"Wheeler's Anonymous"
Discussion in 'Southern California' started by SlipperyTaco, Apr 5, 2016.
  1. Feb 16, 2017 at 9:45 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
    Trucks looking good man. With my calculation of MPG I think your getting more like 11mpg. That's pretty much what I'm getting. Once I'm over my tiny 285/70-17's I'm going to 35's. Then lockers and re-gear for sure to try to bring back the MPG. Looks good bud.
  2. Feb 16, 2017 at 9:50 AM
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    I thought the gas tank was like 17 gallons..? Maybe wrong. I figured there's about 1 gallon left once the lights on. Again I maybe wrong cause thats how I figured it.
  3. Feb 16, 2017 at 9:51 AM
    eon_blue
    Azusa, CA
    Light's supposed to come on with 2-3 gallons left I thought, with the first gens it's 2. something IIRC
    goblue82 likes this.
  4. Feb 16, 2017 at 9:56 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    When I fill up my truck after the light turns on I fit 18ish gal.
  5. Feb 16, 2017 at 10:00 AM
    Mike likes Tacos
    Northridge,CA
    2014 4x4 DCSB
    I got 16.335 when I filled up after light came on. Hmmm gonna have to research this a little more. Dont really care about mpgs or gas cost too much only curious
    goblue82, MotoEd[QUOTED] and Maggot61 like this.
  6. Feb 16, 2017 at 10:04 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    21 gallons
  7. Feb 16, 2017 at 10:05 AM
    Mike likes Tacos
    Northridge,CA
    2014 4x4 DCSB
    So confused... I don't know if I have ever seen more than 17 gals when filling up....
    goblue82 and MotoEd like this.
  8. Feb 16, 2017 at 10:07 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    Fuel tank capacity is 21gal. That's total capacity, not at fill-up. If your putting 21gal in at fill-up, you were driving on fumes. Typically when the light turns on, it takes just around 18 to fill. At least that's what it's been taking in my truck. Only once I put 19.8 in it. That was coming back from mammoth, towing a trailer fully loaded with camping gear and family. Filled up in Mojave. I was sweating it when I pulled in. Still had an extra 5gal that I always carry but I was still puckered waiting for that gas station to appear.
    ODNAREM, dtaco06, goblue82 and 2 others like this.
  9. Feb 16, 2017 at 10:11 AM
    Lord Helmet
    Nick
    '24 X3 M40i
    I agree. If you manage to put 21 gallons in the tank, there's some possibility of damage to the fuel pump and engine. I.E.; overheating of the fuel pump because the fuel is what helps keeps the pump cool. Also starving the engine of fuel...common sense
    ODNAREM and goblue82 like this.
  10. Feb 16, 2017 at 10:17 AM
    eon_blue
    Azusa, CA
    First gens have an 18 gallon tank (at least the 4x4 v6 does) so makes sense the 2nd gens would be bigger at 21 gallons
  11. Feb 16, 2017 at 10:28 AM
    Kens04Taco
    Kens04Taco Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    I tapped off a rectangular section around the perimeter of the emblems. Then I was careful on how I held the can because you don't want the dip to build up along the edges. I tried to keep the can perfectly up and down. Sprayed about 4-5 coats and ten minutes after the last coat pulled the tape off and the layer that was against the fender peeled off. Then I just did some minor detail work with a flat tooth pick. The emblems on the tail gate are proving to be more difficult.
    eon_blue[QUOTED] likes this.
  12. Feb 16, 2017 at 10:49 AM
    YotaGurlIAm
    YotaGurlIAm Well-Known Member
    Madison
    Arizona
    2008 4.7L - wait..I’m on the wrong forum.
    Stuff n' Thangs
    Do you usually cap out at 15 though?
  13. Feb 16, 2017 at 10:51 AM
    eon_blue
    Azusa, CA
    I fill up right before the light comes on usually, which gets me about 15 gallons at the pump...I'd have to look at the manual again but I'm almost positive the light is supposed to come on with either 2 or 2.5 gallons left
    YotaGurlIAm[QUOTED] likes this.
  14. Feb 16, 2017 at 11:17 AM
    YotaGurlIAm
    Madison
    Arizona
    Stuff n' Thangs
    yeah same, I hate driving on the light
    ODNAREM and Lord Helmet like this.
  15. Feb 16, 2017 at 11:20 AM
    goblue82
    goblue82 Well-Known Member
    The Dude Abides
    Southern California
    Click muh sig
    Bingo! Us 2 gens are 21.1 gallons. Most I've got in was 18. Wasn't happy about that since the pump is in fact inline cooling.
  16. Feb 16, 2017 at 11:26 AM
    goblue82
    The Dude Abides
    Southern California
    Click muh sig
    Still unsure where my light comes on. My pops is a stickler and doesnt like his fuel to drop below half. Lol
    ODNAREM, 4WALKER and Maggot61 like this.
  17. Feb 16, 2017 at 11:31 AM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    When the light turns on I usually have around 4gal left in the tank, on "E" there is usually around 3ish. After my needle drops slightly below "E" is stays in the same position and doesn't move anymore, most I have ever put in was a little over 19gal.
  18. Feb 16, 2017 at 11:33 AM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Don't forget to adjust the mileage for the bigger circumference of your new tires. Not sure what tires your running, if they are toyos then they are pretty true to labeled size, if they are bfg's they are usually a good deal smaller i.e.; a set of 37x12.5x17 ko2's come out to about 35.4". But either way since your speedo is off so is your odometer. You're probably going about 12% farther than your odometer is actually reading.
  19. Feb 16, 2017 at 11:33 AM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    anyone wheeling Azusa this weekend? Or advise against it?
    Mike likes Tacos likes this.
  20. Feb 16, 2017 at 11:36 AM
    stvstoy
    stvstoy Well-Known Member
    Northern Utah
    3rd Gen
    See Sig
    @SlipperyTaco I think it's time we rename this thread 'Gas Tanks Anonymous' :anonymous: :deadhorse:
