Wheeler's Super Bumps
Discussion in 'Wheeler's Off-Road' started by YotaDan, Dec 29, 2009.
  1. Apr 29, 2013 at 9:20 AM
    #401
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Ya, I heard the timbrens are the perfect length to prevent the shocks from bottoming out...but the rebound is teeeeerrible...so I'm wondering if I can run these and just invert them to the frame bump spots and add some washers
    +the price difference lol
  2. Apr 29, 2013 at 9:22 AM
    #402
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    Timbrens suck! haha they are great for towing etc but if your looking to romp they rebound too hard making you buck like crazy.
  3. Apr 29, 2013 at 9:26 AM
    #403
    VolcomTacoma
    Jeff
    NorCal
    Yes. Exactly. However, they are the right length to prevent shock from bottoming out...that being said, I don't have any, nor do I want to buy them...I do however want to turn Superbumps into the correct length.
  4. Apr 29, 2013 at 9:30 AM
    #404
    PLC721
    Patrick
    Chandler, Az
  5. Apr 29, 2013 at 9:34 AM
    #405
    VolcomTacoma
    Jeff
    NorCal
  6. Jun 6, 2013 at 1:47 PM
    #406
    marintacoma
    marintacoma Well-Known Member
    San Luis Obispo
    2004 white toyota tacoma 4x4 trd
    saw 2.5 coilovers, wheelers 3 leaf AAL, bilstein 5100 dynomax exhaust
    So what can we order to make these work for front first gen?
  7. Jun 6, 2013 at 1:55 PM
    #407
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I would suggest finding out what measurements you need first so your not speculating as to what will/won't work. IMO without the measurements your just spinning your wheels. I got the rear wheelers superbumps and they came with a huge tower. The tower is around 2-4" (can't remember) but I did not need it at all. I installed the bumps inverted to my strike pad and now I have maximum uptravel. My point is you may be just fine with the towers they already offer, but it's anyone's guess if you have no dimensions.
    you could easily pack down the bump by adding steel plate under it and just getting a longer bolt. I got lucky and had to do nothing for them to be perfect for my 255/85/16's and POS 5100's.
  8. Jun 6, 2013 at 2:01 PM
    #408
    kbauman92
    kbauman92 Well-Known Member
    Kyle
    North Bend
    98 tacoma ext cab
    King 2.5x6 RR coilovers eibach coils Light Racing UCA Spidertrax spacers Fiberwerx fenders
    if your talking about the front ones they bolt right in, i trimmed mine down a little bit so they werent in play all the time
  9. Jul 11, 2013 at 11:07 AM
    #409
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  10. Jul 11, 2013 at 11:15 AM
    #410
    JohnnyK.
    JohnnyK. Wheeler's Offroad Tech Rep Vendor
    Johnny
    Grants Pass, OR
  11. Jul 11, 2013 at 11:32 AM
    #411
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    def an improvement.
    Order placed, see them when they come in.
  12. Jul 11, 2013 at 8:16 PM
    #412
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Is the tower long enough for me to use the longer Bilstein without bottoming out the shock?
    3" to 4" Rear lift, Shock Part # RCD/BE5-B110-T5
    Extended Length: 27.28"
    Collapsed Length: 16.34"
  13. Jul 15, 2013 at 8:56 AM
    #413
    XPOTRPR
    XPOTRPR EXPOtrooper
    Moose
    Chandler, AZ
    Mid-Travel, Boosted, Expo Taco
    Click build link in Sig >>
    So how many people have spaced these out some? I'm looking at ordering some for the F/R.. I currently rub on all four corners when wheeling .. mostly full stuff. I know these compress to about about stock.. so I would most likely still have rubbing. Thinking I can space them out a bit and sacrifice a little up travel but still have a smooth transition PLUS no/less rubbing.
    Any input fellers?
  14. Jul 15, 2013 at 9:14 AM
    #414
    XPOTRPR
    XPOTRPR EXPOtrooper
    Moose
    Chandler, AZ
    Already did. Guess I could do more.. but am wanting bumps regardless, and if I can space them out a tad.. ill just do that.
  15. Jul 15, 2013 at 9:36 AM
    #415
    XPOTRPR
    XPOTRPR EXPOtrooper
    Moose
    Chandler, AZ
    Lol. That's without the towers correct? I read and saw your pics of them mounted. What about the front?
    Basically.. this is what I've gathered and plan on doing.
    Rears: I don't have a flip kit so ill be using the towers and mounting them and they should be fine.. or will I need to space them as well. I'm thinking no.
    Fronts: space 1/8" to 1/4" and that should be good.
    I know they compress like crazy during high speed(most compression) but for slow crawls, how will spacing them/limiting up travel affect the truck? The wont compress as much to begin with during slow crawls.. plus them being spaced a tad.
  16. Aug 1, 2013 at 9:40 AM
    #416
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Why don't you guys increase inventory to keep up with demand? Seems like.. it'd be a better business move.
  17. Aug 1, 2013 at 9:46 AM
    #417
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    Molds are very expensive to get made, and the build process/curing takes time. Trust me, we are having them produced as fast as we can.
    Thank you all for your patience!
  18. Aug 1, 2013 at 9:57 AM
    #418
    XPOTRPR
    XPOTRPR EXPOtrooper
    Moose
    Chandler, AZ
    Hey Dan. Any insight on my above post?
  19. Aug 1, 2013 at 9:59 AM
    #419
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    I don't know your exact setup but if you run the towers I highly doubt you will need to space it out even further.
    And would you happen to have the link to Ants spacing for the rear? (on my phone and at work. Sshhh)
  20. Aug 1, 2013 at 10:01 AM
    #420
    XPOTRPR
    XPOTRPR EXPOtrooper
    Moose
    Chandler, AZ
    Thanks. That's what in thinking as well. I think im going to have more issues with the front than anything.
