine.
    You should be okay. I never felt too top heavy with my tent up there
    Mine was bad on the tacoma. When I put the lightbar in this rack, it got bad too. I fixed it since then though.
    You guys with softoppers should talk to billy from @Bruteforce Fab about making a skeleton for the softopper. I had an idea to make an internal skeleton that came through the top of the canvas in order to be able to mount a roof rack on it and hold a lot of weight. I ended up getting a shell for cheap but I really wish I went that route. Billy and I talked about it a bit and he was interested. I'd still love to see somebody do it!
    alex.busta and eon_blue[QUOTED] like this.
