Wheeler's Steel Wheels
Discussion in 'Wheels & Tires' started by Gossamer, Jun 21, 2010.
  1. Jun 21, 2010 at 6:53 PM
    Gossamer
    Gossamer [OP] Howard Roark
    Guys...should i order Type A or Type B? I have a 2010 OR. I don't want them to stick out too far with my 265/75/16 but want them to stick out farther than my stock...which are a +32mm offset, right? That should equal a BS more than 5, right?
  2. Jun 21, 2010 at 7:07 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The Type A have 4.5" BS, while the Type B have 4" BS. The less backspacing, the more they will stick out. Stock backspacing is 5.5".
  3. Jun 21, 2010 at 7:08 PM
    Gossamer
    that's what i was thinking...i knew the stock BS was higher than 5...someone tried to tell me stock was 4.5. Thanks for confirming.
  4. Jun 21, 2010 at 7:20 PM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    13 Taco Double Cab TRD
    Bilstein 5100's all around, front set at 2.5", Toytec AAL, 265/75/16 Duratracs, Pro Comp 5001, Weathertech's, AVS In Channel Visors, Nokya Hyper Yellow fogs, CB Set up, Color matched grill surround, ATC Camper Shell with Yakima Racks, SOS Concepts Regular Rear Bumper.
    I'm pretty sure stock backspacing is4.5 and not 5.5
  5. Jun 21, 2010 at 7:23 PM
    whitetaco02
    whitetaco02 Well-Known Member
    Frank
    GA
    09 Tacoma 4x4
    Tinted windows, stainless steel drop hitch, rear TSB, Marathon seat covers in Realtree AP camo, low profile chrome toolbox, husky liners front and back, debadged
    Will the 4.0 BS work though? I thought it needed to be at least 4.5??
  6. Jun 21, 2010 at 7:27 PM
    KPT
    09 Prerunner
    Nope, see this thread....stock BS for the TRD offroad is 5.25 (I was thinking of the TRD sport when I said 5.5)
    4.5" BS is the most popular choice for aftermarket wheels for tacomas because they allow you to fit 285's (after a 3 inch lift), by pushing the wheels out around an inch over stock.
  7. Jun 21, 2010 at 7:28 PM
    KPT
    09 Prerunner
    4.0 pushes the wheels out FURTHER than 4.5....
    What do you "need" it to be 4.5" for?
  8. Jun 21, 2010 at 7:41 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    Type B 4.0 back spacing. these are great rims :)
  9. Jun 21, 2010 at 8:35 PM
    whitetaco02
    Frank
    GA
    09 Tacoma 4x4
    I thought I remember reading where a guy had 16x8 rims he was trying to fit on his 2nd gen taco and they would not clear the break calipers. That is what I meant by "need".
  10. Jun 21, 2010 at 8:37 PM
    Blue
    Dylan
    Sierras
    i was going to get the cragar soft rims or something like that but was told that they wouldn't clear the caliper so i went with wheelers type B and have no regrets
  11. Jun 22, 2010 at 5:22 AM
    KPT
    09 Prerunner
    Ah, well that has way more to do with the type of rim than the backspacing. A little less backspacing will help, but there are some brands of 16" rims that won't fit.
    The wheelers ones fit fine, as they were designed for tacomas.
