"Wheeler's Anonymous"
Discussion in 'Southern California' started by SlipperyTaco, Apr 5, 2016.
  1. Oct 4, 2017 at 10:41 AM
    Tacoma1192
    Tacoma1192 GD MOTORSPORTS
    Kyle
    Boise, ID
    2015 DCSB Sport
    39's, LT, 4 Link, Spidertrax 9"
    "Lockers"......you son of a bitch...
  2. Oct 4, 2017 at 10:46 AM
    Tacoma1192
    Kyle
    Boise, ID
    2015 DCSB Sport
    Yeah but that's negated by the fact that you have gears and lockers... so it's fine.
    LOLLY, itaro, YotaGurlIAm and 2 others like this.
  3. Oct 4, 2017 at 10:50 AM
    eon_blue
    Azusa, CA
    Danny at 40 yrs old
  4. Oct 4, 2017 at 10:52 AM
    Tacoma1192
    Kyle
    Boise, ID
    2015 DCSB Sport
    Sure... whatever you need to tell yourself to make you feel better, Danny Boy. hahaha
  5. Oct 4, 2017 at 12:57 PM
    Tacoma1192
    Kyle
    Boise, ID
    2015 DCSB Sport
    HA!!! Looks like you only get 1 LOCKER!!! I take back calling you a SOB.
    Edit - Your Still a SOB.
  6. Oct 4, 2017 at 12:59 PM
    Jimmyboyblue
    Jimmyboyblue Well-Known Member
    Jimmy
    Baja California
    Makes me want to blow a ton of money on part I don’t need and will never use ... ughh sucks to be broke
    itaro, dtaco06 and eccracer104 like this.
  7. Oct 4, 2017 at 1:01 PM
    Jimmyboyblue
    Jimmy
    Baja California
    Well good thing is I can buy a top rack for myself from Christmas so that’s something to look forward to
  8. Oct 4, 2017 at 2:03 PM
    Jimmyboyblue
    Jimmy
    Baja California
    Well not sure which one yet but yes leaning towards that one
  9. Oct 5, 2017 at 1:26 PM
    eon_blue
    Azusa, CA
    Question for you ladies and gents, I'm looking into pulling the trigger on a rear suspension setup now (figure I'm on a roll, why stop here...) but I do need to keep it more budget minded this time. The King setup for 1st gens is a 2.5 shock body with resis for ~$800....more than I can really spend right now. However the Icon setup is tempting....they're 2.0 shock bodies and have the remote resi for $530.
    I know Kings and Icons are valved differently so would that end up being too funky of a setup to run (progressive fronts and digressive rears)? I don't want to end up with a weird feeling ride just to save a couple hundred bucks, if that's the case I'll save up for the Kings. Or maybe look into a Fox rear setup.
    eccracer104 and itaro like this.
  10. Oct 5, 2017 at 1:29 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    I would recommend waiting and saving for the kings.
    If you don't want to wait, and are worried about the Icons, you could always look into a 2.0 fox. It may be priced closer to the Icon, and would have progressive valving similar to the kings.
    YotaGurlIAm, eon_blue and itaro like this.
  11. Oct 5, 2017 at 1:32 PM
    eon_blue
    Azusa, CA
    Not fast. Faster than I go now but high speed desert wheeling isn't my thing, I've been around TW long enough to know by now that that kind of wheeling involves a lot more than just shock upgrades. Though I am looking forward to not falling a mile behind the other guys on group runs now lol. But yeah, I'm all about the 4lo and slow (I want a t-shirt that says that btw)
    I don't plan on ever pushing those 2.5 shock bodies to their limits heat-wise.
    That's what I was leaning toward, tempting as the Icon deal is. The Fox's might be the way to go then.
    itaro[QUOTED] and uhplifted like this.
  12. Oct 5, 2017 at 1:33 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Just wait for the KINGs :boink:
    oni06, itaro and eon_blue[QUOTED] like this.
  13. Oct 5, 2017 at 1:34 PM
    YotaGurlIAm
    YotaGurlIAm Well-Known Member
    Madison
    Arizona
    2008 4.7L - wait..I’m on the wrong forum.
    Stuff n' Thangs
    I have icon remote resi in the rear and they feel great, but more so after putting a lot of weight in the back. Depends on what leaf pack also. Foxes are a good choice as well.
    I don't care to be matchy matchy. It feels great and you can always have the icons valved differently down the line.
    eccracer104 and eon_blue[QUOTED] like this.
  14. Oct 5, 2017 at 1:35 PM
    eon_blue
    Azusa, CA
    Ah, I wasn't aware that you had the rear Icons. That's good to know thanks!
  15. Oct 5, 2017 at 1:37 PM
    eon_blue
    Azusa, CA
    No bumps yet, figured I see where I land (pun intended) after riding around on the new setup for awhile. I'll look into the non-resi Kings, probably around the same price as the Icon setup I imagine.
    eccracer104 and uhplifted like this.
  16. Oct 5, 2017 at 1:38 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    You ever get this figured out? The bar barely pulls anything and should not effect the battery at all or even alternator. Hook that light back up cause it's not the issue. Unless you accidentally grounded something out.
    After you disconnect the batery the truck basically is reset and the electronics have to learn again but it'll fix itself by learning.
    Don't forget to swap the stub shaft in the front diff over to the new one, common mistake (what I did) derp. Pretty sure your front diff has it also
  17. Oct 5, 2017 at 1:38 PM
    uhplifted
    Brian
    16 DCLB OR
    get the bumps
  18. Oct 5, 2017 at 1:46 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    :anonymous:
    itaro[QUOTED] likes this.
  19. Oct 5, 2017 at 1:49 PM
    jtanner21
    jtanner21 Well known scammer
    2004 Tacoma 3.4l Extra Cab
    Haven't had time ended up working overtime. Get off in about an hour and was going to try hooking it back up. The bar had a red and black wire with the metal rings on the ends do I ground the negative wire (black) or put it on my negative terminal? Also the relay had a metal bracket is that to simply attach it somewhere to look clean or to ground it
  20. Oct 5, 2017 at 1:50 PM
    uhplifted
    Brian
    16 DCLB OR
    Ground the black wire with terminal somewhere on the truck. The relay shouldnt need to be grounded, the metal may be there to be more sturdy?
    jtanner21[QUOTED] likes this.
