Wheeler's Offroad T2 Front Coils
Discussion in 'Suspension' started by Kirbstomp1287, Apr 7, 2020.
  1. Apr 7, 2020 at 9:13 AM
    Kirbstomp1287
    Kirbstomp1287 [OP] @MilSpecTaco
    17’ Inferno SR5 V6 DCSB XP
    Has anyone installed these on their truck? Just wondering how much lift it actually gave and how the ride quality is? They are made by Eibach for Wheeler's so I would guess that quality is pretty nice.
  2. Apr 7, 2020 at 9:24 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
  3. Apr 7, 2020 at 9:36 AM
    Kirbstomp1287
    So essentially you would only want to use these with a lot of weight on the front? The OME 887 or the Eibach Pro Lift Coils would probably be better with almost no extra weight?
    Side thought: Can the Eibach Pro Lift Coils even fit the Bilstein 5100's?
  4. Apr 7, 2020 at 9:49 AM
    AccuTune Offroad
    El Cajon, CA
    Yes, you would need an incredible amount of added weight to need those springs. For a cheap lift, those options can work.
  5. Apr 7, 2020 at 3:11 PM
    Kirbstomp1287
    So if my research is correct the regular Eibach Pro Lift springs are also 742lbs but everyone running those says they have excellent ride quality over the stocks even with nothing aftermarket on the front end. Is there something I'm missing?
  6. Apr 7, 2020 at 3:53 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Incorrect. Bilstein pro lift 2.5" silver coils are 620lbs. I am currently running them with my 5100 set at 0. Ride quality is indeed fantastic.
  7. Apr 7, 2020 at 4:31 PM
    Kirbstomp1287
  8. Apr 8, 2020 at 10:43 AM
    Kirbstomp1287
    Just talked to Eibach and their 14" 650lb springs do not fit the 5100's
  9. Apr 8, 2020 at 11:21 AM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    That's odd. Stock length springs are 14". Here is a picture of my Bilstein pro lift 2.5" springs on a 5100. Currently also installed. Depending on where you buy the springs, some distributors will specify it as 610 and some 620.
  10. Apr 8, 2020 at 11:32 AM
    Kirbstomp1287
    I think I see where there may be a disconnect. For some reason on Eibachs website if you are looking for 3rd Gen parts it gives you a different Part Number that is a 2" spring rated at 740lbs. But if you search for 2nd Gen is gives you another part number for 2.5" springs and those may be what you have?
    3rd Gen: https://eibach.com/us/e30-82-069-02-20-2016-2020-toyota-tacoma-pro-lift-kit
    2nd gen: https://eibach.com/us/e30-82-007-03-20-2005-2015-toyota-tacoma-pro-lift-kit
    will.i.was[QUOTED] likes this.
  11. Apr 8, 2020 at 11:32 AM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    I apologise, I did not realize this was for a 3rd gen. Albeit the 3rd gen t1 coil is 15" with .7" wire diameter.
    The springs i have (MPN# E30-82-007-03-20) are 15.75" with .7" wire diameter.
    I was also told to use a specific Eibach pro truck sport shock but I was able to fit the 2.5" on the 5100. The issue I encountered while installing is that the spring is wound pretty tight and I was able to compress it enough to get a few threads started and impacted it down from there.
  12. Apr 8, 2020 at 11:35 AM
    Kirbstomp1287
    No worries, now I am wondering if I could get those to work if it would still give 2.5" of lift instead of the 2" from the ones they have listed for the 3rd gen?
  13. Apr 8, 2020 at 11:40 AM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    I do not think so as the 3rd gens are a bit heavier. It works the other way around as I know 2nd gens gain +1" when installing oem coilovers from a 3rd gen.
    You could however run a small 1/4" spacer in conjunction with the 2" lift coils to gain an additional .5" of lift.
  14. Jun 11, 2022 at 10:07 PM
    CJGT1
    CJGT1 Member
    2018 Tacoma trd sport 4x4
    Ready lift 6”
    I have 6112 and want to put the 31 82 069 02 eibachs but I need a 3” I.D TO FIT YHE 2.5” 6112. Any suggestions
  15. Jun 11, 2022 at 10:08 PM
    CJGT1
    CJGT1 Member
    Ready lift 6”
    Looking for a 700lbs eibach
  16. Jun 11, 2022 at 10:11 PM
    CJGT1
    CJGT1 Member
    Ready lift 6”
