Wheelers multi AAL with 1/2" shim
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 03f5sp, Sep 21, 2016.
  1. Sep 21, 2016 at 12:42 AM
    03f5sp
    03f5sp [OP] Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    I currently have a 1.5" AAL lift in the rear and it rides poorly. (Every Wisconsin road is full of cracks and or pot holes) My left rear sits slightly lower than the right rear. I'm planning on replacing the single AAL with a 3 leaf AAL and adding a 1/2" shim to correct the lean. I've heard that a rear spacer shim is often ineffective with the stock leaf pack because the left side weight bias overcomes the shim due to the leafs being so weak.
    So here's the question; since I'm adding a 3 leaf multi pack, do you think the 1/2" shim would actually help?
    I'm also thinking about doing a 1" block on the left and a 1/2" block on the right. It's a mall crawler so I doubt I'll have ride quality issues.
  2. Sep 21, 2016 at 4:42 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    do you have the spacer in the front installed?
  3. Sep 21, 2016 at 9:45 AM
    03f5sp
    Bill
    Wisconsin
  4. Jan 11, 2017 at 3:38 PM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    what you end up doing?
