"Wheeler's Anonymous"
Discussion in 'Southern California' started by SlipperyTaco, Apr 5, 2016.
  1. Oct 1, 2017 at 3:32 PM
    jtanner21
    jtanner21 Well known scammer
    2004 Tacoma 3.4l Extra Cab
    Sorry should've listed it better.... for any type of LED accessory
  2. Oct 1, 2017 at 4:02 PM
    jtanner21
    Appreciate it man:cool: I'll hit them up. Going camping tonight and I accidentally cut my wiringg harness to all my important lights:( (don't ask)
  3. Oct 1, 2017 at 4:33 PM
    jtanner21
    Was thinking about it... just was being lazy and it was kinda shitty harness, had random wires going everywhere that weren't needed.. was able to pick up one for 15 bucks from local autozone ! So I should be good!
    MotoEd, tcjacado and dtaco06[QUOTED] like this.
  4. Oct 1, 2017 at 6:42 PM
    Big_V
    Big_V Active Member
    Tom
    95 T4R
    95 4runner, SR5, A/C, pwr windows & locks, 3.0 V6, 5spd, 85 T-case 4.7lo w/ Marlin adapter, TG 4" SAS w/ 85 front axle, longfields, shackle reversal, hi-steer, 56" rear leaf swap, spring-over w/ flipped u-bolts, 5.29 gears, Detroits front & rear, Bilstein 5150's, All-Pro cross member & driveline brake, TG front bumper w/ Warn M8000 winch, Marlin Sliders & rear bumper w/ 4xinnovations tire carrier, Viair on-board air w/ tank, 20# CO2 tank, 35x12.50 BFG KM2's on 17x8 steel soft 8's, custom hand-throttle, Midland CB, LED lightbar, rear lights, & rock lights, Optima Battery
    I kno my rig can handle it, but it'll take awhile :turtleride:
  5. Oct 1, 2017 at 7:08 PM
    kyle11863
    kyle11863 King of the BS
    Kyle
    Big Bear, CA
    1990 Toyota 4Runner SR5 V6 4x4
    Doug Thorley long tube headers and lots of mud
    What's your gear ratio?
  6. Oct 1, 2017 at 8:39 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Wiring is easy. Why not DIY?
  7. Oct 1, 2017 at 8:41 PM
    digitaLbraVo
    Any type? Current draw and distance still matter into wire size.
  8. Oct 1, 2017 at 8:45 PM
    Big_V
    Big_V Active Member
    Tom
    95 T4R
    5.29 :muscleflexing:
  9. Oct 1, 2017 at 9:27 PM
    Big_V
    Big_V Active Member
    Tom
    95 T4R
    You have your rear ds hooked back up?
  10. Oct 1, 2017 at 10:09 PM
    digitaLbraVo
    Did you get your rear end hooked up? Are you driving front wheel drive?
    Sorry haven't been following the threads.
    itaro likes this.
  11. Oct 1, 2017 at 10:14 PM
    Jimmynolife
    Jimmynolife Actually has a life
    Jimmy
    Bend, OR
    3 linked 2002 Tacoma
    I did it! So can you!
  12. Oct 2, 2017 at 9:30 AM
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    I love getting taxed $800 a week and get to pay even more come tax time. I'm just doing my taxes this year and this shit sucks.
    Reason for the rant! The money I had for gears and front locker is going to the IRS. :mad:
  13. Oct 2, 2017 at 9:38 AM
    tcjacado
    tcjacado Well-Known Member
    :facepalm::evil:
  14. Oct 2, 2017 at 9:54 AM
    eon_blue
    Azusa, CA
    Believe me I feel your pain. I don't do primarily freelance work anymore for that reason. But this year I did a couple of big freelancing jobs and I'm going to get hit hard next April for that.
  15. Oct 2, 2017 at 10:01 AM
    eon_blue
    Azusa, CA
    Ok so unless anyone has any tricks up their sleeve for adjusting Kings on the truck, I'm going to take them off to adjust them. Spent hours last night trying to adjust the preload on them, I can loosen the collar and turn them just fine but the problem is my SPC UCA/ball joint is in the way. It blocks one of the preload adjustment holes completely and the others are blocked by the shock housing when that happens, so I'm stuck. I've tried jacking the truck up with the wheel off the truck and there just isn't enough droop happening to clear the UCA/ball joint. It's almost easier to do with the truck completely on the ground, but it's still blocked.
    Only thing I can think of is maybe I need to remove the sway bar to allow for more droop? I'm not even certain that will solve the problem but if it droops more it might clear the collar on the shock so I can access it. I was able to turn the passenger side a few times more than the driver side so now I'm sitting about a half inch higher on the passenger side lol.
    Mike likes Tacos likes this.
  16. Oct 2, 2017 at 10:04 AM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Let me know what you find. Ive got the same damn issue. Except my resi hose is in the way and the shock housing.
  17. Oct 2, 2017 at 10:13 AM
    uhplifted
    Brian
    16 DCLB OR
    Oh ya. Forgot about that lol. I'll have to try that next weekend
  18. Oct 2, 2017 at 10:24 AM
    Mike likes Tacos
    Northridge,CA
    2014 4x4 DCSB
    When I did Chris's when we had the big mod day at his house. Put the front on jack stands then took the floor jack under the LCA to move the UCA out of the way as needed.
    Oneluv13T4R and dtaco06 like this.
  19. Oct 2, 2017 at 11:11 AM
    eon_blue
    Azusa, CA
    Ok cool I'll try that, I had thought about doing the bottle jack trick under the LCA but it was already nearly 11pm so I just buttoned everything back up and figured I'll give it a shot tonight. Started to try to remove the sway bar but one of the bolts holding the end link together is bent, it won't slide out. Might be able to work it out if I take the weight off of it by raising up the LCA with the bottle jack.
  20. Oct 2, 2017 at 11:13 AM
    Mike likes Tacos
    Northridge,CA
    2014 4x4 DCSB
    Gotta ditch that sway bar. All the cool kids are doing it.
