"Wheeler's Anonymous"
Discussion in 'Southern California' started by SlipperyTaco, Apr 5, 2016.
  1. Oct 12, 2016 at 2:51 PM
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    Sure is. Especially for somebody who hits the dirt regularly.
    Nicklovin likes this.
  2. Oct 12, 2016 at 2:52 PM
    mercurymullet
    mercurymullet Well-Known Member
    gary
    el cajon/lakeside
    can't afford a toyota
    bronco frame under a mountaineer
    One of my pull vehicles had vinyl. Loved it!!!!l
    I use a leaf blower to clean now. Lol
  3. Oct 12, 2016 at 2:57 PM
    Maggot61
    Maggot61 Well-Known Member
    Jose
    Sky Valley, CA
    2005 Tacoma Prerunner 4.0L
    "If I'm gonna die, I'm gonna die historic on the fury road!"
    I'm going to be cleaning/washing the floors and seats this weekend and i'm dreading it right now! it's been way too long since i've done it and i'm dirt regularly as well.
  4. Oct 12, 2016 at 3:03 PM
    Mike likes Tacos
    Northridge,CA
    2014 4x4 DCSB
    Lol. I have to leave that to the car wash guys. I'm kind of a clean freak so I can't clean the truck it takes me forever. Way too detailed about it.
  5. Oct 12, 2016 at 5:41 PM
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    So @WileECoyote any news on whether or not you can come Friday?
    WileECoyote likes this.
  6. Oct 12, 2016 at 5:44 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    I have two new method double standards. 1 is still in the box
  7. Oct 12, 2016 at 5:47 PM
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    Holy hell, didn't give that part a thought about the CAT? @Nicklovin Nick, there should be 2x O2 sensors B1S1 and B1S2 (bank 1 sensor 1 and bank 1 sensor 2... before and after the CAT, respectively), which code did it say it was?
    dtaco06[QUOTED] likes this.
  8. Oct 12, 2016 at 5:48 PM
    WileECoyote
    SoCal
    Not yet.
    Nicklovin[QUOTED] likes this.
  9. Oct 12, 2016 at 5:53 PM
    YotaGurlIAm
    YotaGurlIAm Well-Known Member
    Madison
    Arizona
    2008 4.7L - wait..I’m on the wrong forum.
    Stuff n' Thangs
    Willing to sell? :) How much?
    ODNAREM likes this.
  10. Oct 12, 2016 at 6:23 PM
    Kens04Taco
    Kens04Taco Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Help please! Lol hi guys...soooooo I got my new kings and I installed them on my truck. The came with a 2 inch lift setting on them. It was a struggle to get them on. I had to pry down the lower control arm to get the lower bolt in. I tried to adjust them and I can't get to the holes in the coil over because the upper control arm is blocking them. I'm concerned I'm going to drive to work tomorrow and something is going to happen. Has anyone put coil overs like mine on stock control arms? Any suggestions? Am I just being a pussy? Lol. I called 4 wheel parts and they told me 400 to adjust them. Totally rape. Can you please help me?
    eccracer104 and Nicklovin like this.
  11. Oct 12, 2016 at 6:32 PM
    glorifiedwelder
    jason
    Santa Clarita, ca
    I have install king co's on a 1st gen with stock uca's. King says their coilovers aren't meant to be adjusted on the truck. It's a bitch. I've adjusted them but had to make two wrenches with varying angled handles to get a full rotation out of the upper collar.. are you trying to lower the front?
    dtaco06 and itaro like this.
  12. Oct 12, 2016 at 6:34 PM
    glorifiedwelder
    jason
    Santa Clarita, ca
    I want $100 per wheel. I'd prefer to sell the one in the box first, just mounted a tire on the other one in case I need another full size spare
    YotaGurlIAm[QUOTED] likes this.
  13. Oct 12, 2016 at 6:34 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Yeah I'm trying to drop the front to either 1 inch or stock height. I drove it up and down the street and it seemed ok but I just don't want to get on the freeway and have a failure
  14. Oct 12, 2016 at 6:36 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Why would there be a failure? Nothing's gonna happen
    dtaco06 and 4Running Daily like this.
  15. Oct 12, 2016 at 6:38 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Being honest, I have no experience with coil overs and it just seems like the ball joints are pressed kind of tight. Maybe I'm just freaking out for no reason
  16. Oct 12, 2016 at 6:42 PM
    glorifiedwelder
    jason
    Santa Clarita, ca
    Jack the front up from the frame and check your clearances around everything(it will need to be jacked up like this to adjust the c/o's well. You don't want to adjust the spring under the trucks weight. Too much risk of the coil carrier jumping the threads). If you have clearance your good. It will also probable settle .5-1 inch. I want to say your 100% good, but am hesitant as I can't be their to visually inspect the rest of your install, but if everything is correctly installed then you are 100% good with the amount of lift it has. Even if you lowered the spring it won't shorten your coil stroke any, so the extended length of the shock will still be the same and pose the same issues with over extending things at full driop
  17. Oct 12, 2016 at 6:46 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Lol ok thanks guys. I'll just take it slow and maybe just get it aligned tomorrow
    itaro likes this.
  18. Oct 12, 2016 at 6:57 PM
    glorifiedwelder
    jason
    Santa Clarita, ca
    I'm not that far up the freeway from you. When it isn't hunting season I'm in the shop every night and work in the valley so if you ever need a hand with something let me know.
    eccracer104 and itaro like this.
  19. Oct 12, 2016 at 7:12 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Thanks man I appreciate that. If it wasn't my daily I wouldn't stress so much. lol
  20. Oct 12, 2016 at 7:22 PM
    eon_blue
    Azusa, CA
    I feel your pain
