Wheelers Diff Drop with TRD Pro skid plate - not fitting?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mtnfishing, Nov 11, 2020.
  1. Nov 11, 2020 at 11:13 AM
    mtnfishing
    mtnfishing [OP] Philosophy, Trout-Fishing, Tacomas
    2021 Cement TRD Off-Road 4x4
    Hello Tacoma World,
    I just bought at Wheelers Off Road Diff Drop kit to use in my suspension lift install. I have a 2021 Off Road Tacoma, but I added the Trd-Pro skid plate. The mechanic at Toyota is telling me that the skid plate spacers and bolts with the kit are too short to be used with the Pro skid plate but only work for the Off road stock plates. I called Wheelers and they said that they had never heard of that problem. Has anyone else run into this? Any recommendations on what size bolts and spacers I would need to make it work so that I can reattach the Trd-Pro plate?
  2. Nov 11, 2020 at 11:16 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Why are you running a diff drop at all? 2nd Gen doesn’t need them so I would assume the 3rd Gen doesn’t either
  3. Nov 11, 2020 at 11:32 AM
    mtnfishing
    It was recommended by Toyota when I talked to them about installing the lift. I am just doing a 2 inch lift with the Eibach Pro suspension, so maybe it is not really needed?
  4. Nov 11, 2020 at 11:34 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Yeah not needed at all, you'll be fine without
  5. Nov 11, 2020 at 11:39 AM
    mtnfishing
    Thanks. I just called Toyota and told them just to take off the diff drop - since it looks like it would be more money to get longer bolts and spacers to make the skid plate fit than it cost for the entire diff drop kit in the first place, ugh.
  6. Nov 11, 2020 at 11:43 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I've lifted all 4 of the Tacomas I've owned, currently my 3rd gen is about 2.5" and never dropped the diff. Never had a vibe issue. Most everyone will agree they're not necessary unless you're chasing a vibe problem post lift, and when that's the case I seldom read they solve the problem.
    Post up a pic or 2 when she's done! :cheers:
    mtnfishing[OP] likes this.
  7. Nov 11, 2020 at 11:45 AM
    mtnfishing
    Yeah, I debated whether or not to do it, but since it was only $30 for the kit and it is a brand new truck, that was why I decided to go for it. But, since it makes it impossible to remount my TRD-Pro skid plate (which was $400) without additional cost, I will just scrap the diff drop for now. I figure I can always add it back later if I do encounter any problems, etc.
    Natetroknot[QUOTED] likes this.
  8. Nov 11, 2020 at 1:08 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I did a little over 2 inches on the front, bilstein 5100s and I used a front diff drop and a rear carrier bearing drop also. I also have the TRD Pro skid plate and no issues needing a longer bolt. Maybe the diff drop is not large spacer, the 4wd shop is extremely repudable and and got my angles right on spec. No issues!!!
  9. Nov 11, 2020 at 7:12 PM
    mtnfishing
    So, when I went to pick it up from the Toyota service dept. They showed me all the pics and, yeah, I need basically another inch spacer for the front two and middle two bolts on the skid plate and about 1.5 inch longer bolts for all four of them. I decided just to leave the diff drop on because Toyota told me that it would help me in the event that there was ever a warranty issue. So, now just trying to find the longer spacers and bolts and I will install it myself. Thanks to everyone for the help on this! In case anyone is ever curious, It looks like you need M12x1.25x110 mm for the front bolts, M12x1.25x130mm for the back bolts and then M12x1inch spacers for all four. The back ones just take M8 bolts with half inch spacers. I will confirm once I get it all installed.
    VaToy[QUOTED] likes this.
  10. Jun 8, 2021 at 7:47 AM
    DOC-Q
    DOC-Q Member
    2021 TACOMA TRD OFF ROAD BLACK
    Any update on this mod?? I have recently added a Readylift 3" coilover with a Readylift tophat, Bilstein springs and 6112's in the front that included a diff drop kit. I installed the diff drop after reading the pros and cons and decided to place it due to the fact that many Toyota mechanics recommend it. Anyways, I too added the TRD PRO skid plate and it fit but the diff drop is in contact with the plate. Would there be any issue with the contact? Is there a spacer kit out there that will alleviate the problem? I know they make one for the Tundra.
  11. Jun 8, 2021 at 9:18 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    The diff drop lowers the front diff mounts 1 inch. The centerline of the axles is behind the centerline between the front and rear diff mounts. So the amount of drop at the axles is less than 1/2 inch.
    You could lower your lift by 1/2 inch, remove the diff drop and still have 1/2 inch more clearance than you did lifted with the diff drop.....
  12. Jun 8, 2021 at 10:04 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Does the Toyota OEM lift kit relocate the diff at all?
  13. Jun 8, 2021 at 11:01 AM
    jschwerdtfeger
    jschwerdtfeger Well-Known Member
    Jeff
    Santa Cruz, CA
    2020 Tacoma DLCB TRD Off Road
    Fox 2.5/2.0, Deaver Expo Stage I
    I second (or third) the comments above, no diff drop is needed with a 2"-ish lift
  14. Jun 8, 2021 at 11:07 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Dif drops are snake oil. Remove it and throw it in the trash.
  15. Jun 8, 2021 at 11:11 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
  16. Jun 8, 2021 at 11:40 AM
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    Mine has been lifted 2" for 20k miles and 4 years. Not a hint of vibes (though I did do the ecgs bushing). And I appreciate the extra clearance under the front skid that a diff drop would take away a good chunk of. I'd go with just 1" lift before I did that.
  17. Jun 8, 2021 at 12:13 PM
    DOC-Q
    DOC-Q Member
    This is a true 3" lift, and I actually measured out at 3-1/2" after install, knowing it will most likely settle. From what I'm hearing is take the diff drop spacers out, correct?? If so, why are so many Yota mechanics for them?
  18. Jun 8, 2021 at 12:58 PM
    jschwerdtfeger
    Jeff
    Santa Cruz, CA
    Yup, remove the diff drop. Take a look at the CV boot fins and make sure they're not rubbing each other; if they are rubbing—there are a few threads on how to solve that issue. Springs sometimes take a few months to settle totally; my 650# springs took about six weeks, whereas a set of 600# of a different brand took only about a week. Also, be aware that any lift will strain your needle bearings, and they very well might fail; luckily, it's an easy solution, ala ECGS. Happy truckin'
    DOC-Q[QUOTED] likes this.
  19. Jun 8, 2021 at 12:58 PM
    Marvet85
    Marvet85 Well-Known Member
    2021 Tacoma TRD Off-road
    Just starting.
    Don’t run the diff drop. Best advice i ever took. Maybe get an ecgs bushing when you can. You’ll thank us later
  20. Jun 8, 2021 at 1:15 PM
    DOC-Q
    DOC-Q Member
    Where do you get the ECGS?? Does a shop have to install?
