"Wheeler's Anonymous"
Discussion in 'Southern California' started by SlipperyTaco, Apr 5, 2016.
  1. Oct 5, 2017 at 1:54 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    You can put the black wire anywhere you want that grounds it out. On a external fuse block, negative battery terminal, frame etc. easiest is probably negative battery terminal since I'm assuming you don't have a bunch of stuff hooked up to it.
    jtanner21[QUOTED] likes this.
  2. Oct 5, 2017 at 1:55 PM
    jtanner21
    jtanner21 Well known scammer
    2004 Tacoma 3.4l Extra Cab
    I'll try it out ! Hopefully after a few miles the truck starts warming up!
    snowboard704[QUOTED] likes this.
  3. Oct 5, 2017 at 2:00 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yep you have it. Remove it from the diff you have now and hit into the new ecgs diff or you won't have 4x4. And you'll have to take it back out and hit it in like I had to do, not fun.
    dtaco06[QUOTED] and itaro like this.
  4. Oct 5, 2017 at 2:06 PM
    jtanner21
    IMG_2314.jpg Anyone in the Joshua Tree area happen to know how to weld ??:cool: Have a shock relocation kit that I need to slap on here in a week or two. I can supply lots of beer.
    LOLLY and Maggot61 like this.
  5. Oct 5, 2017 at 2:13 PM
    jtanner21
    Hell yea they do! It's one hell of a place :D You free on weekends ?
  6. Oct 5, 2017 at 3:53 PM
    tcjacado
    tcjacado Well-Known Member
    @Maggot61 Anyone you know in the area?
    Maggot61 likes this.
  7. Oct 5, 2017 at 4:01 PM
    Maggot61
    Maggot61 Well-Known Member
    Jose
    Sky Valley, CA
    2005 Tacoma Prerunner 4.0L
    "If I'm gonna die, I'm gonna die historic on the fury road!"
    If your not already set up let me know. We're just on the other side of the hill from you in Sky Valley, I got a guy out here that just welded the motor mount gussets on my truck.
    ODNAREM and tcjacado[QUOTED] like this.
  8. Oct 5, 2017 at 6:14 PM
    jtanner21
    :cheers:
    Jamison tends to lift my spirits !
  9. Oct 5, 2017 at 6:16 PM
    jtanner21
    What's your guys opinions on a smooth body shock vs a bypass.... the TC kit I bought for the rear calls for a 2.0 x10" shock .... should I take advantage of that and go with a bypass? Or a smooth body with a resi. The websites I've seen who carries them says they tune the shocks for you.
  10. Oct 5, 2017 at 6:54 PM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
  11. Oct 5, 2017 at 8:00 PM
    jtanner21
    What would you suggest on the tubes? Can you choose witch way the bypass will face ? They have a piggyback and a hose resi don't they? I'll already have to run 1.25 wheel spacers for the kit
  12. Oct 5, 2017 at 8:38 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    If it requires a 2.0, do not waste money on a bypass haha. Just get a 2.0 x 10 King from DSM and you will be plenty happy. No reason to get something you don't need. You're not gonna be eating whoops with a 2.0 shock, so the on demand tune-ability a bypass provides will not benefit you in any way.
    MadTaco461 and jtanner21[QUOTED] like this.
  13. Oct 5, 2017 at 9:43 PM
    jtanner21
    thanks guys! That makes it a lot easier. And saves me some $. I was kinda bummed the kit only allowed a 2.0 I don't understand why a 2.5 wouldn't fit. It requires you to run 1.25 wheel spacers.... but idk. I'm mainly flying through the desert don't do much if any crawling.
  14. Oct 6, 2017 at 1:13 PM
    eon_blue
    Azusa, CA
    Sooo I changed out my rear diff fluid a couple weeks back when I did my trans. Walked out to my truck at work to have a smoke break a half hour ago and saw that the spot I parked in yesterday had a small oil stain right where my rear diff would've been. Looked under my truck and sure enough, there are a couple drops of gear oil on the drain plug, checked it and it was loose enough to remove by hand :annoyed: I tightened the hell out of that fucker back when I did the change. Fortunately I carry a quart of 75w90 under the back seat in case I ever need it when I'm wheeling. Only took a few squirts to top it off but I'm going to drain/fill it tonight when I get home just to be sure there aren't any big metal shavings/chunks indicating damage.
    That cigarette probably saved me thousands....guess it's a sign I shouldn't quit after all :laughing:
    4WALKER, MotoEd, tcjacado and 5 others like this.
  15. Oct 6, 2017 at 1:15 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Damn I don’t know any smokers (cigarette) in Cali anymore
    Props to ya
    eon_blue likes this.
  16. Oct 6, 2017 at 1:25 PM
    eon_blue
    Azusa, CA
    We're still prevalent in the film/photo industry lol. All the cool kids are vaping these days.
    tcjacado and dtaco06 like this.
  17. Oct 6, 2017 at 1:28 PM
    Jimmyboyblue
    Jimmyboyblue Well-Known Member
    Jimmy
    Baja California
    It’s a 3rd of the cost of cigarettes... what’s a pack cost now 20$ or so
    dtaco06 likes this.
  18. Oct 6, 2017 at 1:29 PM
    PROseur
    Pussy
    Don’t care about vaping peeps
    No talent to be in film photo industry :(
  19. Oct 6, 2017 at 1:31 PM
    PROseur
    Pussy
    $7.40 a pack
    Jimmyboyblue[QUOTED] likes this.
  20. Oct 6, 2017 at 1:33 PM
    eon_blue
    Azusa, CA
    Maybe in New York, lol. American Spirits are probably the most expensive at $10 a pack.
