"Wheeler's Anonymous"
Discussion in 'Southern California' started by SlipperyTaco, Apr 5, 2016.
  1. Sep 26, 2016 at 9:41 PM
    eon_blue
    Azusa, CA
    Yup, that sounds like me. Manual trans here but there's the occasional "thud" going into first and sometimes other gears. I never paid it that much attention because the R150F transmission is stout but notoriously 'clunky'. But that combined with the grinding/vibrations I'm feeling may be u-joint related.
    So many potential things :annoyed: And I guarantee you when I take it to Toyota tomorrow they'll tell me they can't replicate any of it. I guess at the very least I could ask them to take a close look at my u-joints, LBJ's and bushings for me.
  2. Sep 26, 2016 at 9:42 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Pretty sure switching out to a longer spring won't really help at the same rate. A lower rate spring will make it more compliant. Maybe a 500 at 14"
  3. Sep 26, 2016 at 9:47 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    That's how I understand it as well. The difference will be negligible. All it will to is move the coil adjustment higher up the c/o. The only way it would help is if you have so much preload that the spring is limiting bump travel. Stiffness is affected more by cal wing than spring rates. In simple terms the spring sets ride height. Ride characteristics are more affected by rebound and compression.
  4. Sep 26, 2016 at 9:53 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    The spring on it now is 650#, maybe go 14" 600#?
    Do you think they could be rebuilt and revalved to be softer in the beginning of the stroke? Or would the change in valving affect the entire length of travel?
  5. Sep 26, 2016 at 9:54 PM
    goblue82
    goblue82 Well-Known Member
    The Dude Abides
    Southern California
    Click muh sig
    @Speed Freek , Curious of your insight on this topic as well. Thoughts?
  6. Sep 26, 2016 at 9:55 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Call up a shop for a quote on a carrier bearing and ujoints. They're wear items, might be worth being replaced unless you know if they were already done recently.
  7. Sep 26, 2016 at 9:56 PM
    MadTaco461
    CA
    Kinda stock
    I think @YotaGurlIAm is trying to tune out the washboard roads. It's pretty hard to tune out that frequency with coilovers while still being able to to take hits. Might need to air out more.
    ODNAREM, dtaco06 and YotaGurlIAm like this.
  8. Sep 26, 2016 at 10:01 PM
    YotaGurlIAm
    YotaGurlIAm Well-Known Member
    Madison
    Arizona
    2008 4.7L - wait..I’m on the wrong forum.
    Stuff n' Thangs
    Yes, but even just normal trails, small bump here and there, speed bumps on streets, minor pot holes.. Haha after driving mikes truck many times, I just am reminded how stiff mine feels
  9. Sep 26, 2016 at 10:03 PM
    MadTaco461
    CA
    Kinda stock
    Try a revalve first since it is cheaper. Then move to spring change if that won't fix it.
    YotaGurlIAm[QUOTED] likes this.
  10. Sep 26, 2016 at 10:05 PM
    YotaGurlIAm
    Madison
    Arizona
    Stuff n' Thangs
    Yeah that seems like the best bet now. There's rust peeking through the chipped powdercoat on the coils, so eventually id like to get some new ones for piece of mind
  11. Sep 26, 2016 at 10:06 PM
    YotaGurlIAm
    Madison
    Arizona
    Stuff n' Thangs
    Tbh, not sure if extended or not. I'll probably just revavle for now and see if that helps
    dtaco06[QUOTED] likes this.
  12. Sep 26, 2016 at 10:09 PM
    MadTaco461
    CA
    Kinda stock
    During the revalve you change out a spacer...boom extended travel bitches
  13. Sep 26, 2016 at 10:10 PM
    ForcedFedTaco
    ForcedFedTaco Well-Known Member
    Cerritos, CA
    2013 Tacoma DCSB-OR
    TRD Shift Knob
    What are the details? I'm down to go Saturday.
    ODNAREM likes this.
  14. Sep 26, 2016 at 10:19 PM
    goblue82
    The Dude Abides
    Southern California
    Click muh sig
    Had downsouth delete that spacer when they built them. Best advice I've gotten to date to get extended travels without paying the extra couple hundred duckets.
  15. Sep 26, 2016 at 10:42 PM
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    Nothing specific as of yet, on wednesday I'll talk to ppl and get some details down
  16. Sep 27, 2016 at 6:12 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    I have been doing a little bit of reading on this topic as I just got some used icons. As I understand it with any coilover, digressive or progressive the valving and shims can be changed to whatever the user is wanting/using the shock for. They come from the factory with an overall baseline settings but with a revalve you can change them to be more responsive and smooth at slower speeds or vice versa no matter if they are king, icon, fox etc. Essentially changing your factory digressive shock to a progressive one and the other way around if you choose. still trying to educate myself on suspension set-ups myself so I am :popcorn: as well for your outcome :)
    As for your spring rate madison, I would agree that sounds like a lot right now(650#) with your current front end set-up. But if you are planning to install full skids? Winch? And so-on? in the near future it might be something to think about before you choose to change your springs to something else?
  17. Sep 27, 2016 at 6:30 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
  18. Sep 27, 2016 at 6:50 AM
    FirstGen Jer
    Jeromey
    Lord Helmet likes this.
  19. Sep 27, 2016 at 7:27 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    What about being on payment in 4x?, straight line of course.
    Hi and low
  20. Sep 27, 2016 at 7:28 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    I see you :alien:
    ODNAREM and Lord Helmet[QUOTED] like this.
