Wheeler's Offroad Steelies
Discussion in 'Wheels & Tires' started by IslandBoy86, Jan 7, 2012.
  1. Jan 7, 2012 at 6:58 PM
    IslandBoy86
    IslandBoy86 [OP] Well-Known Member
    Las Vegas, NV
    I plan on buying Wheelers 16x8 type a wheels. I am going to need the spidertrax 1.25" spacers if I want to run 285/75r16 tires?
  2. Jan 7, 2012 at 6:59 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    No, if you put spacers on those it would make any rubbing you have more severe.
  3. Jan 7, 2012 at 7:09 PM
    TexasTacoma37
    Yes, the wheelers type a steelies already have 4.5" bs, which is ideal for fitting 285s on a 2nd gen. Pushing the wheels out further will increase the width of the turning arc, leading to rub on the outside of the tire in the fender well.
    In fact TW member zombie runner tired running spacers on top of his 4.5" bs rims, stock fenders, and couldn't even turn out of his driveway.
  4. Jan 7, 2012 at 7:13 PM
    bgsmith
    bgsmith Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    I have pro comp steelies with 1.25 Spidertrax spacers due to break caliper rub, had some serious rubbing.
    With the wheelers offroad wheels you should be good even with 285s. Wish I had went with them, but I initially wanted to stick with 17s. Either way I am 100% happ with my truck.
  5. Jan 7, 2012 at 7:15 PM
    Dr_Kevorkian
    Dr_Kevorkian Well-Known Member
    California
    2nd Gen Pyrite Mica AC
    You dont need a spacer with the wheeler steelies, they are guaranteed to clear the caliper. On the other hand, the Summit Racing steelies DO NOT clear the caliper so do not order those if your looking to run wheels without spacers. Just a word of advice.
  6. Jul 18, 2012 at 9:37 AM
    DirtyTaco89
    DirtyTaco89 Member
    Derek
    Hudson, CO
    '12 TRD Off Road Shortbed
    3in pro comp lift, some cosmetics, the rest is yet to come...
    What would be a good tire size to prevent tire rubbing with the 16x8 wheels either AorB on a truck with 3" lift all around?
  7. Jul 18, 2012 at 10:46 AM
    TexasTacoma37
    Get the type A. If you want to trim, 285/75/16, if you don't want to trim, 265/75/16
  8. Jul 18, 2012 at 5:06 PM
    Diablo
    Diablo Well-Known Member
    Calgary Alberta Canada
    09 Double Cab TRD
    So if I wanted to run a 33 x 12.5 with 886 coils upfront and an add a leaf in the rear one would go with the type B?
  9. Jul 18, 2012 at 5:16 PM
    TexasTacoma37
    Still type a. Type b is ideal for first gens.
    You're going to have to do a lot of cutting with that setup either way though.
  10. Jul 18, 2012 at 5:20 PM
    Diablo
    09 Double Cab TRD
    Yea, thats what im worried about. Still on the fence, leaning towards the 285 75 16 right now.
