"Wheeler's Anonymous"
Discussion in 'Southern California' started by SlipperyTaco, Apr 5, 2016.
  1. Sep 9, 2017 at 8:52 AM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    An alignment tech didn't even tighten my passenger front cam bolt last alignment. Hand tight at best!
  2. Sep 9, 2017 at 9:06 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
    Please list all clunk locations. I got pops and cracks and clunks coming from my front end bad. When I'm stopped turning the wheel from lock to lock, rolling and turning into a parking spot, coming to a stop at a red light, accelerating from a stop, going up into a driveway, going down a driveway, climbing over rocks, coming down off a ledge, pretty much anytime. No sway bar by the way.
    MadTaco461, tcjacado, LOLLY and 3 others like this.
  3. Sep 9, 2017 at 9:55 AM
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    -Torque LCA and UCA bolts to spec
    -Wheel alignment can be off. If you normally go to the same place it may be worth having a different shop do it especially if you do not run factory specs.
    -Turn wheel back and forth while somebody looks at your steering rack bushings. You will see movement and noise here if its the problem.
    -Worn out UCA uniballs. Remove the UCA bolt and check for play in uniball.
    -Broken misalignment spacer on shocks. They can break from abuse and I've seen em get rusty and break. I had one side of my kings break within a year.
    -Loose or worn tie rod end
    -Bent spindle
    -Lower ball joints. Check for torn boot.
    - Drive shaft U joint or carrier bearing. Check for play in the drive shaft
  4. Sep 9, 2017 at 9:58 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    You da best Mike :thumbsup:
  5. Sep 9, 2017 at 5:26 PM
    eon_blue
    Azusa, CA
    Anyone interested in wheeling tomorrow? Need to put my 4wd to use, it's been too long. Big Bear's getting hit with rain, could be fun
    eccracer104, tcjacado and dtaco06 like this.
  6. Sep 9, 2017 at 5:35 PM
    eon_blue
    Azusa, CA
    Damn that's right I almost forgot about that, hopefully my Kings will be on by then
    dtaco06[QUOTED] likes this.
  7. Sep 9, 2017 at 5:40 PM
    tcjacado
    tcjacado Well-Known Member
    A group of us are headed to pilot truck trail. Meeting at noon silverwood country store.
    eccracer104 likes this.
  8. Sep 9, 2017 at 5:48 PM
    Jimmyboyblue
    Jimmyboyblue Well-Known Member
    Jimmy
    Baja California
    He said he wanted to use his 4wd so no fire roads
    YotaGurlIAm, dtaco06, itaro and 2 others like this.
  9. Sep 9, 2017 at 5:48 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    I believe he said he wants to use 4wd, not 2wd
  10. Sep 9, 2017 at 5:51 PM
    Jimmyboyblue
    Jimmy
    Baja California
    You can be my spotter
    dtaco06[QUOTED] and itaro like this.
  11. Sep 9, 2017 at 6:03 PM
    tcjacado
    o_O:pout::brianr:
  12. Sep 9, 2017 at 6:17 PM
    Mike likes Tacos
    Northridge,CA
    2014 4x4 DCSB
    There is 4WD trails in Pilot Rock. Have you guys ever been their:confused:
    tcjacado, itaro and eccracer104 like this.
  13. Sep 9, 2017 at 6:18 PM
    Jimmyboyblue
    Jimmy
    Baja California
    But he would be by himself with all them 2wd going
    dtaco06, itaro and eccracer104 like this.
  14. Sep 9, 2017 at 6:22 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Go with them. Take that mall crawler out from the speed bump forrest.
    Maggot61, MotoEd, itaro and 2 others like this.
  15. Sep 9, 2017 at 6:26 PM
    Jimmyboyblue
    Jimmy
    Baja California
    Would love to but I'm up in Mexico this weekend
    MotoEd, itaro and eccracer104 like this.
  16. Sep 9, 2017 at 6:44 PM
    eon_blue
    Azusa, CA
    :rofl:you guys are brutal lol
    @JaCado thanks for the invite! I'll run it by the g/f, her brother's in town from Sac and she really wants us to show him Big Bear but I'll run this by her and see what she says; if we do White Mountain/Gold Mountain in BB we'll be doing it solo and that always freaks her out, lol. I'll let you know
    dtaco06 and eccracer104 like this.
  17. Sep 9, 2017 at 6:58 PM
    tcjacado
    I was just offering a run to do is all. Plus at the end we are headed to get pizza and people can purchase raffle tix for total chaos merch, lca, uca, bed stiffeners and support a local womens offroad team.
    eccracer104 and eon_blue[QUOTED] like this.
  18. Sep 9, 2017 at 7:01 PM
    tcjacado
    Thanks Mike, i refuse to explain myself at this point.
  19. Sep 9, 2017 at 7:02 PM
    uhplifted
    Brian
    16 DCLB OR
    You just did....
    1truckdriver and Jimmyboyblue like this.
  20. Sep 9, 2017 at 7:04 PM
    tcjacado
    Was referring to you and boy blue
