wheelers' progressive aal insight needed
Discussion in 'Suspension' started by 92dlxman, Oct 28, 2012.
  1. Nov 25, 2012 at 8:36 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Yes. Slightly
  2. Nov 25, 2012 at 8:39 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    FTFY
  3. Nov 30, 2012 at 11:25 AM
    jcjr73
    jcjr73 Well-Known Member
    Michigan
    12 Sport 4x4 black
    westen step bars, flipbak cover
    If you install an AAL can you still use the stock rear shocks or do you have to upgrade?
  4. Nov 30, 2012 at 11:27 AM
    650H1
    Michael
    VA
    depends. I used my stock billies for a while with the wheelers 3-leaf. they were ok, but you "top" them out easily. they are pretty much at max flex with an AAL, so you have no room to flex or go over bumps without topping them out. which will ruin the seals over time, NBD if you plan to get new shocks like I did, just didn't have the money at the time, and wanted a deal on something. in the end, I ended up having to cut my stock ones off the truck anyways so it really didn't matter that I used them with the AAL.
  5. Nov 30, 2012 at 11:41 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Stock billies being the ones that came with the truck, correct? I know Dan mentioned that with the OL leaf still in that the lift would be around 2.25". The 5100 is supposed to be for up to 1.5" of lift..called wheelers and jonny said it should be fine unless im jumping the truck or doing something with enough force to pull the shock apart..which I don't plan to do.
  6. Nov 30, 2012 at 12:17 PM
    jcjr73
    Michigan
    12 Sport 4x4 black
    yes, what I have is a 2012 Sport double cab LB with Billies. Love the truck!!
    Just put 2.5 lift in front to level but am thinking of the 1.5 AAL for rear and then at larger wheels.
  7. Nov 30, 2012 at 1:26 PM
    650H1
    Michael
    VA
    Yea you should be fine. I have fox 2.0's in the back
